Dr_Clyde's Shop Projects
NASTYZEN
St-Colomban,Que. Canada
A bit late to this. First off, you ****!:) Nice piece of equipment.
I would paint then machine. That's what they do with castings around here.
If you could make the table height adjustable. Only needs 1/2' or so to precisely match to your other table. floors are always uneven. At least mine are.
sberry
Brethren, Michigan
Good idea to sand it. Keeps spatter from sticking so bad after blast. I bet you can come up with something doesn't need bracing with 6 inch legs. I see it has heavy legs, sand and paint a little. I would skip the grind also,,, whats it really going to do for it?
D
dr_clyde
Holland, MI
It doesn't NEED grinding for what I plan to do with it, but it would be a nice, fresh surface that will be good for many years to come. Its for sure more of a want than a need. Like I said, I'll probably just smooth it out with the DA for now and run it. Maybe when I move to my next shop will be a good time to grind it.
As far as the legs, it doesn't need bracing for stability but for shelving underneath and tooling storage. I also want to incorporate catch pans for spatter, grit and whatever falls through the holes.
D
dr_clyde
Holland, MI
Here's an interesting repair I helped with last night.
A good friend has a machine shop, one of the best in his area. Because he will deal with the walk in work, he gets a lot of farmers, excavators, and other small time repair work. They've got some good welders on staff, but they asked me for my help on this one.
This Case backhoe had a pivot boss shear off. There is a pipe connecting the two sides of the front bucket arms going through the hydraulic tank on one side and the diesel tank on the other. The tanks are part of the chassis and not removable.
The bearing boss on on one side had broke loose from the pipe inside the diesel tank, and then cracked the outside of the tank right around the weld due to the forces from the loader arm.
My buddy's shop machined a sleeved bearing boss that would slide inside the existing pipe, as well as a new flange to seal up the tank.
We had to weld the new boss into the pipe, and then slip the flange over the boss and weld that to both the tank wall and the boss.
The inner pipe weld was grooved out, and had 4 passes with 70S-2, and the outer plate and boss welds were each 2 pass welds with 70S-2.
We chose to TIG this repair for a couple reasons. First, there was some seriously tight fits between the weld and the tank wall, as well as up against the cab. No way a MIG gun was fitting in there, and a stick weld would have been quite difficult as well. I would have had to bend and contort the electrode to fit in a very tight gap that I couldn't see. The flange weld was a lot more roomy, but still kind of snug up against the cab. TIG was the easy way in this instance. We already had pulled a window, we didn't want to pull the cab.
Second, we didn't want any spatter or slag getting into the tank to cause problems down the line. This backhoe is owned by a guy who takes the utmost care of his machines. This thing is like, 30 years old and still looks fantastic. He made a point to have us try not to scratch the paint or get spatter on the windows.
Looks pretty straightforward, but I'm here to tell you, that was a bit of a tricky weld on the bottom side of that pivot boss with the torch jammed up inside the tank and my head wedged inside the cab.
My buddy did a great job on the machine work, that outer flange has an angled bore, so the plate lays flat on the tapered fuel tank and still fits snug up on the pivot boss.
Yeah, most real heavy equipment repair guys could probably have gotten this done with 7018 upside down in a mud hole out in the oil patch with one hand or whatever, but this is what the customer wanted and they are happy with the results.
Thanks for looking.
jeepinerdeep
South Central PA
I mean the repair is outstanding and everything, but where did you find an old case without 1/2 of grease and 20 year old mud stuck all over it?
D
dr_clyde
Holland, MI
I kid you not, this guy was legit concerned about weld spatter on excavating equipment. He's still using equipment his dad bought new in the 60s.
His stuff is almost museum quality. He kicks out a lot of work, but takes really, really good care of his machines.
lis2323
Which is why he takes his stuff to you.....
zmotorsports
Northern Utah
I like him already. :thumbup:
Agreed. Properly maintained equipment by an **** owner deserves to have the repairs done by an **** welder/fabricator. And I mean that with the utmost respect.:beer:
rvieceli
Illinois
Really outstanding work.
Truly surprised you didn't figure out a way to lay the thing on its side so you could weld it flat instead of vertical. :lol_hitti
Ron
D
dr_clyde
Holland, MI
Table update!
We got the base fabbed up finally. We've been waiting on both time and availability. Took forever to find the free time and have a free table top. I've been very busy, so my helper Ben did a lot of this welding.
First thing we did was cut off the existing legs. They were made from 8" x 1" thick angle iron. Heavy stuff. I wanted to re-use the existing mounting holes, and provide enough of a space for the tray slides. The old DoAll C69 made easy work of cutting these off.
We fabbed the base out of drops and leftovers from around the shop. We only bought laser cut feet plates, leveling pads and nuts. I bought 1"-8 swivel leveling pads from McMaster, good to 20K lbs each. Overkill, yes but I wanted the 4" dia foot pad. And they're pretty inexpensive. I wanted the ones that were 6" pads, but I couldn't justify over twice the price.
Here you can see the slide ways for the trays. I haven't built the trays or the lower shelves yet. My plan is to have 4 trays each covering 1/4" of the top. That will help catch any detritus that falls through the holes. Nothing fancy, but I saw Bellaireroad had done something similar and I liked the idea.
I plan to paint the table, so I made up this copper ground pad for a good place to clip ground clamps. I will just paint, then loosen the bolt and slip it back in between the washers again.
I discovered something cool about these StrongHand sliding bar clamps. They have a spring loaded clip to easily flip the dynamic arm. If you remove the dynamic arm, they can slip in any hole on the table. This allows you to get the body of the clamp down far enough to slip the clamp leg around where you need in the webbing. Then you just pop the arm back on and you can clamp anywhere. I probably will still buy a few drop in clamps, but these work for most things and I can double up and use them other places too. Win/win.
Next up is paint, trays and bottom shelves. I may weld a few more tubes under the shelves for belt and suspenders to keep from sagging. Easy to do now, hard later.
Hoping to have paint on it in the next few weeks. I have the paint, just have to schedule with my buddy who has a paint booth a few doors down.
Then I probably will get the top ground. Even after a little smoothing, weld spatter sticks really bad, and I really hate that. Hopefully we can find the time soon.
y'sguy
Tulsa, Oklahoma
Awesome skills. Can't wait to see how the table finishes out. I am also very surprised to hear that the weld spatter is sticking to it?
Bellaireroad
Fort Worth
Same here, it will fuse but not penetrate, pops off easy with a flat edge. I just douche up the top with some ceramic spatter guard.... lasts a long time. no problems with grounding through it either...I have my ground on a corner like the good Doc
lis2323
I use these two anti spatters
The Bio Circle by Walter is my fave.
D
dr_clyde
Holland, MI
Hey guys,
Been a while since any updates, I apologize.
Anyway, here's a fun one that ran through the shop this last week.
14" Sch. 120 steel pipe had to be welded into a 3.75" thick steel square flange. There was a 3/4" groove weld on the face that took about 5 passes or so, and the fillet weld took 10 passes with .045" wire on the Millermatic 350P. We had 2 of these to do.
I was running it flat out for the groove weld, 500 ipm synergic pulse spray. For the fillets we could turn it down a bit, running 340 ish ipm synergic pulse. All done with .045" wire.
Heavy sons of *******, the pipe alone weighs about 1000 lbs, and the flanges added several hundred pounds.
The rotary table is an old 20" Troyke, with a homebrew Leeson variable drive. My buddy bought it at auction for $60 and loaned it to me, as my positoner is only good for 75 lbs or so. I could prop my gun hand on a bar clamped to the table and switch on or off the table and adjust the speed with my other hand.
The controller, simple to use and easy to operate with gloves on.
This was pass 4. This welder is sooooo nice for this kind of work. Put some big wire in and let the big dog eat.
6 passes in. These get wire wheeled in between every pass.
All 10 passes in. I am able to make a half turn before I have to stop and reposition my ground clamp, as I can't ground through the table on this rotatry table, seeing as how it was intended to be used for machining and not welding.
All done. Pretty straightforward weld job, but it takes a bit to handle it. Need a forklift and a pretty good welder, minimum.
More to come soon, hoping to splash some paint on the Acorn table this weekend if the weather cooperates.
Strouty
Southern Maine
Great idea for a rotary table, welds look great. I don't weld things that thick, so it is always neat to see it being done.
What color is the acorn table going to be, pink?
D
dr_clyde
Holland, MI
Pink would definitely be eye catching.
I'm probably going with boring old machine grey because I happen to have some leftover expensive industrial paint in that color.
I will probably put the blue stripe around the top lip like my plate table so they match.
Strouty
Southern Maine
Need to know basis and you don't need to know.....
I think making them match is definitely the best route. I like machine/battleship gray, that is what I usually paint my rims on trucks, except I mix my own from black and white rustoleum, I always seem to have those colors, but I never buy gray.
D
dr_clyde
Holland, MI
Very nice. What was the application for that pipe?
Customer picked these up a few hours ago, I asked him what they are for. These are for large injection molding machines, and these are the tubes that hold the molten material as it is pressed in to the mold. So basically, these are like super heavy duty syringes for molten plastic.
Opa
placerville, ca
beautiful welds. i am new to welding. just curious, did you stagger your starts and stops so they aren't all in the same area? or does it matter?
Craftfab
Garage
Very cool. Thanks. Always enjoy your shop updates.
