The landing gear ratchet reminds me of this one.
http://www.garagejournal.com/forum/showthread.php?t=207554
I would guess that the shank is inserted from the front, and the cap from the rear, but there is only one way for you to find out...
One issue I'm having and it is only because I'm fairly **** (understatement) is that I want complete set with all 3 drive sizes. I think this handle on a 1/4" will be a bit much.
so sacrifice a smaller driver
Just got back from HF with a new 1/4" stubby and put on a Craftsman p3 handle.
With all the interesting handled ratchets poping up lately it was mentioned that a thread was needed to showcase them all in one place.
You might see some real bastardizations in here so beware.
I'll start with a few I did.
Excelite/American Forge
Fuller/Gray Canada
These have all been done by other members
If any of these are your ratchets please repost them so everyone knows who made them. Unless your ashamed you created the human centipede of ratchets.
How did you get the craftsman blade out I know for soft handle you can boil them but what do you do for hard handles?
Just read through the thread.
Basically, you insert the shaft into a vise, put a flare wrench around the base to protect the handle from being marred, and then use two pry bars to remove the handle. You'll have to adjust the placement in the vice as you remove the handle.
Yes, I chucked the handle in my cross slide vise, center drilled a 3/8" hole to the appropriate depth, then wobbled it to size(slightly over 3/8).
I've turned Micarta on a wood lathe several times and it works well. Do what you can to get it octagonal and roughly to shape on the bandsaw or tablesaw first. I think Craftsman at one time had carbide tipped wood lathe tools which I think would be handy. I've only use the standard steel tools and they do get dull a little quicker but not that big of a problem. Honestly I mostly use high speed steel tools on the metal lathe for turning Micarta, so carbide surely isn't necessary....I have an old craftsman wood lathe... haven't used it in YEARS, just wondering how it may hold up for use on a material like Micarta.
A little off topic but here's a Micarta turning project I did a few months ago, on a metal lathe though. pic-1 pic-2 pic-3 pic-4 pic-5 pic-6
Grigg
Don't know if this counts seen as it's not actually a ratchet but I've not seen anyone else do it so I thought it would be worth a share
It's a renthal bar gripand seen as they come in pairs I've also done my shorter bar too, no pics yet though because that one was trickier and the glue is still drying!
What did you use to step it up to fit the grip? Or did you have too? Id live to try it
If someone wants a cheap rubber grip, shrinking tube would work too I bet.
