lilscorpion
I haven’t even cycled the suspension and I’ve identified a few problems with the orientation of the lower shock mount I’ll need to address before I can. First, the way the mid-arms cycle the diff create a subtle clearance issue for the coil spring and the coil bucket at ride height.
Second, the shock sits almost perpendicular to the ground in all regards at ride height which is ok, but not ideal. I’d prefer to have the coils angled slightly out at the bottom so that when the suspension cycles, they never are angled in. Doing so aids in stability on the trail.
These are lower shock brackets that came with the Evo kit. They’re to convert the stock shock mounts to double sheer. Think I can tweak and use them.
Modified the brackets so they’d fit the tube
Added a few brakes so they’d tuck up along side the original shock mounts.
With a little trimming, it now lays up against the knuckle nicely. Now the shock mount will be in triple sheer.
Burned it home with a stack of dimes.
Now the shock can outboard 2” correcting the geometry issue. In its furthest outboard position it’s about 1/2” award fro the caliper. Perfect.
