The Everything 3D Printer Thread
burger
Erf
Does all 12 kg need to be the same color/material? Pricing sounds really good!
jeepxj
ok i got it working. I think.
who wants to test it out. no codes. no gimmicks. just multiples of 12 needed. it should block you with this alert:
burger
Erf
Waiting for the spools I ordered on Tuesday before doubling down. After I look thru the colors and decide which ones I like, gonna place a bulk order.
Spire
Kenai, Alaska
Looked over the website looking for some shipping information for Alaska... NO ONE ships to Alaska for free. Do you have something in mind for AK and Hawaii shipping? Continental US and Contiguous US?
soloz2
Western NY
What brand are these spools? If I hadn’t just loaded up on bambu I’d be all over this, but probably need to buy a dryer before anything else. My PETG has been brittle 😞
jeepxj
message me what you want. i'll get you fixed up.
jeepxj
factory direct. so the "brand" is yasin.
Gerald O
NC
I use con-Fusion or Inventor mostly. Just kept banging on it until I get it to do what I want. One big problem I had with Fusion on first learning it was its default 'parametric history' timeline mode. I always turn that off and use 'direct modeling'. Just have to remember to save frequently.
bugnut
Central Ohio
Finished completely disassembling Prusa hotend, learned more than I wanted to know. Placed bits in boiling water let soften and then set to scraping and cleaning. Reassembled on the bench. Then reviewed and ordered parts from Prusa. Ordered the hotend also, even though I checked parts with meter and they say they are working I thought for a C note it was worth having a backup in case of failure.
soloz2
Western NY
Ordered a creality space pi plus. Wanted the x4, but considering I already spent so much just getting a printer recently I opted for the cheaper version. Almost with with the $60 polydryer but wanted to be able to dry more than 1 spool at a time.
PelicanPines
I have two of them. Great dryer, terrible touchscreen. You gotta kinda touch and hold for it to register. You'll eventually get the feel for it, but it can be pretty annoying until you do.
My wife says the same thing about me...
I have the dual Pi dryer'er. I have it sitting next to my printer so it can direct feed. Problem is... the screen has to face the wall for things to not tangle. Need a deeper table ... First world problem.
Grant Gunderson
Bellingham, WA
I’ve been resisting picking up a 3d printer for years, as what I used for prototyping in college 20 years ago really tuned me off of them and I’ve seen a whole lot of **** parts done on them ( wrong material, poor design etc) but it seems like the Bambu ones are pretty dialed at this point. I’m mainly interested in doing gridfinity for organizing all of my tooling and have 20 lista style cabinets so I’ll be doing a ton of printing. I realize this will take a long time to complete so will focus on converting one drawer at a time over. Ideally I need something I can trust to hit run and let it do its thing all night and then do the next batch when I arrive in the morning etc.
I really like the idea of doing two toned parts for holding various tools etc the foam bellow is a good example of what I have in mind. Would be nice to do size labels too. Plus with the costs of this much foam 3d printing with a modular system so I don’t have to redo a drawer each time I add more tools is a big plus.
So given I’ll be doing a ton of larger gridfinity stuff and two colored parts, what’s the thought on going H2S vs H2C seems like the C will save material but if I keep parts to only 2 colors is it really that much of a difference?
Also thoughts on the laser module for etching labels vs doing two colored parts? Seems like they could potentially speed production up but I have no idea. My kid really wants one with laser, but he’s been watching too many mark rover videos so I don’t think he fully understands you gotta design the parts first! I would like to lazer etch some sizes in larger fonts on to some of my sockets as my best vision goes to ****.
I do see myself using some of the higher end filaments for building stronger tool holders / custom tooling in the shop too.
I can also see using this to make some custom shaft seals as well…
Not afraid to spend the money on the h2c, but am I better off with 2 h2s machines? With a larger volume to print I’m also concerned about minimizing waited material as material costs do add up. I also am usually a buy it once kind of guy and hate buying something to save a few bucks only to find I need to upgrade later.
pcrov
Ontario, CA
$1000 difference buys a lot of material to spend on color changes. The example picture wouldn't even require a multi-material system to make. It's a single color change at a layer boundary. In the slicer you can add a pause after one layer, manually change filament to the second color, then continue on. This isn't wake-up-and-done convenient and I'd use an AMS instead anyway but it helps to think about what goes on in a print.
As cool as the H2C is you could have a small farm of A1's cranking out gridfinity for the price.
I think 3d printing is a good place to deviate from that. You learn a lot by doing, particularly about what you really need; the price differences are more than just a few bucks; and the tech is still advancing rapidly. When you do upgrade it's not like you're throwing the old printer away - it's still got gridfinity to print. Heck, even if you start with the most expensive out there you might want to grab a cheap little second printer just to have something to iterate on designs with while the big boy works on production.
3D printing is a rabbit hole filled with rabbit holes, gridfinity being one of them. Don't expect to navigate it all ahead of time.
PelicanPines
@Grant Gunderson Think of 3D Printers as individual wrenches. You shouldn't have "Only One". As far as GridFinity Two Color Prints... I used to get two color prints rather nicely on a single spool printer by inserting a "PAUSE" in a specific layer line in the slicer then swapping out the spool for a vibrant color and print the completion of the part. (Just a suggestion)... Having say 3 or 4 printers going sounds like a better solution P1S's even. Don't know Bambus well... go for a minimum 300x300x300 bed. (my suggestion)...
Best of luck with your print farm... Remember ... when you decide to grow tomatoes... you don't plant one plant.
Cruzan80
Denver, CO
Bambus A/P/X are all 256mm beds, the H2 are 320mm. The H2C would be the top of the line, if you are worried about "filament poop", the H2D could easily do two colors without it (and is cheaper). H2D is dual nozzle, vs the multi-nozzle of the H2C. Almost of the H2 support the vision encoding plate for super-high precision. You can also "trick" the AMS if you need more colors than it has available to load (you can string up to 4x AMS for 16 auto-options, but you can do 5x+ colors on a single AMS with some "tricks").
For labelling parts, it is the same simple "Pause at Z" to swap, or Bambu's software has a "paint" option where you can select surfaces to make a different color, if you don't want the color in other adjacent levels.
The Pause at Z would mean the bottom layers of the "foam" are all blue, then swaps to black at a certain height (literally think of stacking different color post-it notes). The "paint" option let's the outsides all be black, and just blue on the inside of the cutouts (just depends on how much you care). It will need to swap (in some way)/more for the second option, as each layer will have multiple colors.
IIRC, the laser module occupies the same physical space as the printer hotend, so you have to swap them out manually between jobs. Also, don't know the specifics of lasering on 3-D prints.
Our X1E has handled everything up to the PAHT-CF (High temp CF infused Nylon) without issues (haven't tried TPU). The benefit of a dual nozzle would be for printing with support material, as swaps can get wasteful because since every layer, it has to swap.
For Stian, I would look at getting a A1 Mini for him to play with. I got one for my son (he wanted something he could run w/o help), and then we just printed support holders to rig up 3x spools off of it. He "manually" swaps colors instead of an AMS, but it was $100 for a lightly used one. Happy to continue chatting via PM on business use vs kid use (as I have the school ones that occasionally follow me home over breaks that he uses too).
jayz66ragtop
SoCal
Well, bit the bullet and ordered up an H2C yesterday with the ultimate package. A lot of the stuff I print is three or four colors and it kills me how much filament is wasted with my X1C. Nothing at all wrong with my X1C, a co-worker showed interest in it and I thought he was going to buy it but he bought a Core One. I'll decided what to do with the X1C once the H2C is here, not really enough space to have them both setup but may rearrange some things.
For those wondering why the H2C and not one of the tool changers. I read and read about all the other brands and their tool vs nozzle changer and kept coming back to the H2C. Because of these reasons:
1. I bought my X1C on the kickstarter and have been very happy with it. It fit exactly what I bought it for, simple to run, minimal fuss
2. All of the tool changing options are not closed chamber (Yes, the INDX will be enclosed) which is a no go since I print ABS
3. I thought about an Core One but read a lot of reviews that brought up build quality issues and alignment issues
4. All of the print head swappers us pogo pins that are side loaded when swapping, this makes me nervous about longevity of those pins
I know there are some down sides to changing the nozzle vs the print head. One big one is time to swap is not that much faster than regular single or dual nozzle printers. That isn't that big of a concern for me since I usually print stuff while I'm sleeping anyway. Some can say the Vortek switcher can be prone to misalignment's which I agree, as long as it's as reliable as my X1C has been I'll be happy.
This picture is one that helped sell me on the H2C
jayz66ragtop
SoCal
and just because there is a new printer on the way don't think the X1C is getting retired. Not going to reveal the cool thing I've been working on until it's done but can share something else.
MIL's sewing machine broke and she wanted to order a new piece. Wife looked at it for a bit and I came along, looked at the broken part and asked if she had the rest of the missing parts. Wife knew where this was going, rolled her eyes. MIL asked why I would want the broken parts, I asked if she threw them away and she said yes. She went to get them out of the trash. We agreed to wait until Thanksgiving before ordering a replacement.
Took me two tries... First just because I missed that the pin went through both inner circles. Second try fit like factory but I'm printing a third with six ribs instead of the original four.
Broken part
New design, ribbed for...
and another satisfied customer! Well, once MIL gets the machine back.
