bunks-tj
it looks amazing
Thanks - it does. I don't have the same angst I did when the wind came through last night, that's for sure!First of... Congrats!! Must feel good to finally get to this point..
That looks very nice - is it real stone or concrete? I guess I just have to price the stuff out, my goal is to have a 12-8" exposure, so I should not need more than 110 sq ft.As to the foam, I went with the stone veneer.. worth it in my book to cover the concrete, I wanted it to have a field stone foundation look and it really finished it off. Something to consider down the road.. Now I'll just get some popcorn and watch you tackle the electrical with the same incredible detail you've given the exterior of this very cool barn!
I would take a look at PVC conduit, even inside the house, its just a little floppier than EMT but is very easy to install.
Conduit bigger than you intend to use, i would recommend 2". That way you can easily run large conductors without worrying about the tight bends inside of LBs. And small conductors fit just fine as well. I'd glue up sweeps underground and only use gasketed conduit bodies like LB/LR/LL/C/T above ground. So you are going to have some radii.
Like Mike recommends I'd go for a 100 or 125A panel, usually the box stores have a package of panel + some breakers. Square D QO is a high quality panel in my opinion. You can feed that with a 60A service for now, the potential is there to upgrade later if you want.
Either blue or purple line should work, I'd add a pull-rope as you build the conduit, it will be easier to pull either the fish tape or the wires themselves.
I also recommend a 2nd conduit for low voltage stuff, Cat 5 would be highest on my list, you can easily setup a parent-child setup using an old router to have fast Wifi in your shop. I just use an "old" router that still functions but goes crazy when 4 devices connect to it. But out in the shop its usually just me or my Dad.
I'm not a contractor and would be working on my own project, in the good old US of A, where freedom... ah nevermind.I believe that after this Friday, MI contractors are being hit with $1K a day fine if they continue to work on non-critical projects as well. I know my buddy near Holland is being impacted. He's having a shop built right now.
Steel. Why... longevity. I would have opted for a premium vinyl, but at that point the price was negligible compared to the longevity I hope to get out of it. My only real concern is chalking, and that, well, I'll live with if it happens.HI,
I have scanned your posts but can't find mention to what siding you chose and why. It's steel siding, correct?
In all seriousness, I'm pretty sure I could go down to Menards and buy some PVC, wire, and safely work on this part of the project without much fuss, I'm in a rural area.
I had toyed with the idea - but since I'm just going to do a sub off the house, and planning on trenching on the side of the house that doesn't have a sidewalk, the task was made much easier. Plus, even though I am able to work from home, I have some extra time on my hands.Ah, I thought you were going to hire an electrician for part of the job...
Just read through the whole thread, very cool project!
Maybe I missed it but why are you putting insulation on the outside of the building vs the inside cavities?
Sounds like you are getting close to having the planets align!
Having lights, outlets and fast wired Enet is a great thing![]()
HehPerfection is the enemy of good enough. I figured you would have learned that over the course of this build![]()
