#FabSpace
zmotorsports
Northern Utah
Stance looks great Matt. I know you wanted to keep low COG but I think that little extra lift will make a bigger difference off road and for the better.
I like your nail trick with filling holes. I've always used my Roper/Whitney punch to make a small slug and then place it in the hole to be filled, backed with a body dolly and hammered to expand or swell the plug then TIG weld the slug autogenously before metal finishing. It works well to make the hole invisible but your nail trick is much faster.
I've also used your trick to add metal back to brackets and such as things have to be "re-calibrated" from time to time. I've always said I prefer to working with metal over wood because if (when) I screw up and I can always add metal back in.:lol_hitti
Great job as usual Matt. Keep it up.:beer:
L
lilscorpion
Colorado
I know nails aren’t the the right way. Slugs make sense. How do you hold the little slugs in place? A magnet? With the nails I can easily hang on to the shank. Do you use the same thickness material for the slug or slightly thicker?
When I use the nails and fill with spot welds, there typically ends up some pinholes in the welds after metal finishing. I would think TIG would be much better for that purpose. I don’t have one at the moment but someday.
neilc
Chicagoland
What a build! So you will undercoat the entire body when you are finished I guess?
Thanks for the great details and photos! Masterful!
neil
L
lilscorpion
Colorado
neil
Thank you for the compliments, much appreciated. We will undercoat at least the wheel wells front and rear. It yet sure if we want to bother with the rest of the underside of the rub or not.
L
lilscorpion
Colorado
Wires everywhere. Difficult to view a build as a quality if there’s wires everywhere. Part of the problem is the sheer amount of wires that need to go through the firewall and no good way to do it. Typically you run the wires through a grommet that the factory has left for accessory upgrades but it’s not usually big enough to handle the dozens of wires which feed accessories like off road lights, a compressor, lockers, etc.
While working on the master cylinder upgrade I noticed a block-off on the firewall.
Looked it up and it’s a block off plate for where the clutch master cylinder would go for manual transmission equipped jeeps. Since I’ll never need it, I can use it to mount a bulkhead-like fitting for all of the auxiliary wires.
A peek behind the dash revealed it’s easily accessible and only held on with two 15mm nuts.
After popping the plate off, I got a better look at it. Two studs embedded in the plate, nothing special.
Backside has some kind of spray-on foam that serves as the seal against the firewall. I’ll have to use a gasket.
Hole is big enough for a significant plug and/or grommet but, if enlarged, it’s plenty big enough to run more than one.
Also browsed around and found there are aftermarket options do re-use the block off plate for the same purpose. Here’s one that’s available via Quadratec - https://www.quadratec.com/c/howto/how-run-wires-through-jeep-wrangler-tj-firewall
It’s simple really, you use a hole saw to cot through the block-off plate and then insert their grommet.
Though that would be really easy, I kinda want something more like a bulkhead which I can pre-wire the inside of the vehicle for what we intend to run accessory-wise and then add them under the hood as we go. Here’s what I‘m thinking. I was going to use 2 bulkhead Deutsch connectors for that reason already anyway. This plate is almost perfectly sized for 2 to sit side by side.
Took some basic dimensions
The plate is about 1/8th inch narrower than the plug. But there was enough room on the firewall to make the plate a little larger so I should be good.
Pulled down some 3/8” 6061AL off the shelf and marked some over-sized pieces to rough cut.
Quick check for bolts. These were metric but I think I’ll convert them to something that’s more common in my shop - 3/8ths.
Cut to rough length on the bandsaw and then pre-drilled and tapped the holes.
We’ll fake the studs using two button head screws like so and the rough out the profile.
Plan is to recess the profile of this flange into the plate and set 2 side by side. This will allow 24 wires to pass through the firewall and absolutely seal.
Cut in the shape of two of the flanges side by side into the plate first.
Then the through-holes for the body of the connector.
A snug fit of the two next to each other while recessed, eliminates the need to screw them individually into the plate.
The side you can see will be what goes towards the firewall and will have a rubber gasket between.
Side by side comparison new and old. Though I’m impartial, I think mine looks cooler.
Front-side of the new plate is what you’ll see inside the engine compartment.
I’ll have it powder coated with the remaining brackets and we’ll get it installed when we get back under the hood.
zmotorsports
Northern Utah
Fantastic work on the bulkhead fitting plate Matt.
We used the same manual clutch master cylinder hole in my son's LJ when we wired in some accessories but not as fancy as your connector setup.
90roadster
Chicago Burbs
Turned out awesome, good job! I like how you sunk them to be flush with the face. Was this on a CNC mill?
L
lilscorpion
Colorado
Thanks guys, we’re getting amped to drive this thing again! Little bling process after work. Got the Trail Gate for up.
Closed. Now from the rear you can’t tell a color difference between the yellows because the whole rear end is the same. Sweet.
Andrew dropped on the tire carrier and started booting on the different pieces and parts.
Working through rhetoric pics, this struck me as funny - notice how he’s still bolting stuff on and the sun went down completely in about 15 minutes. That’s Denver this time of year.
After getting to stand back and see the tire carrier fully installed, I gotta say, Andrews idea of color matching the tire carrier to the body was pimp. Once we get the tires mounted I’m not so sure someone following the Jeep will easily be able to tell the tire isn’t floating.
Next we got the tail light bezels installed. So sweet.
Fully assembled.
Andrew wasn’t feeling like the pics were truly showing the scale of the Jeep so here’s a Poser shot to put things into perspective. Andrew is 5’10”.
csp
Franktown, CO
First time visitor to this thread Matt, 2+ months after you started it. I seem to never find free time these days. While scrolling through the first page the glint of yellow made me think you were going to show some build pictures of your old CJ5, lol.
The pics from TNT brought back some memories too. I have the very first set of sliders that Bob had bent many years ago, still in operation on my CJ5.
Shoot me a PM next time you need a box truck. I have pickups, flatbed trailers, and enclosed trailers that might be useful to you vs a rental.
It's a sweet build for sure! My soon to be 15yo thinks that the '73 CJ5 Super Jeep I found six months ago should be hers. It's the last thing I want her to drive and she may be 18 before I can find time to do anything to it, unfortunately. I picked it off the ground for the first time since bringing it home and found the left front wheelbearing hub flops all over the place. Yeah, it's far from being drivable.
L
lilscorpion
Colorado
Yo! Man it’s been a while, glad you’re still doing well. Funny it reminded you of the CJ, it’s happened to me a time or two In the past few months too. Seems so long ago now. Seems to me to be an oldie now by today’s standards.
The earliest design of sliders we had were different that what most of the ones they have today. Do yours look like these? This was the earlier design.
I don’t blame your daughter for wanting it. From what Andrew is saying, jeeps are the rage in school for both boys and girls. I get it, they like them for the same reasons as we do. Can’t get it running?...come awn dad!! [emoji41]
Thanks for the offer, I might just take you up on it. Honestly I’ve had a few moments lately that make me want a truck. Like yesterday. Snow is piling up and the snow blower Sh*ts the bed. Wanted to buy another but no way to get it home. Turns out shoveling is easy for a 16 year old so I didn’t need one after all...though the idea of a Jeep/pickup hybrid (JT) is becoming interesting to me.
Matt
csp
Franktown, CO
Front wheel bearings sound like a perfect daddy daughter project for a future Jeeper.:bounce:
I wish it were as easy as just new bearings. The snap ring at the end of the outer axleshaft is what kept the entire wheelbearing assembly from coming off the spindle. There was nothing left of the outer bearing, the race on that one had to be cut off of the spindle. Inner bearing took a puller to remove from the spindle. Wheelbearing hub is trashed and I'm hoping the spindle nut threads on the spindle aren't beyond re-using it.
Good thing I hoard old CJ parts!
L
lilscorpion
Colorado
The stock braking system will be no match for the new one ton axles so I’ve been researching upgrades. I found a few different versions of master cylinder upgrades but what appeared to be the easiest involves swapping in a master cylinder off of a ’99 Dodge 2500 which is a direct bolt-in with only a little fabrication. Sourcing one at the local parts store was easy and I think I have just enough time after work tonight to knock it out.
Started with draining and removing the factory unit. Believe it or not it’s empty here, that’s just how dirty the brake fluid was.
Brake lines removed then pop off the nuts that retain the proportioning valve and then the retention lock nuts.
After so many involved aspects of this project, a less complicated mod like this one is a nice change. I’m a minute and a half in and I’m ready to start in on the conversion. The most significant fabrication is to solve a problem with this little guy. This 1/4-inch diameter rod depresses the master cylinder and, based on the articles, is just short enough that it doesn’t have enough adjustment to support and will need to be replaced.
Here’s where a little planning makes a mod so much easier. Goal is to take measurements so I know exactly where the rod is set now, how much it needs to grow, make a new one exactly the right length, and then install it exactly where it (should) need to be for the new master cylinder.
Here’s the two side-by-side. The factory unit is top left, Dodge unit lower right. The casting and piston on the base appears to be maybe half again larger which should make a significant difference in braking power.
That being said, the business end doesn’t appear to be all that different except for the new one doesn’t have a guide tube for the rod.
I worked back and forth between the units taking offset measurements for the depth of the guide tube
And the distance that the casting sits inside the booster.
Then took a reference measurement to see how far inside the booster the rod was. After I do the math, I should be able to use this measurement to check my work.
With the basic measurements jotted down on a notepad, I removed the rod from the booster. I then took one final measurement of where the retaining shaft was in relationship to the face of the booster. This allowed me to figure out how much adjustment was possible with this little guy.
The rod was set fairly deep, about 4 threads in.
Which leaves me with likely less than a half inch of adjustment.
Now to figure out what is actually needed. I created a numbers worksheet that handled the math for me after entering the data points. The “piston depth” in the far right column is where the piston was/will need to be in relationship to the face of the booster (same as the flange on the master cylinder). For this master, I need a rod that is almost an inch longer so the one I have won’t work.
As luck would have it, the rod has 1/4-28 threads and is dimensionally the same as a 1/4” bolt. Quick trip to the hardware store to pick up a 3” grade 8 bolt as a starting point (get 2 because, well you know).
Believe it or not, I cut this one handed while looking through my cell phone so I could take this picture. Remember I had a second bolt (no I didn’t need to use it).
Nice thing about Grade 8 hardware, I know that the thread length on this bolt is 1” so I can easily determine if where I cut makes sense.
Now to the lathe. I’m going to flatten and then round the nose of this bolt shaft to match the profile of the factory rod. I chuck it up in an ER32 Collet chuck so I can get at it a little better without risking the chuck jaws.
This really is maybe a minute or so activity. I barely touch the part while making a half radius motion. Notice the cardboard below the chuck. That’s to prevent the dust and sparks from landing on the ways of the lathe. They’re no good for it.
Close enough I’d say.
Not bad for spit ballin it. Black line signifies where the screw was adjusted previously and the new rod is just shy of .900 longer.
Hand threaded it into the retainer and set it approximately .600 extruded from the face.
And adjusted it to be sticking out exactly the .6075 that my spreadsheet indicated as the new adjustment length. As I started putting it all back together, I found that the proportioning valve bracket didn’t fit well around the new master cylinder housing which makes sense given the difference in housing size.
So out comes the carbide burr to touch it up.
And we’re moving on again.
I had read that the brake lines between the master and the proportioning valve may not be long enough to reach but I wanted to wait and see before buying lines. Unfortunately the write-ups were completely correct though, there’s no way they’ll make it no matter how I bend the lines. I’ll have to stop and get some tomorrow or figure out another way.
Brake lines for the calipers are on order and I’ll bleed the system as soon as they arrive. The setup looks so similar, it almost doesn’t look like I did anything.
Wait…there’s one more thing I should do. I’m not a huge fan of letting peepers easily be able to see all of the mods I do to vehicles. I prefer to give them things to find and it’s those things that typically uncover the enthusiasts who really know their stuff. In this case, I don’t really want the master to look aftermarket so swapping the factory cap back on is preferred.
There, now that looks better.
Now to deal with the brake lines. The new master cylinder is now mis-aligned with the brake lines by almost exactly 1 1/2-inches. There’s two ways i came up with to solve this problem - (1) cutting the bracket and moving the proportioning valve forward 1 1/2” y adding In some material or (2) making new brake lines.
Though I can flare brake lines, I’ve been known to mess up occasionally so I figured I’d go
The metal fab route. Right about as I was about to cut the bracket so I could weld in a 1 1/2-inch spacer it occurred to me that I wouldn’t even need to make an adapter if the stud was, say, 1 1/2-inches longer and I could simply use a spacer to set it forward just enough...hmm.
Concept is to make a spacer that threads on to the existing stud that has a stud of its own. I started with a piece of aluminum faced off square and chucked it in an ER40 6-sided block.
To get a hex it’s really kinda easy, machine a flat and then rotate it and machine another...6 total times.
With the hex machined, I moved the entire assembly to the lathe and chamfered then square edges.
Next step is to drill and tap to match the studs on the master cylinder. In this case, pre-drill to .266 and tap to 8mm x 1.25.
Now to test fit mocking bolts as the studs.
The the stand-off moves the entire assembly forward enough now so the brake brake lines match up to the new master cylinders holes. Proof.
And with the threaded studs in place, the. It’s can now hold the proportioning valve bracket where it needs to be.
And the brake lines can now be threaded into the master cylinder factory-ish. Hindsight I wish I would have thought about machining the stand-off so it would have a pocket on the back so it could conceal the nut behind it. Too much work to do it now so good enough.
Thanks for following along.
zmotorsports
Northern Utah
Excellent work and fantastic write-up Matt.
I couldn't agree more about doing homework and having a solid plan when it comes to mods. They turn out so much better and look less "half-assed" when you do that and yours looks factory. I too prefer to have things hidden in plain site when it comes to mods, especially on certain vehicles. A street rod or custom bike I'm ok with having the mods in your face but on a daily driver that I'm trying to keep OEM looking yet is heavily modified, like you I prefer to keep things hidden and only the true enthusiasts can tell the difference.
Great job Matt.:bowdown::bowdown:
Bob Heine
Boca Raton, Florida
Matt, that's a very nice modification. Much better than the fool who replaced the vacuum power brakes with hydroboost to install tall valve covers on a big block Corvette.
L
lilscorpion
Colorado
Tho I too have wanted tall valve covers on a bbc with limited space, I could not have brought myself Togo hydro-boost to get there...though he did choose to polish the turd so there’s that. [emoji16]
L
lilscorpion
Colorado
Trying to get a dozen things ******* enough such that I can post an update.
...and with much disappointment - my son was driving my JK and it appears the trans is smoked. Just about ruined my inertia. It’s moments like this that not having a bigger garage kills me. Now we have 2 undriveable jeeps. [emoji107]
zmotorsports
Northern Utah
That ***** Matt. Sorry to hear that and hope you can get your drive revigorated. I know what it's like to be in the middle of one project and something else on another vehicle pop up that just ***** the energy out of ya and causes you to lose steam.
I have to tell myself in order to eat an elephant it has to be one bite at a time so prioritize tasks and take one on at a time. I know it's much easier said than done though.
Best of luck and keep plugging along.
L
lilscorpion
Colorado
We’re continuing to pick away at fine-tuning activities today on the front end. As we were working towards finalizing the front suspension we noticed that the front end wasn’t tracking the same on the driver and passenger side. Now in a radius arm setup, this is a ridiculous thing to see because the differential is connected to the chassis in 3 places. Either control arm at the chassis side (just under the seats) and one is the trac-bar which cycles perpendicular to the chassis. As we cycled the suspension we realized that the driver’s side upper link on the radius arm was coming in contact with the Dynatrac bridge at ride height. As the driver’s side tire begins to stuff in the wheel well, the radius arm cannot twist in the housing side upper bushing which caused the axle to go into bind. The driver’s tire pushes forward in the wheel well and the passenger’s side goes hard into the rear fender.
Gave Bob a call up at TNTCustoms and he shipped me out a set of deconstructed upper links. What I’ll do is rotate the link end so it runs parallel to the upper bridge. Simple triangle math allowed me to figure out how to mock it up on the bench so I could think less.
I like to use higher-tech tools and processes whenever possible but sometimes doing so just makes a basic mod take way too long. Using a sharpie I mark the angle I’m looking for.
And free-cut the tubing along the angle with the 4.5” grinder wearing a cut-off wheel. Sparks are cool.
Something like this should do the trick. The tubing fits inside the hole and I’ll weld around the outside and the inside to make sure it fuses into a single assembly. Kinda hard to believe that a piece of .120 DOM and a bracket made out of 3/16” steel plate will be strong enough to withstand the torque applied to it when the radius arms go into bind.
The bracket didn’t come out of the brake perfect, it’s left slightly under bent by design. This allows it to fit inside a fixture which pulls the sides into perfect square with the bolt holes right before welding. Since I’m finishing on the bench, I have to do so a little more caveman like. I start by squaring one side and burning it in. Then I tac the bracket to the tube and use a square to pull it into squareness with the tubing. Here you can see it needs just a tweak.
Fiddle fiddle, putz putz…and I’m able to burn it home.
After a little clean up on the arm, I get it all back together and get it installed.
Now we have plenty of space between the control arm end and the housing bridge.
With the corrected uppers in place, we again cycle the front suspension to see if we’ve solved the problem. The passenger’s side now has room to breathe and the driver’s side matches. Fixed.
zmotorsports
Northern Utah
Excellent recovery Matt.
I worried about that on my son's WJ as well so when we mocked the front suspension up to build the upper links we angled the upper axle end so it wouldn't contact the center section. Even during mock up we still cut it a bit to close as we noted when off-road in Moab in October at stuff on the driver's side it was still quite close to contacting the cast housing.
Great work as usual Matt.
How's the transmission issue coming on the JK? Did you get that sorted out yet?
L
lilscorpion
Colorado
Thanks Mike. Always good to get the inertia back.
The Jk - well “we” did in fact smoke the trans. Not sure how honestly because I really don’t think Andrew was beating it yet it’s a NAG so it should have been able to handle quite a bit they tell me. What ever, forward. I was going to pull it but a local shop called ATSDiesel apparently is kinda ninja with the NAG and I happened to get Black Friday prices so I’m going to have them build one and do the install. Figured it was easier than attempting to straddle 2 torn apart jeeps in the garage at once. I dropped it off Saturday and the owner happened to be there and walked me through their process. As luck would have it, they were just about to run a NAG on their dyno...super cool.
Im hoping they can get me the Jeep back before Christmas but I’ll know more when I check in tomorrow. Hopefully good news. As they say, I'm making every attempt to let it be a good thing and attempt to enjoy the process along the way.
Matt
L
lilscorpion
Colorado
Since we cut out the mid-bed crossmember to re-located the gas tank, we no longer have the factory upper shock mounts. A common mod in jeep builds is to move them outboard which allows the use of a much taller shock mount (which enables the use of taller shocks). TNT Customs makes a fab kit that’s designed specifically for this reason. This is one of the rear upper shock mounts.
The shock mounts get frenched into the frame. To get them lined up, there’s a sequence of steps you go through to get the installed at the correct angle in reference to the rear axle but it’s nearly dummy proof as long as you have a large square, which of course we do.
With the square you pencil in a line perpendicular to the sloped part of the frame using the fat side of the ruler on the differential side. That width of the square is how far off the diff the shock brackets sit so it’s almost a no-braininer. Good thing, this activity has to be a cut once affair.
With measurements taken, I mock the bracket mocked up to get an idea of where it’s going to sit. It’s this moment that we now need to think about shocks. It’s really really easy to just cut the shock mounts in and assume that there are shocks out there that will work but experience has proven that finding shocks in the length you need isn’t always easy. Narrowing in on shocks can be challenging so I like to make it as easy on myself as possible. All I really care about is the collapsed length and usable travel length. The only measurement I need to take then is the collapsed length which means I need to cycle the suspension and take a few measurements. Measuring from just below the axle tube (assumed location of the lower shock mount) to the mock location of the upper I get ~14.625”.
Front differential is easy since we’ve finalized all of the brackets and the upper shock mount is stock. A front shock can have a minimum length of 16.5” (collapsed).
Front shocks are easy to locate. Based on some charts on the web I found that the JK front “Factory Fox Shocks” were nearly an ideal match and have the upper stud we need for the factory upper shock mount. Based on the chart, the Shock designed for my Jk with (oddly) my exact lift height is the shock we need - FOX-883-26-015 shock has a collapsed length of 15.93”. That’s just half an inch shorter than the ideal collapsed length (ideal is where the shock would bottom out) which gives us the 1/2” fudge factor I like to have…perfect.
Based on my measurements, the rear shocks need to be 14” compressed which makes for a limited selection and constrains me to 8” travel shocks in the 2 1/2” diameter shock class. That’s no bueno. Given the length of the wheelbase, we should be targeting a 10” - 14” shock. Though many on the web say a 14” shock will work, it really won’t if you have any plans of running the factory evaporative canister in it’s stock location which we need/want to so we need access/clearance into this hole which means we’d need something taller BUT we also must be able to finagle the eval canister around it.
A little perplexed, I couldn’t believe that this outboard kit was designed to run (only) an 8” travel shock. Andrew figured it out fairly quickly - the rear stretch screwed us. The upper shock mounts were designed to outboard shocks on a stock-ish ride. If the diff were 4” closer, then the shocks would be elevated 2”…enabling the use of a 10” shock. On the shorter wheelbase of the TJ, a 10” travel shock is nearly perfect.
Ok, now I know what needs to be fixed. I gave Bob a call at TNTCustoms and shared a few measurements. If the shock mounts were to stretch by 4”, we’d be able to run a 11” - 12” travel shock. Bob got after it quickly and brought them down to the Toy’s for Tots event a few days later where we connected. While at the event we had a chance to see what TNT has been working on. As luck would have it, it’s also a later model LJ but with a safari twist/theme.
This LJ has many more hours fabrication in it than our LJ does. It has an internal cage and this external safari rack. It’s fully LineX’d blue and the frame, the accessories are powder coated black, an the interior cage and wheels are powder coated a dark-ish blue. It’s running the same suspension as ours and, though I didn’t get a shot under the hood, it also has an LS motor.
Here’s an old Bruiser Chassis. This was a full tube chassis production chassis that Poison Spyder Customs built back when Clifton Slay was the owner. It’s super clean though it’s so clean that Andrew thinks they’ve never wheeled it. I was skeptical as well but having removable body panels does comes with it’s benefits.
Andrew got a kick out of seeing some of the buggies they had on display. Now that he’s worked on his own jeep and is learning, his awareness of things is much different than it was back when I had the business. To be fair, at that time he was 5. He was most drawn to the buggies. So much fabrication.
He spent a lot of time ducking in and around looking at the suspensions, welding, and tube work. External bypass shocks, coil-overs, rear mounted motors, and rear steer captivated his attention for quite some time.
We’d been talking about limit straps recently and he was quick to notice that this buggy had them attached exactly like we had discussed.
We ended up hanging out and chatting with Bob, Mary (wife), Jason (son), and the TNT team until they shut it down. It was good to catch up and time well spent but wrecked our plans to make progress today. Once we got home, we quickly mocked up the new upper shock mounts. Much better. Painful progress is to realize you’ve spent a week and a half to get back to where you started.
L
lilscorpion
Colorado
With the taller upper shock mounts in place we’re now ready to figure out the shocks. Initial measurements indicate a shock with a 18” collapsed length which means we’ll now be able to run an ~12” shock. Fox makes a Factory Shock for the Jeep JL (front) that is perfect for use in the rear of our LJ - FOX-883-26-054 has a collapsed length of 17.43” which gives us the 1/2” error factor.
Though they’re EXACTLY what Bob and I discussed, what I had missed was that by stretching the shock mounts taller by 4”, I was creating a new challenge - the shock tower now blocks the evaporative canister. When the tower is frenched into the frame, the green channel will be clear but the top ear of the tower will prevent the canister from being removed or installed.
So as much as I hat the idea If hacking up these towers, I need to clearance the upper ear but I’ll only trim off the bare minimum while trying to keep it looking somewhat normal.
Out comes the cutoff wheel for all delicate precision work.
With the angle cut, I also round off the ear so it looks half-way not crappy.
Hate it when I have to scavenge sheer metal from Home Depot angle iron. Ghetto. The missing piece will be welded on as the new cap.
Before I can test to see if there’s enough clearance for the canister, I need to prep the frame so I can make sure the clearance is right and adjust now as necessary if it isn’t.
And a test fit. Though the evap canister will just barely fit, it does fit. Good to go.
Get the new cap welded in.
Left is drivers, right passengers. They kinda look like something out of the movie Monsters Inc.
Now to clean up the frame where I’ll be welding.
And since the shock mount will make undercoating behind it extremely difficult later, I’ll give it 2 coats before welding it in.
Left handed, right handed, overhead, and cramped neck welds done...it’s in there.
And wrap up with some etching primer.
Then the other side, done..money.
WoodsTruck
Nice work.
Will the shocks have heim ends or standard rubber bushings?
Seems like there will be some lateral movement through the given travel at least at the upper mounts.
L
lilscorpion
Colorado
Looks great, Matt!
Thanks!
Nice work.
Fox factory shocks do have poly-like bushings in them as opposed to the heim sale that the Fox Race shocks have in them. There will need to be some deflection in the bushing throughout the suspension cycling however the bushing should be able to handle it. If it can't, I'll figure out how to adapt them to use heim-style.
Thanks for following along and Merry Christmas.
Matt
