I installed mine over Thanksgiving, and have used it a couple of times for small projects since then. My observations:
- There are a couple of minor errors in the manual that would be easy to fix. They should fix them.
- I had very uneven lifting on the first couple of attempts (4-6"). Another couple of bleeds, particularly going all the way to the lift maxes out and things seem fine now. I will say I cavatated the pump when first installed due to a lack of fluid. As others have said it takes a couple of quarts more than the manual lists
- No leaks so far, but I added more teflon tape to what was included on the fittings
- I should have put the posts further apart. I have a narrow 2 car so was trying to minimize width. I have it set so the arms are barely extended to reach the jack points on my E46 M3, and E36. With the car on the lift getting into the doors is not practical. Not an issue parking as I can park closer to the garage door, which allows the doors to open further. That is a mistake I may fix by drilling another set of holes further out. I am at 131" out-to-out, which seems like way too much for a BMW sedan when reading the instructions. At the recommended 110-120, I'd never get the doors open, and I'm not even sure the pickup points would work.
- One of my arms will not slide out in and in with beating on it. It appears to be some weld slag just inside from the end. Assuming the arms slide all the way out out of the carrier this should be a 1 minute fix with the die-grinder. Just haven't got to it yet
All in all, don't know how I lived without one
A couple of questions:
The hoses are annoying with the pump located in front of the engine bay. Has anyone located the pump to one side and drove over the hoses each time they pulled in?
For those who ran the hoses over-head, did you get new hoses? The hoses don't appear long enough to go up and over.
