measuredtwice
That's a really short spring. The old Snap-On 36 toothers had super long springs and do well with a shortened spring. I haven't tried swapping springs on a ratchet with a spring as short as that Stahlwille.
The replacement is a much lighter spring. You might try using a longer length of the replacement. You'll have to compress the spring more during assembly which can be tricky. It's even more difficult with the super long spring on the Snap-On 36 tooth so Snap-On made a special tool. It's just a thin piece of spring steel with a hole that's smaller than the diameter of the ball bearing. You use the tool to compress the spring and the hole traps the ball bearing to keep it from flying across the room. It would be easy to make your own.
Ordered some new springs to try and reduce backdrag on a 1/2" Stahlwille. Didn't want to cut the original spring, because I think I will be selling the ratchet on. Got the spring from a Chinese seller on Ebay. Thinner gauge wire so a softer spring.
The softer spring results in much lower backdrag and the ratchet mechanism still seams to work properly, but the switch became floppy. Just stays where you leave it rather than positively engaging on either side. Not recommended.
There must be a little variation in spray nozzles.
