Between 705 & 1200 SQ/FT Miller Time Garage
G
GreenIron
A bit north of the GOA
Update:
Today, we completed the right side of the shop's mid-wall.
I parked the black rolling toolbox to hide the automotive related tools.
Cleaned up and straightened out the left side (fab area).
Need to install a few receptacles on this wall for the drill-press, grinder and MIG.
A view from the front of the shop.
Next job is to build and hang a sliding door in the 56" wide opening.
G
GreenIron
Wow, looking fantastic!
Thanks. :)
Very nice.
Thanks. :)
Looks great but your welding table looks a little flimsy. :lol_hitti
Jay
Thanks. :)
Yeah. It is a bit flimsy. :ROFLMAO:
Best I can figure, it's between 750-800 lbs., since I've added the lower shelf. ;) The top is 3/4" plate steel. The legs are part of a crowd (boom extension) cylinder from a Galion Crane.
The vise also is heavy, like 51-lbds. Wilton Tradesman 1755. (y)
G
GreenIron
Spent some time working on the awning support, for the south door.
These are 4"x4"x10' square tubing and are used for the uprights.
I drilled hole to install alignment tabs.
Clamped tab and welded in place.
Buffed and prepped for paint.
The gloss-black paint was allowed 3-hours to dry.
Installed one post onto the stub, which was set in place prior to concrete, then welded in place.
Second post will/should/maybe be installed today, along with a 2"x2"x~16' square tubing to tie the posts together at the top.
G
GreenIron
I got frustrated at having to run extension cords. Instead of working on the awning frame, I Installed three receptacles today.
One to power the drill press.
One to power the bench grinder.
Another to power the MIG.
I ordered 2-foot switches last Friday and they arrived after lunch today. I installed one on the bench grinder.
The second foot switch will be used on the table saw. (y)
While installing the receptacles, I also installed a double-gang light switch and receptacle in the wood working side of the shop.
G
GreenIron
Something about having working receptacles with face plates that make things seem so complete.
Yes, it is nice. (y) And they're all grounded and wired correctly. :)
My son used to be a commercial electrician. Now he's an Instrumentation Designer. I've done my own wiring in the pass, but I ask him questions when I'm not sure about something electrical.
G
GreenIron
Today, I ripped a few pieces of cedar boards to make stiles for the north door glass.
Wife helped by priming and painting the boards. She likes that type of thing. (y)
Hopefully tomorrow, I'll cut them to length for installation.
While she was doing that, I fabricated a metal frame for a gate to be installed between the shop and house.
Buffed, sanded and primed. Ready for a couple coats of gloss black after hinges are welded in place. Later, horizontal cedar boards will be installed.
G
GreenIron
Late yesterday afternoon, I installed the dust-to-dawn lights on each side of the north door.
This pic was taken last night.
Today, the wife and I cut and installed the window stiles on the same doors. We also installed the lower weather seal on the doors.
G
GreenIron
Ok, so the pitch makes more sense now, but why the cross bar in the middle of the horizontal portion?
Support.
I will have to climb on this frame to install the roof sheeting. It will need to support my fat ***. :ROFLMAO:
Also, we're in a Hurricane corridor. :eek: Late one (Aug. 2021) delivered 145 mph winds. o_O
I did more work on the awning frame this morning.
Added an additional horizontal tubing and angle bracing.
I hope the weather holds out for me to install the steel sheeting, trim and flashing.
G
GreenIron
How was the heat up in the loft this summer?
I wasn't too bad. It's used for storage only, so I'm not up there often.
I only went up in the loft once yesterday. The entire shop is insulated.
I did install a ceiling fan in the loft late last year. I have an oscillating fan up there also and it helps. I need to install the roof vent during this Winter.
Was planning on working on the awn today, but my Vertigo returned last night. Last time I experienced Vertigo, it took ~10 days for me to recover. :rolleyes:
