Pliers; How Many Is Too Many?
LesserSon
PA USA
OH! I didn't know you had a collection! I think I may have one of those here somewhere.
Thanks for sending me a fifth pair! Still no dupes. Alloy Artifacts had one pair shown on their Globemaster entry. I checked their guess of Footprint or Gordon as the Sheffield manufacturer, but none of what I’ve seen matches a grip pattern, nor, I think, the model numbers.
Mintgrun
Kingston, Wa.
The tips of the jaws are interesting on those. I was wondering if someone had ground one down, but an image search showed another pair with one fatter shorter tip. I wonder what the offset tips are for.
GaryM909
Calgary, Alberta, Canada
I have Craftsman pliers from Japan. Same type of jaws
Jgaz
One old pair of hose clamp pliers on the right that my dad had from the early 50’s.
He repaired and installed automatic washing machines.
The pliers on the left are used for coiling the wire ends of heater and A/C blend doors.
I made a ton of money with these.
Customer comes in with a broken cable. I would remove the broken wire cable, cut new wire to length, leave the plastic outer casing in place, slide a new wire down the casing, and wind a new coil on both ends.
I very seriously doubt those were made by Gordon or Footprint. We've emailed back and forth on this one.
Looks like there's only one decent photo of any Gordon pliers HERE, and they appear to have smooth handles (although they are a completely different type of pliers than any of your examples.)
We know Globemaster was outsourcing stuff from Britain, and Sheffield would have been the go-to place for an importer.
Are there no examples of a Globemaster-branded specimen having the same handle pattern (other than the pair on AA's site?)Or did I miss something?
The "Globemaster" on AA's page has nothing to do with "Worldwide Tools" out of Sheffield, England. The original "Globemaster" has been defunct for decades, so the name was up for grabs, I guess. :dunno:
I cleaned up these pliers I found on Saturday. No indication of manufacturer, just a part number, HR-1107. I imagine that someone will recognize the handle pattern.IMG_0852.jpeg
IMG_0853.jpegIMG_0854.jpeg-Don
cody1325
Southwest Virginia
I found these US made snap ring pliers yesterday at an estate sale. IMG_0420.jpegIMG_0421.jpegI can’t find any brand markings even after cleaning.IMG_0433.jpegIMG_0434.jpeg
I have a pair of Blue Points that are somewhat similar. The brand markings are on the grips, thus prone to wear off. Gramps didn't use them much, and they only come out when I need to disassemble a ratchet that uses snap rings--thus they look pretty much new. Not so much these days, given my main go-tos are old Proto pear-heaads or the various Facom derivatives (mainly, SK Tuff-1).
oldpliers1
Found these yesterday circa 1995
Mintgrun
Kingston, Wa.
I pulled these pliers out of a scrap metal bin the other day. The top pair have the classic CeeTee checker-dot grips and I was surprised to see an unfamiliar brand when I cleaned the heavy rust off. ROYAL VALUE E 26. That brand isn't even on @four.cycle 's list! It sounds like an 'overseas' name, but they're marked MADE IN USA on the other side. By Crescent, I assume.
The <DIAMOND> K 36 pliers cleaned up well. They looked rusty, but it rubbed off with LAVA soap and a toothbrush. The upper pair took a swim in the electrolysis bucket.
Lesserstore
Texas
The part number is Western Auto, and the handle pattern is Pendleton Tool with a date code forged into the handle as well.
Can you post another example of the handle pattern? I looked at a large selection of Pendleton pliers and couldn’t find a match. The part number does seem like it could be Western Auto though.
Lesserstore
Texas
Yeah, I looked at mine and they don't have those two outer chevrons. And the jaws look wider on yours as well.
I did find them in a Western Auto catalog, but the style doesn't match.1000004568.jpg
Yeah, that is pretty much the same thing I came up with.
I found a few pliers at today’s estate sale. My wite spotted the Ford marked pliers.IMG_0875.jpeg
Xcelite pliers with what looks like the Crescent handle pattern.IMG_0880.jpeg
Eric Brown
Patented by Francis Stallings, Effingham Illinois, #1498488 (June 17, 1924) it has three jaws that all open/close at the same time. My pictures show both sides, open and closed. The two sides seem identical, lowering cost to make. This one has no markings. Works smoothly.
Attachments​
Very cool, Eric! DATAMP page entry on that unit linked here...
Mike'smeatshop
Attachments​
Another very cool project. Don't get dirty going down the rabbit hole.🤞
Eric Brown
Here are a couple of buttonhole pliers. Top one is a Wiss, the bottom one is simply marked DRGM (Germany). Both seem well constructed, but the adjustments are different. Also shown are Heaton pliers for attaching the Heaton button. There were a handful of different patents for this type of plier, this one is the 1880 model. Strange, but have not found buttons for these pliers.
Eric Brown
Bernard parallel jaw plies for leather belting used on machinery. Looks like it cuts a 1/2" belt and then punches a hole in the end for splicing. This one is model 119-6. Also shown is a bronze pliers that seem similar to the Bernard but oddly it cuts a 1/4" slot lengthwise about 3/8" long. It also looks like it can crimp. Only marking is Pat Pend.
Sometimes I stumble on an answer to my own question. I was going through my box of offshore or missing COO tools sold by Sears and spotted a familiar handle pattern on these Companion brand 3072 Japan marked water pump pliers. IMG_0960.jpegIMG_0959.jpeg
Eric Brown
Not sure about these. Marked "CCS Co". Have not seen another pair like them. They use a cam to close the jaws, giving them great power. The jaws are smooth and are 1/2" wide and 1/2" deep. When "closed", the jaws are still open and parallel, with about a .04" gap. So, were they used to crimp something or perhaps to pull sheet metal? Bend a tab?
Interesting, the internet reports two sizes, or someone can’t measure. At least one eBay listings at 5”, but Great Plains has them listed at 7”, item 115, and one other w a tape measure in pic is close.
Eric Brown
Thanks. Mine is a little different in that it doesn't have the extra eye on the handle. I looked closely and it doesn't look like it was cut off. One of them on E-Bay does look larger and has a number 2 on the side.
Eric Brown
Utica "Made to Order" no 269. Not sure if these cut, crimped, or maybe both. They look like a tool that was used in an industrial setting. Very smooth action.
Eric Brown
Another unusual pair of locking pliers. These are unmarked. Did not see in the Cope American Wrench Makers book or on this plier's thread.
Any thoughts?
Love that they say "Made to Order", no flipping thru catalogs trying to find them.
Eric Brown
Just did a E-Bay search and found another pair similar. They have the same model number of 269 B but say "Custom made". They also have a different end, looking more like short needle nose. So probably the 269 was a basic starting point. I am trying to contact Utica, but don't have high hopes of a response. Most companies are concerned with new sales and not history.
ararat
Ararat NC
Screenshot_20250305_130210_Chrome.jpgthis site is calling them watchmakers pliers
Coming back to these, wondering about other pulling pliers like linesman for fish tapes, or for pulling the metal or plastic banding tape. 0.04 seems pretty thin, and don't have any linesman's here to check anyways
Also, what about holding a feeler gauge for inserting somewhere?
If you put a piece of a beverage of choice container in the jaws and squeeze, what happens. If smaller than the jaws it holds, if larger, I'm assuming no cutting or cramping too, but just thinking will my process is warming up here.
