Above 1200 Sq/FT Garage Refurb®
kngkong
Wellington, New Zealand
Youre Nutts!
Man, Ive been subscribed for a while but spent some of yesterday and today reading all 20 pages. What a great build and thanks for documenting everything so well. Soup to nuts lots of great ideas I can use.
Cheers!
N
NUTTSGT
Northern Central Ohio
Re: garage refurb
Thanks for the kind words my friends. I'd like to get more done but not I have weather constraints, a non-existant funds and a few other matters to halt my project. Hopefully things will get better in the Spring and I can go back at it.
cbharis
Re: garage refurb
Very nice job! Just took a couple hours to read through your thread. Nice job and nice ideas for my building too! :)
SpeedinLemon
North Texas
Re: garage refurb
Hey Nutts - This is one of those threads that should never be far from the top of the list. Great work! I really like the workbench and how you've improved but still kept the original flavor of your building. I've had more than my share of contact with men in your profession lately and just want to thank you guys for doing what you do. Any progress lately or are you snowed in?
N
NUTTSGT
Re: garage refurb
Thanks guys, no progress lately as winter moved in. Well you could call it winter by the time of year but snowed in, nope no way. Today Feb 1st, it's 47° and raining.
Things have not been going well for our city right now, money is real tight. We have 2 Fire Fighters laid off, we are taking comp time in lieu of cash for OT worked and no holiday pay (more comp time). Working on the garage comes from extra cash from working OT. It's not there ($$)so I'm on hold and not sure when I can start back on the siding. I do have some siding but there's few other things than need done prior to continuing.
SpeedinLemon
North Texas
Re: garage refurb
Its a shame that you guys that provide such a valuable service to the community seem to be the first to be affected by budget shortfalls. Hang in there and I'll keep watching for updates.
Jimh77
Re: garage refurb
Eric, man the things you have done with that property all around is nothing short of amazing!! I ran across this thread while researching something elseand got so caught up in reading this I had to subscribe to keep reading it till the end. So sorry to hear about your Station issues. Seems the most important things are those that get cut supporting our communities. Hopefully things will get better soon and you can finish the garage project.
N
NUTTSGT
Re: garage refurb
Thanks guys. Hopefully if the weather holds out, I can do a few things this Spring. I still have some siding left and things I can work on. One thing I did get done was removing what was left og the gas pump island out front. The thing was almost an eyesore to me. I still need some more stone to put down but I'm waiting for it to get packed down a bit more from driving on it.
FWIW, I screwed up when I said we have two guys laid off. We have 3 guys laid off and another that went active duty (from the Nat Guard) to try and save one job. Luckily, one of the laid off guys got hired by his previous employer and another guy got hired by a neighboring city, one that we have mutual aid with. Things are looking grim for us in the city and I'm not sure what the future holds. I'm going to advise the guy that went to GFD, not to come back but to stay there. I believe he has more job security there and ***** to lose a guy that you consider a little brother.
In the mean time, I've had a project that I have been working on in the garage. It should be done this week and I can start with a little outside work. If it rains, I'm going to start painting the "wood project" side of the garage. It'll get a paint scheme to match the other side.
The project I'm working on.
http://www.garagejournal.com/forum/showthread.php?t=142836
N
NUTTSGT
Re: garage refurb
As you can tell from the rest of my thread, I have painted one side white over the previous gray. I keep realizing how dark the gray is on the other side. I've decided to do something about it. The problem is, now it's getting nice and I should be working outside not inside. I figure I can work on this as it rains.
Where I started last night after some progress. I thought maybe I should grab the camera.
Tonight after the first coat. I'll go back out and roll on a second coat.
You may think the white goes down farther than the other side, you're right it does. There is a reason for that but you won't see that till later.
N
NUTTSGT
Re: garage refurb
Moved some more stuff around and worked on the other end.
I get the blue stripe painted on tomorrow.
IONH
Central Massachusetts
Re: garage refurb
Wow, a radial arm saw! My dad has one of those in his basement and I remember him using it a ton when I was a kid. It's just had stuff piled on it for the last 15-20 years though.
Aside from having a larger work surface and closer to eye level, is there a benefit to using one over a compound slide miter saw? Though I guess larger work surface and eye level may be reason enough!
IONH
Re: garage refurb
N
NUTTSGT
Re: garage refurb
The advantage of the radial arm saw was that I paid $200 for it new because it was an older model found in the back during inventory versus the regular price of $500.
One nice thing you can do is cut dados fairly fast for some simple work. I've had it long enough that I just use it when I need it. Having a long wall for it to be placed against helps.
zuk123
Houston TX via Chicago, Phoenix, LA, and San Diego
Re: garage refurb
Great looking project, and a stunning amount of work! Reading thru the whole thread makes it seem as if it happened in one big push!
You might want to check out http://radialarmsawrecall.com/ if that is the Craftsman saw that it looks like. I didn't ever hear about the recall until last week on GJ. You type in your model number and they tell you if a retrofit kit is available. If not, they will give you $ to destroy your saw (which you can take or not.) Mine has the kit available, so I ordered it (free.) The instructions look pretty extensive, and it comes with a new table top. At the very least, you will know if your saw is 'extra special dangerous.'
FWIW, there are several threads on GJ debating radial arm safety, and correct usage. Personally, I rarely use mine, but having it set up for quick dados is probably the best use of it vs. a sliding compound.
Sorry to hear about the uncertainty at work. I'm always amazed that politicians start screaming about cuts to cops and fire service as soon as there are budget issues. They still seem to find the money for the guy who inspects beauty parlors and barbers, and all the 'commissions' and 'outreach' programs though.
Thank you for your service to your community and our country.
zuk
IONH
Re: garage refurb
Dado cuts, I would imagine those are much easier with a radial arm saw than it would be with a table saw as you can get a better look at your cut. Thanks for mentioning it.
N
NUTTSGT
Re: garage refurb
They make it really nice when you're cutting dados on some larger lumber like 4x4s or long boards.
Motown 454
Re: garage refurb
Glad to see your staying busy in the garage. It looks a lot brighter.
N
NUTTSGT
Re: garage refurb
It's unbelievable how much brighter it is from just changing a paint color. I need to paint a blue stripe on the rest of what I have painted and it will be done. Once that is done, I can put some stuff back on the walls and hang some new peg board.
N
NUTTSGT
Re: garage refurb
I finished painting today, adding the blue stripe to the walls.
by comparison, here's the old paint.
It is so much brighteron this side of the garage. I should have painted it when I did the other side.
N
NUTTSGT
Re: garage refurb
Tomorrow's project will be hanging new pegboardand trying to remember where all this **** went.
After that is done, I have to rip some 2x4 done to make some more trim. I'll slap some paint on it and hopefully get it up later on. Once that is done, I can hang the rest of my junk back up.
kngkong
Re: garage refurb
Thanks for all the updates, your build has been an inspiration. Really looking forward to seeing what you do next. Watching you pretty closely and taking notes, trying to steal as many of your ideas as possible. Cheers :bowdown:
N
NUTTSGT
Re: garage refurb
Thank you and feel free to steal any and every idea, even the bad ones. :lol:
N
NUTTSGT
Re: garage refurb
hopefully, the new pegboard is white for an even brighter work space!
Actually, it's still brown. I almost bought some white pegboard at HD. It was $18/sheet and 3/16" vs the stuff I bought at Menard's $11/sheet and 1/4".
For some reason, I prefer to have brown (normal) pegboard over the white. :dunno:
JC23
Northcoast
Re: garage refurb
No, no, no. You gots to think positive.
Now you get to make an even better layout for that stuff. New and improved!
Looking good! I jelly...
Motown 454
Re: garage refurb
That wall with the call boxes looks a lot better in white for sure.
N
NUTTSGT
Re: garage refurb
They do stand out more with the white. I also added a pull station to the wall that I picked up. I'm thinking of adding a small section of conduit (painted red) between the pull station and alarm box.
shopnut
Florida
Re: garage refurb
The new colors look better in there, for sure.
The little call boxes are pretty cool. I'm not sure if there is something in them anymore, but your mention of a conduit between them got me thinking (okay, you better run now!)... Maybe the conduit could actually be air line and you hide your air quick disconnects in there. Or maybe if you don't need compressed air in that room, it might be kinda cool to hide something garage-related in there like cordless tool chargers or something. Just a thought.
Keep up the good work.
Omphaloskeptic
Ultima Ratio, Wa.
Re: garage refurb
"The little call boxes are pretty cool. I'm not sure if there is something in them anymore, but your mention of a conduit between them got me thinking (okay, you better run now!)... Maybe the conduit could actually be air line and you hide your air quick disconnects in there. Or maybe if you don't need compressed air in that room, it might be kinda cool to hide something garage-related in there like cordless tool chargers or something. Just a thought."
^ What a genius idea!
jeffmoss26
Cleveland, Ohio
Re: garage refurb
I really like the fire alarm stuff! I have a bunch of pull stations and horn strobes wired up to a power supply in my shop, just for kicks. Nothing old like you have lol
N
NUTTSGT
Re: garage refurb
I have compressed air in and going through that room. I am gathering pieces to run new lines though. ;)
N
NUTTSGT
Re: garage refurb
The fire stuff keeps accumulating rather easily. One of the call boxes came from one of my neighbors from a plant he did work in, it was getting tossed. The other from another neighbor where he used to work, one of their old boxes. The extinguishers are mostly from another neighbor who comes across them, where ? I don't know.
The pull station came from our station that was getting trashed (no key for it) during a remodel. Once it's in the dumpster, it's fair game. The hydrant wrench, I can't remember where it came from. The spanner wrench came from one of the old retired guys who passed away about 18 months ago. I'll hold onto that one forever.
The Firefighter St sign came from my daughters. My step-dad made the frame for the calendar pic. It from Jan '05 when our new ladder truck was featured on a KME (manufacturer) calendar. :rocker:
I hung the wrenches up last night so they can't be seen in the pic. :sad:
motodavid2000
Florida and Ohio
Re: garage refurb
NUTTSGT -
I spend part of last evening & early this morning going through your complete thread. Great vision, planning & execution on the complete rehab / refurb of your garage & shop space. Really nice job and the results speak for themselves.
Also I love the Call Boxes on the wall - super character addition ! :thumbup:
Best regards - Dave
N
NUTTSGT
Re: garage refurb
I can get you a key for that pull station. Is it a notifier, fire lite, or? Can't see THAT well LOL
No need to worry about it, it has a screw to keep it shut and it for display now.
I took a better picture of the wall today, after the wrenches were hung up yesterday.
