Show us your welding projects
RossRinSD
Fallbrook, CA
All these nice welding carts....mine is an old TJ Max shopping cart with the sides cut out of it and a bottle bracket welded to the back. Lol.
Can't beat free, but Northern tool has a nice cart I would not mind having that has drawers for the weld stuff. They also have a bigger cart that I could have both the welder and plasma cutter on.
Haha, mine too. I've got to redo it eventually, I have a huge gravel parking area, and it ***** having to carry it across there...
But man, some of you guys have serious skills. I'm pretty impressed.
My first gate, did the stone walls and pillars, too.
I'm just pleased its level, actually swings, and hasn't fallen down yet
RossRinSD
Fallbrook, CA
And a couple of bumpers for the old truck
NASTYZEN
St-Colomban,Que. Canada
Nothing pretty here....but it's Magnesium.
Broken ear on VW gearbox. We use em on formula cars. That's why there's already welding all over it.:)
Ready for more abuse.
:beer:
ibedayank
Columbia TN
bumper I made to replace a factory one that fell apart
simple and ugly but works cost $0 pulled materials from scrap pile
welded with the tombstone
monkers
OK, not sure if Ive posted any of this here before or not, Im gonna try to post some pics using photoshop, but dont remember how, so bear with me. These are a couple pics from stuff I made at work : this is a table I made for my cutoff saw, with stock storage
this is the cart I made for my welder at work, Miller Shopmaster with wire feeder and spool gun, machine works good for stick, the spool gun works ok, but the wire feeder has not fed smooth from day one, not very happy with it at all.....
monkers
I have a couple other little things, if this works ill post them, not very pc smart lol....
monkers
UGH.....sorry for the large photos, and posting twice.....my fat fingers hit the button too soon.....how do I resize them for the forum
monkers
a couple other items, a "screw" press, I didnt build the screw portion or handle, the screw came from an old valve, I built the frame, the old frame was not adjustable
<a href="http://s1181.photobucket.com/albums/x427/monkers1212/?action=view&current=2011-06-17_18-43-24_590.jpg" target="_blank"><img src="http://i1181.photobucket.com/albums/x427/monkers1212/2011-06-17_18-43-24_590.jpg" border="0" alt="Photobucket"></a>
torch cart
<a href="http://s1181.photobucket.com/albums/x427/monkers1212/?action=view&current=2011-06-17_18-43-02_701.jpg" target="_blank"><img src="http://i1181.photobucket.com/albums/x427/monkers1212/2011-06-17_18-43-02_701.jpg" border="0" alt="Photobucket"></a>
bronze piece is a bushing for a valve that I made (we have a bunch of them that we replace every once in a while)
the piece to the left of it is a "spanner wrench" I made to adjust the bushing and also to remove it
this is a large "nut" I made to test the threads when I machine them, and also hold the bushing in the chuck for machining
<a href="http://s1181.photobucket.com/albums/x427/monkers1212/?action=view&current=2011-06-17_18-46-32_703.jpg" target="_blank"><img src="http://i1181.photobucket.com/albums/x427/monkers1212/2011-06-17_18-46-32_703.jpg" border="0" alt="Photobucket"></a>
monkers
a couple more, I apologize if it doesnt work, hopefully it will....
step plates I made for pressing bearings and seals
this is the setup I used to make some stainless slotted screws for the same valves
the finished screw, used in the lever that takes the valve from hand to motor position
SWT Racing
South Carolina
Have you tried using a felt lubricating pad on the wire before it enters the feeder?
Also, the enclosure for the wire spool keeps most of the contaminants off, but sometimes the spool will drag on the housing and make the wire feed a little funny without the proper tension.
DanielVetpath
Late this summer I made a small running gear to use with my garden tractor. I am planning on adding a wooden bed and stake sides in the next few weeks.
SWT Racing
South Carolina
I was bored, needed a lamp and had plenty of scrap. :bounce:
That lamp looks great! I wish my wife would like furniture like that. If I were a bachelor again, I'd order 500' of 2"x2"x065 steel tube and go to town. :D
Maybe I can convert her. I made a necklace display this morning for one of our friends that makes jewelry. She seemed to like it. I also welded up two hemispheres for a forming dolly.
N
neonnblack
Reno, NV
Did a bit more on my table, middle this week i got the red bars welded in for the welder "cradle". The angle iron cut to set inside so that you can fit any width welder you want. Talking about angle iron, boy do i love bedframes, we get mass amounts of them at work and i can buy them for 2-3 bucks a frame, thats alot of steel for very little money. Also i picked up a new skil grinder 6 amp 4.5" beats the old HF one it replaced in power and cutting speed, but longevity, only time will tell that. All in all success full the red bars hold up to my 300 pound *** jumping on them so i think i did ok.
Nova_Guy
Near Dayton, Ohio
I make small stuff as I need it. I built these out of square tubing to hold my trailer spare tires. I was moving them around all the time based on what I was hauling. I put them in the back to help take weight off the nose of the trailer. They seem to work fairly well so far.
NASTYZEN
Ninja crack repair.
Kind of a strange place for cracks to appear..... looks like it may of originated from the bend in the sheet Alu.
Clean of all the paint with a scotch brite disk and groove the cracked areas.Then slight torch heat to burn off any paint or oil that may still be in the crack.
Clean with Acetone and wire brush to make sure it's spotless.
The finished weld repair. Not as pretty as ZT's work, but just as strong.:)
:beer:
NASTYZEN
Any more pics of the blast cabinet (inside and out)? I have a fuel tank in the basement that I'm going to do the same with.
Here you go.
Shop vac hookup.
I gotta build myself a cyclone separator one of these days. The shop vac is ******** noisy and spreads the dust all over. grrrr
The insides.
Air intake.
Sand funnel and pickup.
3/4'' angle iron framing for windows.
I made a flange out of 1 x 1/8 inch flat bar for both the door and tank to be
able to glue a gasket for sealing and also for rigidity.
I also have a second door on the other end.
:beer:
monkers
Nasty, nice job on the Ninja repair. I like the blast cabinet also!
KyleQ
Twin Cities, MN
I recently finished a transmission swap and noticed I was leaking fluid, from the dip stick :headscrat
I pulled it out and found it cracked around where the o-ring sits, so without any choice, out came the welder.
I carefully welded up the crack all the way around and then, without having any of the tools I'm used to having (new home owner), I clamped an angle grinder to my table with a cutting blade and made the channel for the o-ring.
After I ground and test fitted I applied some RTV, baked it in a 100w light for ~20 minutes, put the o-ring on and installed. No leaks :bounce:
KyleQ
Twin Cities, MN
My father and I built a tube bender as a project a few years back. It was our first fab project - we were a bit nervous as the precision here was important.
A pile of steel was bought, measured, cut and prepped before continuing.
Drill, drill, drill drill....... drill some more, and did I mention some more drilling?
Ok - we drilled a few holes, always stepping bits and went through probably a gallon of thread cutting oil (we found this stuff to be the best lube, bonus was Menard's carried it and it was cheap)
I welded and ground the pivot block
Then came the clamping and welding - lots of careful measuring and clamping.
Hey, a couple of hacks can measure, cut AND weld while retaining square!
Getting there-
Bzzzz
Final product:
I shot some hammered paint on it - I'm damn good with a rattle can :)
Our first project turned out awesome -
(Project not completed in this pic)
KyleQ
Twin Cities, MN
I've also made quite a few drive shafts for our trail rigs - our rigs are trailer queens, but I've had my truck over 65mph without any vibrations.
I did a nice single pass over the joints and run over everything with a fat 2nd pass to make sure everything is set. On this drive shaft I've welded the CV head to the tube and now made the shaft longer. I've killed a D70 R&P with the drive shaft already, I'm not worried about it :thumbup:
Cryo Gal
Show ME your welding/metal projects on my Facebook page and win a Cryotreated Rotabroach set! Click the link. "Like" the page. Post your photo(s) on the wall with some info. I'll put all the photos into the contest album. When they are in the album, ask your pals to like the page and vote on their favorite photo. Photo with the most qualified "Likes" at the end of this month wins the Rotabroach kit! Easy
http://www.facebook.com/pages/PARTSMASTER-X-ERGON-Chicagoland/133028496795862
Deltarat
Hey! I recognize that craftsmanship. Nice to see your work/art again. :beer:
Is that a coupling to connect 2 pieces of tubing together in the last picture? I have seen some used on Extreme 4x4 and wondered if they were strong enough for a cage.
RossRinSD
Fallbrook, CA
Started on some rock sliders and steps for my truck.
I'd classify my skills as mediocre when it comes to sticking two flat edges together, but throw in the round stuff, and forget about it.
Is there a trick? I find myself making very exagerated arm movements as I work around the tube just to stay in front of weld puddle. And then, as you can see, I get about 25% of the way around and have to take a step around the work piece. It always makes a little jump, or wobble in the bead size. You can see it in every weld. How do you prevent that?
jinjaninja
hey guys, first post :)
as to the circle tricks, im currently a 1st year apprentice metal fab for a rally car shop, so im working my way through the learning process also.
The boss told me the most important aspect is a dry run. Make a pretend/practice sweep and make sure you can do the whole sweep in one arc. If not, break it up into even sections and practice the **** out of your starts and stops to minimise visual and structural impact.
As to my projects, im currently of work for 2 months due to being a retard and breaking my finger lol, so i have nothing awesome to show ... but will be sure to get some as soon as im back :)
mrpowderkeg
Bismarck North Dakota
Buddy wasn't happy with his adapter that he has to run on his 427 ford. It's a dove intake, and he has to adapt it to a dominator flange, it makes thing really tall. I guess dove at one time made a few intakes with dominator flanges but they are not currently available. Or so I've been told....
So I called in a favor from a friend, and had him mill off .750 inch off the intake, and also .750 inch off the adatper
We took it to my shop and welded the adapter to the manifold
And after some grinding inside, smoothing out the transitions and opening up the inside to the larger flange it came out pretty good
