Learning to WELD!
bczygan
DETROIT! Arsenal of Scrappers
Today was welding all day.
The morning was TIG class. Most of it taken up with the above project.
The instructor did give us our assignment for the final.
It is to be an inverted T shape, welded both sides attached to an inverted L shape with lap joints top and bottom. The L will have an outside corner joint.
We've been working in aluminum for most of the course. Very difficult. Very frustrating.
Have forgotten the little bit of steel we did at the start.
Thank goodness he gave us the choice to do aluminum OR steel.
This evening was a stick course I intended to use to finish the stick course where I didn't complete all the exercises in. But TIG has been so much fun and so challenging, I'v just been using it to get more TIG seat time, especially in aluminum.
So this evening I sat down with the intention of trying to get my steel TIG skills back up to snuff. I never really mastered them in the first place. My T joints were very sloppy, I couldn't do even a halfway decent lap, and hadn't even tried an outside corner.
But after all that aluminum work, the steel just seemed to flow. Really focused and just plodded through it, one thing after another until it was complete.
Not a great demonstration of skills, and I see all the mistakes. But it may be enough to pass the course.
Take a look and tell me what you think.
Bill
bczygan
Couple hints since your just learning.
1) cut your 36" rods in half. It will help you out a lot with hand feed control.
2) when you evaluate your weld quality, Look on the "back side" of the weld and notice your weld/heat penetration. When you start to improve you will notice a nice heat burn without "drop through" and skipped heat areas.
Hope that make sense!
On this thin aluminum, it's easy to burn through, so I'm trying to keep from doing that.
And I've found the full length rods to be no problem. The difficulty is essential tremors in both hands. I have to find ways to anchor them.
Bill
bczygan
I just realized I can weld things for myself!
Thinking back to last summer, I needed an L shaped bracket to attach the motor starter to the compressor. Didn't have anything L shaped.
So sheet metal is too thin. It will vibrate. But a couple of pieces of 3/32 or 1/8 welded into an L shape and drilled to mount the motor starter on, will do nicely!
Bill
ez-duzit
Marina del Rey
Never taken a class. Had an acquaintance give me a few pointers. Just bought the equipment and teaching myself through youtube videos and weldingweb.
Have a Miller Dynasty 200dx and Millermatic 211, Hypertherm 45xp.
NitroShark
Greenville, SC
l
adding "Rod" will cool the puddle and eliminate -burn through.
You will learn this as you progress.
Back off the heat or add rod. It's all about heat/puddle control.
Keep trying
gnpenning
I have more questions than answers.
Bill, I'm impressed you have gone after this as well as you have. You do need to get outlets for your welders and other power equipment. Practicing at home will be catching huge benefit.
As you mentioned you will be able to make parts and build things for yourself.
Craptain
Tampa Bay FL
Bill we all do the same thing, only showing the best. That's expected and OK. Generally only the instructors or close personal friends and family get to see the warts.
Now go fix up your shop and do it for real. Of course then you face the reality of paying fair price for consumables and materials.
Sent from my SM-G930T using Tapatalk
sberry
Brethren, Michigan
As noble as it to want to be a lifelong learner the goal might or should be to help with something you want to do. You get some exposure and now you shouldn't be scared of the machine, get the stuff around to plug in the wire feeder you have and make or fix a few things. All this **** is good to know especially if you are a career welder but you need to get comfy with a 120V Lincoln.
bczygan
That is fast becoming the plan. I want to get the steel TIG going. Gas, regulator, torch etc.
In January I start the MIG course. Going to run the 120V Lincoln to practice before that.
Today I fab-ed up 2 things. A weight for my 3rd hand and a bracket for the motor starter for my compressor. So great to feel confident that my welds are structurally sound, even though they could be prettier.
Bill
bczygan
The weight for the 3rd hand has 2 tabs that will get holes so the rod can go through them. This makes the weight movable and thus adjustable. Edges and corners will get rounded.
Bill
bczygan
The bracket is to mount on the end of my horizontal air compressor.
The narrow part will bolt to the top of the tank and the larger vertical portion will have the motor starter mounted on it. I may weld a small triangle on to keep it from vibrating. Need to drill holes and round edges and corners and paint it.
Bill
bczygan
Bill
Looked at the bracket and determined it needs reinforcing to keep the vertical piece from vibrating. It will require a hole to route conduit for wiring.
Bill
bczygan
Showed my final project to the instructor. He said it was a C+.
So I did another one. 3/32 instead of 1/8. Ran a little hot but it looks like this:
Bill
Bigblue&Goldie
Bill
If there's 2 things I remember from college it's "C's get degrees" and "push the puddle"!:beer:
bczygan
Today I finished welding up a bracket for my motor controller, so I could mount it on the horizontal compressor. Welds came out better and more uniform and smaller than ever. And tacks are nice and small and don't burn through. The pedal is my friend.
Bill
bczygan
Final session of Stick class.
I've been using the session of that class to do TIG work, since I like it so much.
But to get credit for the stick class I needed to do the final assignment, coupons with bend tests.
Now understand that I missed the first 4 sessions of this fast track class.
And also that I never really got the hang of whip and pause, which is needed for the root pass.
So this evening, I decided to try it anyway. Did a practice whip and pause and then went straight to the coupons. The TIG class sure helped me run straighter beads in stick. Attached you will see the root pass and first cover pass. I finished it and cut samples.
The root pass failed, but the cover side didn't.
But I passed the class!
One more session in the lab on Monday and the done with school until January.
Bill
bczygan
This morning was my last chance to get in the welding lab.
Ran ten 6" beads on T joints.
Here's my last and best. They're getting pretty uniform. Critique?
Bill
Bigblue&Goldie
Looking a lot better. It's hard to tell, but it appears you were welding really hot. I'd make sure you have good gas coverage and bare, shiny metal (makes life waaayyy easier). Tig welding is all about the prep.
bczygan
Was welding hot but used pulse to keep things from overheating. 1/2 sec. pulse, 75%, 95 high, 75 background.
Just ground the areas where weld would go.
Bill
bczygan
A new development on the welding front.
I've been wanting to get TIG capability here at home, ever since I discovered how much I like it in class.
So I bought a pedal for the Lincoln Invertec V275S. And I have an empty tank, out of date tank, I can exchange and get filled with argon. Still need a flow regulator and torch. Doing all that would still only give me steel TIG, not aluminum.
I would really love to have a Miller Dynasty 200DX like I used at school, but prices are high for those. A pretty well used one is on CL for $2,200.
So I've looked at the imports. AHP, Everlast, Eastwood, ESAB etc.
I really want HF and pulse. I wanted all digital controls, like the Dynasty, but that makes the Eastwood one almost a grand. The big old transformer monsters are out of the question because of size and electricity cost.
The AHP has been one I've focused on for a while. Usually it is an order in advance and wait for the shipment to come in deal. $749 plus $30 shipping. 3 year warranty.
This morning I did my daily CL search for welders and expanded the search to 200 miles.
Up popped an AHP, bought a year ago and never plugged in. But 2 1/2 hours away in Grand Rapids.....
$600!!!
I'm picking it up a week from Sunday!
Bill
joe49
Tonica, Il
I would want to test any equipment bought used. More so if it has 5 hours of driving involved.
bczygan
Note:
Just found out I got all A's in the 4 courses completed so far.
74855 ABT 101 501 Introduction to Auto Body Technology Eastern A
76717 AUT 101 101 Automotive Fundamentals Downriver A
70803 WLT 101 501 ARC/Oxygen-Acetylene Welding Eastern A
73021 WLT 103 502 GAS TUNGSTEN ARC WELDING (GTAW) Eastern A
So 4.0 GPA.
17 credit hours completed and signed up for 12 more next semester.
Will be taking Steering and Suspension I, MIG/FLUX-CORE/Plasma Welding and Surface Preparation & Fillers.
Bill
bczygan
Big news.
The welder I mentioned above.......is on it's way.
I was supposed to pick it up this coming Sunday, but the trip would be 2 1/2 hours each way, so I called the owner and asked if he would ship it. He said some relatives from Ann Arbor were coming for Christmas and they could take it and I could pick it up there.
Then he called back and said they didn't want to do that for fear of the unknown.
So he suggested taking it to a pack and ship. I agreed. Cost $102 insured and sent FedEx. I'll have it tomorrow or Friday. Still saved $80 off new, and it is virtually new.
I had been waffling and thinking I should just wait, but Millers and Lincolns would cost considerably more, even used. So now I'm all in.
Merry Christmas to me!
Bill
xman_charl
have been using my AHP for several years
got a lot of features miller and Lincoln, have
stick welding is lacking 3 main features, hot start, **,***
use another welder for stick only, AHP does stick weld, but..
Charl
bczygan
Charl
I have 3 other welders that can do stick.
HF AC/DC ARC180
Lincoln AC/DC Tombstone
So I'm covered!
Bill
bczygan
I am just curious, have any of the 3 other machines been plugged in?
Correction.......4 machines.
HF AC/DC ARC180 - New, never had a plug on it. Got it free
Lincoln AC/DC Tombstone - No $70
Lincoln Invertec V275S - Ran a bad bead before I took a class $100
Lincoln 3200HD MIG - Ran a bad bead before I took a class $175
I would like to sell or give the HF to a family member and sell the Tombstone.
And upgrade the MIG to a 240V machine.
Bill
