WHY are you buying a vice, when Irwin advertises a "Limited Lifetime Warranty" on their vices?
Example:
Heavy Duty Workshop Vises
With a 6" jaw width, the IRWIN Heavy-Duty Workshop Vise features a captured safety jaw to prevent the slide from falling out during use. At a solid 30.6 lbs., this anvil and pipe jaw incorporated table vise maneuvers quickly into position with a swivel base. An aggressive set of steel jaws...www.irwintools.com
This should answer you better:
So yes, they're replacing it, but it'll be two weeks before I get it, and it will still be the same model vise that didn't stand up to my use case anyway.
I think Project Farm did a vice comparison earlier this year. It was interesting, or maybe entertaining at least, but I don’t recall the conclusion. I’m not in the market.
The conclusion was that he endorsed the Harbor Freight vise. Some of the other vises were better in various ways, but the HF vise performed far better than he expected at its modest price point. The PF video was actually why I went looking at HF in the first place.
Edit: Here is what he said in his conclusion. "I have to admit I'm pretty impressed with the Harbor Freight Central Forge when you consider the value price of under $80. I also like the Heuer quite a bit, but $500 is quite a bit more." Here is how he ranked the results (lower scores are better):
I broke what I think was a grey iron vice. It let go with a loud bang. There’s a tremendous amount of energy stored in a vice that’s really cranked down. I suspect that one of the primary failure modes on some of the PF vices was bent handles… the handle bende to keep the vice body from literally exploding and hurting the user / abuser.
One advantage of ductile iron over cast iron is that it yields instead of violently fracturing with energy release. Other is 60,000 PSI versus 25-30 ,000 of cast iron. As for handles bending, the original Record brand of vises made in England were designed for the handle to bend before vise limits exceeded.
Mine just let go with a quiet little thump, and popped open about an inch. Not violent at all. So I'm guessing the fracture must have been gradual instead of catastrophic.
