Permatex® does not recommend the use of any anti-seize product on wheel studs. Many people have used anti-seize for this applications, however, there is the potential for over-torqueing and therefore, higher clamp loads and potentially dangerous bolt stretch. Because of the lubricity of anti-seize, there is a tendency to over-tighten because of the ease with which the nut will bear down on the lug. For this reason, even if you try to torque the nuts to factory specs, the clamp load may become too high depending on the type of bolt, size and manufacturer."
Written by a lawyer.
I use it sparingly on the threads of wheel studs and lug bolts. I DO NOT apply it to the conical or spherical faces of the lug or wheel. The bulk of the frictional force should be coming from that interface if everything else is working properly.
In the rust belt LOOSE lugs caused by insufficient tightening are vastly more common than broken studs caused by overtightening. The torque spec is utterly meaningless if the threads are binding/galling/etc due to loss of plating on the fasteners. Since the chances of shops replacing damaged studs that aren't completely broken are approximately zero, I'd rather have them on tight than loose.
