anti seize fetish?
sberry
Brethren, Michigan
It took me a long time to learn some of the stuff I could have in 5 minutes if someone shown me. Thats another matter but the statement above about galling is correct and I believe Nascar guys fuss over this. Rightly so.
Take a commom hwd bolt, run a nut on, feel it, run it on/off and even by the second time it may smooth noticeably, add a drop of spray,, even smoother. Even on a good Nat Course threat 40% of the torque is just to overcome friction, when its rough, dry the engineer says 8 times and that doesnt include outright seizure.
You can magnifry this with Nat pipe, screw a couple dry 2 inch together, even by hand, they get outright stuck, a little WD first and you can tighten and remove them. 2 problems with the installation,,, it didnt get tight and it wont come loose in simple terms.
Air guns are terible, this was a bit less of an issue when people used a 4 way but dry nuts are nothing new. When they come off with a snap it hasnt been installed right. The saving grace with hand tools is that they are slow, used a lot with coarse threads but do not make heat from real speed.
I have a manual from old Snappy Torgue wrench I have, says on the first page,, all values based on clean lightly lubricated threads. Got a nice chart for grade/thread/bolt apps and a list of common car stuff of the day.
If a guy went thru the full John Deere trade school they have a Fastener manual as part of the program.
In cases where we are using screw for r & run self drillers back out, put a shot of spray and run back in. I bought this old Mack Truck a French version and at first it looked like oh ****. I had a cab from the South but we had to ter the other one off and figured man,, it was rusty. All the stuff came right loose, they must have had super QC with the bolt lube and torque.
Back in the day we used more gallon products and spray bottles and today I like the conveienceand cleanliness of spray cans. Shopping was more difficult than also but we would add a couple cups of ATF to a gallon of WD40. The price and practicality changed, went to liq wrench and did the same but finally come to shopping spray cans on sale. I like about any of them at around 2.50 and under and am a case price opportunist. We loose a few to can damage, just a fact of life. Same with brakleen, try to score to go from sale to sale.
We have a lot of alum threaded pipe connections, one inch, have put a lot of them together with simple spray when the ideal sealer was not at hand, years later they come right back out, never know the difference. They used to grease them or common sealer and in some ways this seems to work as good or better in that app. Many a day have used hyd oil on the job as a thread lube for piping, its a thing of beauty with steel pipe, can turn it tight.
sberry
Brethren, Michigan
I agree a dab is all thats needed, oil in the connection also displaces and repels water. Its interesting to look at bolts under magnification.
One of my helpers jobs is to test run bolts and nuts. Had a couple guys a while back trying to install a difficult to back up bolt, finally had to stop them, get a new bolt, test the nut, put a flat washer under it and some spray and wtf,,, hits up from one side with the air gun. Usually if a bolted connection wont tighten with one wrench from one side something is fundamentally wrong.
The major change with all this that means 2 cents is the reduction of use of the lock washer. I need to go to the real bolt store and get 3/8 and 1/2 machine washers by the box, we use a ton of common fender washers but there are times the right fit etc under the turned element is ideal, a little oil on the thread and a drop on the face of the nut.
sberry
Brethren, Michigan
Ok, here is a dandy, bolt/lug nut oiler. Put a shot of oil on foam, press bolt to oil, very neat, no overspray. It should have a magnet on the bottom and a simple hinged lid?
I want a version on a belt clip, maybe something with a flip top and a dauber?
Boiler
Indiana
I used to really push for people to use anti-seize when installing my jeep skids I used to make. Problem was getting the bolts OUT before you could put the skids on. They often would have issues. I like it on everything, but I don't use it on wheel studs. I rotate my tires 2 times a year and change my winter tires in and out so no lug nut is left on for more than 3-4 months, and thats if no maintenance / touch up paint is done.
th148
Anti Seize is bad to use on lug nuts. The I have used it for years on the OLD STYLE BUD wheels-- the ones that have the combination of thimble and lug nut. If you use it on the hub pilot wheels, you can damage the hub. the general purpose was for things like exhaust bolts, bolts that are going to be exposed to the elements--that would not normally back off. YOUR WHEELS CAN COME UNTORCED AND WALK OFF THE VEHICLE!!!
Spudland_Dave
Maine
Urban Legend as far as I can tell...Millions of miles combined with all my family's vehicles...Farm Trucks, Pickup Trucks, Tractors, Cars, ATV's, etc... Never seen or even heard of such a thing. I've actually had an un-torquing incident with a DRY thread lug installation on a brand new Deere 3520...promptly took off the wheels I hadnt already taken apart, anti-siezed them...re-torqued them and voila...no more problems.
That must only apply if Sasquatch is the one doing the wheel torquing.
porschedude996TT
Santa Maria, California
Engineers figure bolt torgues are using either a dry torque or a wet torque method. Using oil or anti-sieze could cause you to over torque a bolt. Most automotive stuff is specified dry. Head, Main, and Rod bolts/studs/nuts from ARP have specification of wet and dry that differ some 25-30 fl lbs.
Big-Foot
Midlothian, TX
It's clear that this will be like arguing politics or religion here but I'll say it anyway...
Never use antiseize or oil on lug studs/bolt threads.. Seen too many snapped studs, warped rotors and lug nuts you simply could NOT break loose with hand tools after this was done. It also will cause extreme galling of the contact surfaces on alloy wheels which further complicates matters.
Living in Minnesota I see my fair share of rust. Clean the lug studs with a wire brush before reinstalling the nuts and you're good to go 99.99% of the time. There are some cases where lightly oiling the end of the stud with a penetrant "after" the lug nut is installed and torqued. This would be on vehicles where the lug stud is exposed (no wheel cover)...
There - I said my peace.. Flame away...
sberry
Brethren, Michigan
I have seen truck wheels with major problems caused from dry installation, wheel fall right off due to the fact the bolts stopped turning but were not tight. Period after that statement, never seen a lubed ne installed to torque, many ever survive extreme over torque provided they done seize, never even seen one come loose and fixed a dangerous situation which was shop practice involving cement trucks and loose wheels to not one more issue by applying a simple 3$ spray can.
There was an engineer a while back started some forum but it was ahead of its time involving this issue. The specialist may need never seize, that I have no dispute with, the other 99% need a shot of spray. I would come to a stop without it.
imagine44
I believe this. I had a caliper bracket bolt work it's way out and off while driving. I had used anti-sieze on the bolts.
sberry
Brethren, Michigan
I am a firm beiever the went to and advertise dry install because the technition is not going to follow instructions, they have figured out that half the worlds mechanics are below average and whats the answer? The engineere back in the day knew this, it hasnt changed, lightly lubricated with oil.
Here is another question, when we got a bolt thru a bub and sandwich a rotor hub on this how does this warp a rotor? You could torque one to 200 and the rest to 50 and it wont make a bit of difference.
This seems to be a job everyone assumes the next guy does right because they paid him to do it. They turn less than qualified people to work on your car regularly, never had one bit of training in some of these areas and most of the hearsay learning about it is almost like electrical code.
No one has made sure the student has learned the principle.
E.Marquez
Kempner Texas
Anti seize,anaerobic thread locker (of the correct grade) or a specified lube goes on every threaded fastener. Preventing galling, lubing where spec,ed, locking or just sealing the threads IS THE RIGHT WAY, far as I'm concerned. 40 plus years of anecdotal evidence supports my opinion. Though I'm sure some expert will say otherwise.
sberry
Brethren, Michigan
I have had 2 wheels come loose in my career, both on stuff I owned where I worked on it. 25 years apart and I cant rule out that I just plain didnt finish, got interupted etc. I can recall a time where my helper burned a dry nut on with the gun and seized it where it cause me greif, a service call.
My own, cant remember the last time I seized a bolt. The only bolts we ever have a problem on are the ones we actually do use it on like most others, certain exhaust fittings. Use a tiny smear on spark plugs.
so2315
I have read this thread and have a question. If I use this as personal lubrication with the wife, will this prevent the galling and seizing that seems to be prevelant the longer you are married?:lol_hitti
alex71
SE Florida
I had never used it till I moved to the Midwest and attempted to take off a Caravan rotor after my first winter. It was rusted to the hub. I actually broke the rotor getting it off.
Once learned... it wasn't going to be twice burned. After that, anti-seize was used liberally. Now that I'm back west I still use it and preach it to those I know. Yep, it's great stuff...
Yes, this. a little on the threads, a lot A LOT on the WMS. who wants a to use a sledge hammer to remove wheels? not me.
sberry
Brethren, Michigan
The only spray I dont seem to like and it might be because I am not familiar with the characteristics is that super tech from Walmart. It seems a little like WD40 and for some reason I like the "feel" of spray similar to that Kroil which is near as good as it gets in my opinion. Breakaway is great but comes in a gusher can. I like the Wally world cause the cans are smaller and cheaper but is it my imagination or does it not work the same?
Also,, smearing a little on a hub is a different issue than lubing threads. There in theory might even be a product which sheds water better.
The best sales seem to be on liq wrench and the occasional CRC but usually strip the shelves off before assembling a case or 2.
BB70
cincinnati, ohio
Worked on firetrucks. Shop rule was one drop of lightweight oil per lug stud. Torque to 450ft lbs. If there was a accident that was wheel related and above was not adhered to-the hammer was coming down-DOT was swinging the hammer.
WHT
I have always used anti seize. My son says I have a anti seize fetish. I'm not offended...I love this stuff. I've always put it on lugnuts and on anything else I thought I might possibly have to take back apart later....except seating ball joints steering components etc.... Pretty much everything under the car exposed to rain, rust, road salt.
The old boy at the dealership tells my son not to put it on lugnuts cause it will cause lugnuts to be over tightened/torqued and stretched. Thus possible failure and injury to someone if their wheel was to fall off from broken/streched studs.
I've never heard of this. Anti seize is my friend why would it do this to me. Its like RED SOLO CUP....its my friend. I'm confused. LOL
I say "Anti Seize Fetish Lovers Unite"
Opinions?
Your son is correct. :beer:
Torque for critical fasteners is usually quoted for dry, clean threads and anti-seize can do more harm than good in many applications where galling is not a serious problem. You should not torque a fastener with anti-seize to dry, clean torque specifications. It should not be used for lugnuts unless specified (and spark plugs).
I do use it on the steel aluminum contaxt surface of lugnuts and not the threaded section.
purplezr2
Central MN
Every seen assembly lines, lots of bolts are installed dry
ssentt
Iowa
Anti seize costs money and that cuts into profits.
Wheel studs have held up to the use of impacts whether dry or lightly oiled for years. It seems to me then they would be strong enough for the use a hand torque wrench and anti seize. I have seen impacts break dry studs off, but I'm sure too they could break ones with anti seize too given the power of impacts. The general consensus seems to be that the use of anti seize on lug nuts that are properly torqued, is not going to contribute to the lug nuts loosening or breaking. Here more people reported using anti seize on lug nuts for years without any problems vs people advising against it so far.
This link http://www.mechanicsupport.com/articleTorqueWrench.html goes to a page with some interesting information about the difference in axial loads (preload) when coating *only* the threads with anti seize, vs coating the threads and under the bolt head or nut where it seats. If the information is reliable, there is a difference in axial load. Also if you compare the preload value of no anti seize vs anti seize on threads only, the load is even less with the anti seize. My guess is this is probably due to the variations in friction of identical bolts with dry un-lubricated threads.
The question of whether or not to decrease the manufacturers torque specifications to account for the use of anti seize is debatable, but if you can keep anti seize off the contact point between the end of the lug nut where it seats in the rim, you are probably better off staying with the manufacturers specified torque. IMO.
According to http://www.boltscience.com/pages/vibloose.htmthey the most frequent cause of bolt/nut loosening is side sliding effort of the nut or bolt head relative to the joint. In the case of a wheel/rim, friction between the wheel and the hub prevent traverse movement. That friction is generated by the axial force/preload from torqued lug nuts. To prevent the possible traverse movement of wheel and hub its probably best to not use anti seize or any lube on the back side of the rim where it contacts the rotors, hub, or brake drums. IMO I have applied anti sieze ther many times with no ill effects, but will do so very sparingly in the future and only to alloy wheels to steel hubs.
I will continue the practice of occasionlly applying a small dap of anti seize to the threads of lug nuts and not the studs. The reason why is to prevent any anti seize from getting on the contact point between the end of the lug & where it seats in the rim lug recesses. IMO it is wise to make sure that any shop you take your vehicle too only uses a hand torque wrench to tighten the lugs to the correct torque. If they don't, take it home and retorque them yourself.
My anti seize fetish continues......
Wakefield
Arlington VA (but would like to get out to country
Sometimes lugs do unscrew and fall off or even the wheel fall off (I have found lug nuts lying along the road) but I suspect that someone simply forgot to tighten at a quicky tire place after running the nuts into place.
Also do some aluminum/mag rims require retorquing after a month or so after being put on?
freedomgli
nova
I prefer Molykote P-37 for general purpose thread lubrication anti-seize. It sure beats silver Permatex, which seems to harden with age and can make a mess that's hard to clean up.
HMCFab9
Fox valley area, Wisconsin
Opinions?
So why not on steering & ball joints? I always use it on tapered suspension parts that I know I will be taking apart often. They come apart so much easier that way & they are all held tight with castle nuts & pins.
Is there a reason not to use it there?
aczr2k
NW Minnesota
Yeah I can almost absolutely guarantee that not one of the engineers/product designers have ever had to take anything apart 1-20 years later either. Its all about cost savings.
kamesama980
columbus, IN
I'm vehemently anti-anti-seize. Comes from working in an automotive shop, automotive education, and working for a major engine manufacturer.
Having worked in a an automotive shop for a few years, using anti-seize on studs and not torquing them properly does overstretch the studs. You can feel the difference between overstressed studs (with or without lube) and good clean new ones (w/ or w/o lube). old stretched studs slowly take up tension and I've had them snap prior to reaching specified torque. good studs are loose, then there's some friction, then the wrench clicks. No I didn't save the link and this isn't the first time I'm kicking myself for it.
If you rotate the tires once or twice a year and torque the nuts properly you should have no problem getting them off again. If they're rusty/tight and you don't want to stretch to buying a tap and die, try putting a bit of valve grinding compound on the threads and run the nut in/out a few times (clean it off both before final installation)
I read an article online a few weeks ago about how some engineer measured the angle required to achieve the same torque with a few lubes vs dry and what the dry torque was at the same angle... IIRC anti-seize was ~60+% higher dry torque on the lubed fastener for the same angle. That means a LOT more tension and physical deformation of the fastener. You can only stretch metal so far before it has the paperclip effect as it passes the yield point and no longer returns to it's original size/strength.
Every (manufacturer published) car repair manual I've read states that torque specs are for clean, dry threads. There are some instances where a manufacturer specified lube to be put on a fastener, in those cases, yes a lube should be used. some of the newish (mid-late 2ks?) ford super duty trucks come to mind that ford said it's OK to use anti-seize on the studs. Most head bolts are specified to be lubed with clean oil. The ARP studs for my car gave different specs for 3 different lubes and discouraged dry installation.
On non-fastener parts, anti sieze is fine (used sparingly and appropriately) IE between the brake rotor and wheel hub or between the wheel center and hub. I definitely put it there because I too have taken the face of the rotor off with a hammer and split the 'hat' section before it let go of the hub (customer's car, not my own)
I would not put it on tapered shaft joints like steering parts and ball joints. The tapered shaft is supposed to self-tighten and stick. Quite frankly I'd rather it be a little hard to get apart again when replacing it 10 times than have it than come apart once when I don't want it to. With the right tools, I've never had a problem getting them out working at a shop in the rust belt (west of chicago)
Working with engineers at work and in general (including a few in the family) I'd agree that 90% have never turned a wrench. 98% have never had to take apart something difficult (IE over 5 years old and/or from the rust belt). The sad part is 20% don't know how what their engineering actually works. By no means is this uniform or universal, merely an approximate, observed trend.
Holy **** that got long...
stratman977
Belle Vernon, PA
People are so quick to blame engineers for everything. People who make these kind of comments don't know why things are the way they are and then instantly think they know better. There are alot of tradeoffs in a design that have to occur. Take your cost savings for example, if engineers don't think about cost savings than the common man wouldn't be able to afford to own a car. I agree that some things on cars weren't well thought out or designed well but sometimes theres a real good reason for why things are designed the way they are. I agree that some engineers don't know to turn a wrench which can be a problem but the manufacturers also aren't designing these cars so that a backyard mechanic can easily work on it 10 years from now.
A good reason for not using lubrication when tightening bolts in the factory is that you can get wide variability in the friction values on the threads depending on how the lubrication is applied. They design for how much tension is in the bolt but they can only measure torque applied so if your friction is an unreliable value you don't get the desired tension.
fflintstone
MOFnowhere Mi.
I use it everywhere that Loctite is not specked; the general rule of thumb is 10% less torque for lube.
Anyone that doesn’t want to anti seize lug nuts can go change their wife’s flat tire at midnight in the rain.
y20dth
Antwerp, Belgium
Anti-seize does not cause nut/Bolt connections to come loose, threads to lengten or break.
No matter what the Internet says.
ssentt
Iowa
My OCD prevents me, even with cotter pins present and I know its not gonna come loose. One less worry I have. OCD is not my friend. :eyecrazy:
Skin
Boston
Entirely false. Anyone in rust country who doesnt put a dab on the lugs and a ring on the hub where the wheel contacts is simply making their job harder. I know many guys in shops who have worked for decades and do it on every vehicle. Never once have i heard of a comeback for a wheel falling off that was properly torqued, anti-seize or no anti-seize. Sadly there are also a lot of shops that dont use it on anything.
A lot of people dont torque them far enough. Caliper bracket bolts on passanger vehicles are generally in the ~50-60 foot pound range. Not "just snug".
Not quite correct. Any lubricant is absolutely going to increase the amount of bolt stretch before a desired torque is reached.
sberry
Brethren, Michigan
Why go thru this when a drop or 2 of oil will solve the problems? How hard can it be?
Adam.C
http://www.permatex.com/resources/faqs/answers/5-lubricants
"Does Permatex® suggest applying anti-seize to lubricate lug nuts when installing or tightening the nuts?
Permatex® does not recommend the use of any anti-seize product on wheel studs. Many people have used anti-seize for this applications, however, there is the potential for over-torqueing and therefore, higher clamp loads and potentially dangerous bolt stretch. Because of the lubricity of anti-seize, there is a tendency to over-tighten because of the ease with which the nut will bear down on the lug. For this reason, even if you try to torque the nuts to factory specs, the clamp load may become too high depending on the type of bolt, size and manufacturer."
An engineering text book I read quoted a study done which proved this theory incorrect. In the experiment, dry and lubed fasteners were torqued and their preload measured with strain gages. The average preload of all fastener was the same for dry and lubed, but the lubed fasteners varied less.
The reason was offered that a dry fastener has a higher static friction and that higher torques are required to get it moving. Once moving the higher torque required to get it moving can cause it to be over torqued. If you are ratcheting the torque wrench it is also possible to undertorque the dry fastener when the torque applied meets the wrench's setting, but the fastener doesn't move. Again, due to higher static friction. This conjures a stuck, spin, stuck action.
In aerospace, all flight critical fasteners are lubed and torqued lubed. I think that tells you something. I also believe the higher torques published for dry fasteners reflects the case I mentioned above wherein by happenstance the fastener is under it's preload reqt, but the torque wrench reads good due to static friction. In this case a higher torque value would be conservative. It doesn't indicate (as many believe) that kinetic friction of dry fasteners is simply higher and therefore more torque needs to be applied to achieve the same preload as a lubed fastener.
As a senior aerospace engineer myself, I feel comfortable using anti-seize on my cars' lug nuts and bolts and recommend the practice.
Hawk321
Germany
Anti seize is the tool to prevent broken diesel glow plugs and seized injectors. I use it almost on everything too - except lug nuts-
I don't use it on cilinderhead bolts, those fasteners get some oil...
At work I got trouble for using it all the time (co workers dont know what it is) I put it on those lil' ABS screws.
Another great application are spindles from hyrdaulic tools or suspension compressor tools....much more power and no worn threads
Same with my ratchets, clean the guts and than some AS...so smoothy!!!!
