Show us your welding projects
Muggzy
Orange Co., NY
Boxes are bolted to the floor.
All mounted up and aluminum ramps slid in perfectly.
That's an idea I hadn't considered. Can you share some pics with the atv loaded up. Looks awesome!
I got a short bed chevy that "measured" ok before I bought it, but in reality, it's such a pita to load that I still use my trailer.
Sent from my Pixel XL using Tapatalk
PhantomEB
Medicine Hat, AB, Canuckistan
I assume these are just to deal with the wheel tubs?
Several reasons, wasted space with the old skinny ones that were totally unsafe in my opinion. This way allows me to put jerry cans, air compressor, beer and whatever else I need. Mostly I really wanted to use the full box, not just the in between wheel wells area, once the ATV is in there it’s a ***** to put anything other than lawn chairs down the sides so why not put it all under then the quad on top. This is short of doin a sled deck which I didn’t want. Will be able to roll out the tonneau cover when I don’t need access to the ramps.
I also plan to upgrade to a side by side in the future.
[\QUOTE]
I shall next time I load it up in there, still tinkering away on the ATV was to not have any last minute **** to do.
Why I did it all this way is I hope to pick up a travel trailer in the Summer/fall so this keeps me all nice, short and self contained/sufficient!
ez-duzit
Marina del Rey
Just recently completed the fabrication and installation of a Bimini frame to support a hardtop, 2 antennas and 4 solar panels on a 45' sailboat. It is 6' high x 14' wide, made of 1-1/4" and 1" polished stainless tube. The boat's original pushpits were reused. The camber and large-radius bends were formed by a specialist subcontractor. My helper and I did all the rest of the bending and fabrication; he did the welding. Fish-mouths were done mostly on the mill.
jalexl
Los Angeles, CA
Tunajoe
Ventura County
Nice work!
Gorgeous sailboat!
Old Man Roger
Palm Coast Florida
Here’s one with the ATV loaded up on the old version ramps.
Nice!
bczygan
DETROIT! Arsenal of Scrappers
Tiny little project.
No welding yet, but my first time ever with a cut off blade in the angle grinder.
Had a 10' piece of 3" diameter 1/8 wall pipe that had been used as a column for a greenhouse structure.Bottom 2' were full of dirt and rusty, so I cut a 3' piece out of the middle.
It will be a stand for a grinder or vise. Photos later.
Bill
topcok88
Wanted a modern take on a pergola so I’m making it out of steel and Trex Transcend. The uprights are 5”x5” tune, the cross members are 2”x4” tune and all the plate components are 1/4” material. CNC plasma cut the plate and used tri-mix mig to spray-arc all the components. Great thing about spray arc is very little splatter and excellent penetration with very localized heat. Just picked up all the parts from powder coat so hopefully I will get it assembled on the patio this week. The frame is just over 8’ tall and 10’x29’. Designed it in SolidWorks a little over a month ago.
The ends of the pergola will have privacy screens made using some brackets and Trex Transcend decking boards. The top will be Transcend dimensional 2”x6”.
21173faafcffc917f16cec3077c98a18.jpgd90e6e5675dfd18edbfa52ebfebf758b.jpg84119725038e8cabb21b7046f91d2049.jpg592119cef7ba9dd235af5cd2248440f0.jpgc8735515ec71c88511c7d43b53c5042f.jpg
Tinker2
Pacific NW
Since I’m new here I thought I’d post something to get started.
I just recently completed a 5x10 trailer project. I’m just a hobby welder [with no formal training in any of the different welding disciplines]. I used 2x3 in., 3/16 in. wall box tubing for the perimeter frame rails and tongue rails. The axle was found on CL and was formerly under a mobile home. It is factory cambered [at the axle center] and came with the leaf springs and several sets of wheels/old tires. I sectioned the axle tube 8 inches on each side, approximately midway between the hub and bend of the camber. Tight fitting DOM tube splines were fitted and plug welded into the sectioned opening before **** welding the axle tubes back together.
I did not use the original leaf springs as they were mismatched. I replaced them instead with 2600 lb. rated aftermarket leaf springs/hangers. The sidewalls and rails are all steel. The deck is new 2x10 fir lumber. Everything was painted with an oil based red oxide primer and top coated with oil based black enamel. New Carlisle mobile home tires were installed. I will use one of the extra wheels/tires that I received with the axle as a spare.
I must have done something right as it tracks very nicely on the highway at speed.
I realize this is over engineered for a utility trailer, but that is how I prefer it. I think it should be good for 5K GVW, though I will not likely ever come even half-way close to that. Welding was done with an Esab Mig using straight CO2 gas.
Some photos -
LXCam
Welcome to the joint tinkererer. Nice job on the build and I’m sure you already know those but overkill is very welcome here. ;)
Magneto
"Relocated from VT to Middle TN"
Some photos -
Nice job on the trailer. What I'd really like to see is that nice Ford truck that tows that trailer.
Mag
Magneto
Can hardly wait to see the finished project....
topcok88
It is assembled but still have not received the Trex Transcend. Hopefully around the Fourth of July I will get the Trex. I wish it was here but I’m juggling a 24’x79’ concrete pour next week for the new driveway, spray foam and drywall for the basement and a few other projects. Thanks and I will show so more later.
harley jim
Cleveland Tn..........out in the sticks
Some photos -
Dose not look over built by GJ standards
Nice trailer and welcome tinker2.
Sent from my SM-A102U using The Garage Journal mobile app
Tinker2
Pacific NW
Thanks for the positive comments and the welcome.
Magneto - It is a 77 F-100 Flareside [SNB] w/original 302 & 4 spd manual. A daily driver at the moment and a pending project as soon as the 73 Dodge D100 Utiline [SNB w/318 & 5 spd] is out of the shop and on the road. I don't mean to hi-jack this thread topic, so I will just post a picture & let it go at that.
Tinker2
Pacific NW
This is a foot operated pedestal stand for a new Lancaster Shrinker/Stretcher that I just completed. The pedal pivot point uses ball bearings in the pivot hub. The linkage tubes use Heim bearings in each end. The bearings make for a nice smooth operation of the foot pedal. Primed w/red oxide and top coated with black because that's what I had left over from the previous trailer build. Welded with an Esab Mig and straight CO2 gas.
Tinker2
Pacific NW
Got to love an old truck build thread
Indeed!
And just to stay on topic, my current weld project which is not quite finished [but is operational] is an HF bead roller that I've 'stiffened', motorized, and fabricated a pedestal stand for. I still need to fabricate a chain guard, and there are a couple of other small improvements I'd like to make in the near future.
Motor is a new Bodine 12 VDC, 1/18 HP gear-motor that I purchased off ebay. Sprockets were from the Surplus Center. Currently, with this gearing it turns at 13 RPM at the dies. A little bit faster than I wanted so I think I will change gearing to slow it to around 10 RPM.
Power is through a 115 VAC to 12 VDC converter [not shown but fits in the side mounted tray], through a DPDT toggle switch mounted at top rear [to reverse the feed direction], and a Temco foot switch [on/off]. Painted in black enamel.
Some photos -
TheEquineFencer
Farmville, NC 27828
Where did you buy the Lancaster Shrinker/Stretcher?
danielbuck
Burned in the front IFS crossmember and rolled tube front bumper for my 33 Chevy this weekend :)
Still need to box the front part of the frame, will probably get to that next weekend.
mielked
Central Coast California
I've always enjoyed seeing everyone's projects on this thread so I thought I would finally contribute and show you a few of my projects. This is my work bench I constructed out of 2x2 steel tubing. It has two Harbor Freight tool chest built into it with a space between for my rolling table saw project I'm currently working on. The work bench is 16'x25" and is approximately 38" tall. It is topped with a 2.25" butcher block.
zmotorsports
Northern Utah
Very nice work on the workbench. That turned out fantastic.
Thank you for sharing. Quite a stellar first post.
Bigblue&Goldie
Looks good Mielked! I really like the color stain you chose with the black boxes and how you made the top conform to the recess in the wall.
4 FN 27
Minnesnowta
Beautiful!!! Well done!!!
aka Larry
Eastern, NC
Nice work man!
BTW, thanks for the pic of showing how you maneuvered the big heavy box into the frame. I know some here just happen to have a forklift on standby, but for those who don't, your idea looks perfect.
csp
Franktown, CO
Take the drawers out (which is easy) and they become no problem to move by hand.
quadrcr87
Travelers Rest, SC
Really smart way to get the boxes loaded into place. I have been thinking about how to do it without a forklift. The bench turned out great! I look forward to seeing the rest of your projects.
