The Abrasive Blasting Resource Thread
930dreamer
Amarillo,TX and Stinnett,TX
I spotted this on CL, might need to look into it today.
"185 sullair compressor with 4 cylinder John Deere diesel for parts. Has newly rebuilt injector pump by Abilene diesel. Ran good made good air but wouldn't idle down. Now will crank won't start I have to many projects to mess with it".
dkmc
NYS--Upstate in the corn fields
I hate that. There was an old Jaeger portable on Rochester CL with no contact info. Ad said "CALLS ONLY" with no number. Dude kept it on there for more than a year. Probably cussed out CL because no one ever called on it....lol
Strouty
Southern Maine
Anyone ever convert a siphon cabinet to a pressure style? What are the pitfalls, if any.
I found an older cabinet that is pressure style and thought it would make a nice upgrade to my pretty siphon unit.
Strouty
Southern Maine
What I should do is just sell my current one as is and then use the pressure one for a bit, until I can get the big unit I have going, except that has been on the back burner for several years now.
lis2323
This ones running around incognito.....:bounce:
Around here, the meth heads would have scrapped out the compressor and used the trailer to live in. Prob try to pull it around behind a bicycle......
lis2323
I have a question for the compressor experts.
I have a potential buyer who is interested in my Quincy rotary screw compressor. His concern is that it is a little too big for his needs. He is building a new shop and will be doing sandblasting as well as running CNC machines.
The unit in question is 40HP 187 CFM. He has power service available but a 20 or 30 HP unit would prob serve his needs.
Besides the “never too big” mantra which only goes so far, what other selling points could I use to my advantage?
I realize inrush power requirements might be the biggest downside.
Thoughts?
lis2323
Yes check check check check. All those points covered.
Thanks for the reply.
lis2323
Sure but you’re prob seen them before.
dkmc
Well, it's got a Baldor Super E motor on it, that should save substantial kilowatts over the rest of it's lifespan. I'd also have to deduct a few points for the non original paint color.
