Show us your welding projects
Furby1184
East Bridgewater MA
A few more pictures of the truck progress
smalltown
Western Maine
Furby1184 nice work. You must have somehow removed all of the original inside rocker panel, and tack welded the new to the floor. I'm imagining you will close that joint up with a weld the entire length to keep out water underneath.
I've got a small truck that needs similar work. I took a look underneath, and wondered just how i would replace the inner rocker.
Eric H.
Nor Cal
I found GJ while researching tool restorations. This is my latest project that my friend and I finished recently. Took my wife's 99 3/4 ton Dodge Diesel and converted it to 12" travel coil over shocks on all 4 corners.
Eric H.
Nor Cal
Just don’t tell her how much the shocks cost LOL
I hear you but these are FOA which are about half the cost of the Big names and still American made. I can't say I would recommend them to the average Joe though. They have a bad reputation for quality control when it comes to deburring internals and this can lead to leaks. I knew this going in and with the help of my friend who tunes and rebuilds shocks we rebuilt and blue printed them new right out of the box. Once the internals are cleaned up, there isn't much to separate them from Kings and Fox.
Old Man Roger
Palm Coast Florida
Nice. It’s good to have capable friends:D
Furby1184
East Bridgewater MA
Todays progress. Leaf springs, hangers, rear cross member removed. New hangers, shackles, springs went in. Now I'm going to reinforce and stretch the frame
Furby1184
East Bridgewater MA
I cut everything out with a plasma cutter and I did fully weld the seam. No sense fabricating stainless rockers if you're not going to do it right lol
JackOfDiamonds
Idaho (USA)
Not welding...a few brazing pictures from the last couple bikes I made.
Furby1184
East Bridgewater MA
Made some progress today. Frame stretched, reinforced and the frame for the flatbed is built
JackOfDiamonds
Idaho (USA)
That's great. I'm afraid brazing is turning into one of those lost art things that still has it's place if people were aware.
It really is a great process. I especially appreciate the low distortion potential and the nearly unlimited repairability. And plenty strong, as my destructive testing has shown over and over.
Bigblue&Goldie
That's cool to see. I've always wondered what would yield first. I'd be curious how thick you could go with the tubing before the braze fails first?
iagsxr
Vinton, Iowa
txvwnut
Bedford, Texas
All Norton feather bed frames are brazed. When the builder was asked why he said brazing when done right is just as strong as weld in that area.
Slick111
Everett Wa
OK welders whats the solution correct rod for welding ( cast steel I assume ) C clamps.Not trying to repair just need to build a type of holding jig by welding 2 clamps to a cold roll steel plate.
JackOfDiamonds
Idaho (USA)
That, I don't know. I mostly use 0.028 or 0.035 chromoly. That's about as thick as it gets for bikes. There is a theory that the braze will be stronger than the tubing as long as the fillet is X times thicker than the tubing. X varies between 3 and 6 depending who you talk to. Most bike fillets are overkill by that criteria.
Brazing is used on much thicker tubing for motorcycle frames and was historically the method used for tubular race car frames which surely also used thicker tubes.
txvwnut
Bedford, Texas
Since we’re kinda on the topic brazing would be a good choice for this, either with an o/a setup or a tig.
iagsxr
Vinton, Iowa
I've accidentally welded C-clamps to stuff with just a MIG.
If they're not life and death critical I'd MIG them to the plate then hit them with a hammer after they cool. If they stay attached I'd call it a win.
Or braze them.
Or stick welder with nickel rod.
Or clean the flux off your nickel stick rod and use as filler material with your TIG.
ClappedOutBport
I've seen plenty of C clamps welded on. Seems like folks used just whatever. Standard mig wire, stick, whatever you've got it should stick.
harley jim
Cleveland Tn..........out in the sticks
I just mig weld my C clamps to my bench then when Im done I clean up with a grinder.
Sent from my SM-A102U using The Garage Journal mobile app
Furby1184
East Bridgewater MA
More progress
DeeDubz
Socal
I saw this project on Pinterest. Keeps my clamps at the ready.
bplayer405
Pekin IL
Picked up a tig welder a couple months ago and have made pretty good progress on welding thin aluminum. Working on my mod-v jon I've been sealing rivets, modified the seating, extended the front deck and added a elevated bow. Next will be raising the transom framed with aluminum rectangle and adding a rear deck. This is the type of work I want to do on the side...445a908040729c58ee044affadf99cfe.jpg32cfe999cd43eadb8a4087ae4fbff588.jpg53e88cae5840f80693988647dbc0ad6c.jpg
Sent from my SM-G973U using Tapatalk
afazz
Pittsburgh, PA
I just finished my first aluminum TIG welding project: a handrail into the garage basement. The original owner/builder commissioned the stairs, and I wanted to match the style. This was a great project to get started welding aluminum since it isn’t structural, doesn’t need to seal any fluid, and all of the welds were ground off!
zmotorsports
Northern Utah
Excellent job. That turned out very clean and sanitary looking.:thumbup:
Woods_Wanderer
Virginia
Here's my latest, I just finished up this welding/fixture table. This is my second big project since I started metal fab during covid. For this project I took heavy inspiration from several table builds here on GJ as well as a couple of excellent youtube project builds.
I designed this to be a general purpose shop and fab table, with the size and mobility aimed at keeping it out of the way in my limited floor space.
I also tried to keep costs minimal by using reclaimed scrap metal as much as possible, in fact with the exception of the top plate all of the raw steel for this table came from a local scrapyard.
Total cost of materials for the table came out to roughly $600, $330 of which was steel.
Tools were another $600 but nearly all of that was the mag drill and related tooling and assessories.
Length: 56" with an additional 36" slideout, Width: 40", Height: adjustable 32-37"
Weight: ~600lbs? it's very overbuilt
(this plate is not actually warped)
Mag drills are amazing, but if I had to do it again I'd get a shop to plasma cut these holes for me.
sweetk30
finger lakes area upstate ,ny
Friend wanted a side gate / ramp to load 2 atv's better . He had me install this used snowbear utility trailer ramp i saved from a rusted out trailer . The ramp was still solid so i didnt toss it .
Made up 2 mounting tabs from 2.5x2.5 1/4 angle iron . Then capped the top of the angle to set the side rail upright on . I drilled a 1" hole in each unit for the pins .
Popped the whole thing together and drilled 2 1/2" holes 1 per side for the lock pins when up .
She come out real nice and rock solid . He will clean up the rest and do a quick paint job .
