lafester
Also the cast iron base (with tool rests) is interchangeable with the cast aluminum one, and both will fit any of the block grinders. The cast iron one of course has the coolness factor but will rust.
This is our bench grinder at work. Not sure exactly how old, but the owners' dad started the business in 1964.
I may need the source for those bulbs.
These are the bulbs I got. I like the temp and brightness, they seem to be about perfect for this grinder.
https://www.ebay.com/itm/6pcs-BA15D...var=690978360158&_trksid=p2060353.m2749.l2649
Thank you.Nice job restoring that 1/4hp pre-block. I see that model available fairly often, but can't get past the lack of guard end covers. Maybe I'll give one a try once we can leave our homes again![]()
Not sure this qualifies but I was buying a snowblower off a guy and he gave me this old Milwaukee bench grinder.
He didn't know if it worked but I took it home and plugged it in and it worked. I got a grinding wheel and made a stand for it.
Its pretty darn powerful I thought it would be gutless.
Does anyone know how old this is or anything about it?
I like these Milwaukee grinders.Is it a two-speed?? The nameplate lists two speeds - does the switch select which speed you want, or do you rewire it (like changing voltage) or ...?
I have a 1/2-HP model 4980. It also specifies 3450/2850 RPM, 115V, it is a single speed. What is interesting is both yours and mine also specify 60/50 Hz.
Could the 2 speeds depend which frequency they are operated at?![]()
Very good information, and a great job!
this one popped up today so I will grab it in a few. My first 1/4 hp pre block.
$55
That grinder looks in great shape. That’s a steal.
Nicely done lafe! I've often wanted a hand crank grinding stone, maybe good for knife sharpening?The grinder is very clean. Tag is 9 54.
If only it was a 1/3 hp I would be very tempted to keep it.
The hand crank grinder is actually pretty nice. Not sure how useful beyond being decritive.
Sent from my Pixel 3 XL using Tapatalk
I just picked this one up today . It might be the oldest at 7-54. Paid top dollar for it but it will last me forever . Just need to find the missing parts . I was looking for a block grinder and stumbled on this pre block thread . Realized this one was a pre block 1/2 hp so I jumped on it . Runs good but needs a little work . Any help with parts is much appreciated.
Spring washers are installed on the fan side to push the rotor towards the centrifugal switch.Old Radar, I realized the housings were on wrong when I bought it. Easy fix. When I took them apart there was only one finger spring washer. Should there be two ? Also are there spacers between the snap ring and bearings ? Your stand and restoration are great. You give me inspiration to restore mine.
Very original 1/2 HP, "7575" Pre-Block with 10-56 date in "Power Bronze" on optional power bronze stand.
It came with what i believe is its original wrench, standard with the 1/2hp models. A parts list/page for the "7575" may confirm the wrench. Regrettable I don't believe it was ever wiped/cleaned off in 63 years.
.......I believe OE grinder bearings are shielded. I've had some success applying oil to shielded bearings by clamping the shaft in a vertical position and letting oil seep into the space between the shield and the inner race.
Interesting. I was aware that those sealed/shielded bearings were available, but have never seen them on a Craftsman machine.I am restoring another 1/3hp Pre-Block and was surprised to see the bearings were Shielded AND Sealed types. I actually didn't think they made decent sealed bearings that long ago. I suspect they are original since there was no evidence that the grinder was ever disassembled. I am replacing them with SKB sealed.
Finished with another 1/3hp like the one that started this thread. It didn't come with eyeshields so I made some, but I am not much of a fan of shields (I wear a full face guard). It runs flawlessly. Color-wise, I kept thinking "My grinder, my color" so it is what it is.
I inherited this model from a family friend years ago and I'm finally going to set some time aside to restore it. From what I can tell from the part number it is a 1955/1956 Craftsman 1/4 hp. Part number 115.19500, Mfrs number S-7561. Only thing missing is the right side tool rest and the cast cover on that side is broken. I've actually used it a few times for small stuff and it runs excellent with long wind down, so I believe bearings are good still. Old/dry grinder bearings will tend to run longer after power off, due to lack of drag from grease. The cord needs to be updated to one that is grounded and its chafed anyway. Saw an Amazon link in the block thread that I assume it's a generic and can be used in this application as well. Yes, and that is a worth while safety upgade.
I know nothing about these, and can only presume this is the original color. Some surface rust is present and it is dirty from years of use/sitting. I wiped it down to get some heavy grime off already. Tore it down tonight to prep new wiring and repaint.
Read a number of posts on this forum, mostly the "block" thread and excited to learn and see its progress.
Right now the plan is to keep it and make use of it. But does anyone know the value of these and if they are better left original or restored? Prices vary a LOT, depending on local supply, size/HP matters of course. Bigger/more-HP the more $$, also condition AND completeness. OEM parts are scarce or NA, use parts are also scarce. OEM NIB command breathtaking $$ on eBay!
Also would anyone happen to have the right side cover complete and a tool rest for this era they'd be willing to part with? Would love to repair that to original.
