Things that happen in my garage
D
dlcwent
Member Emeritus
coastal maine
Okay guys..........
Andy, this is no "screw thread" but very clever of you as usual. It is a Wentworth not a Whitworth thread.:lol_hitti
Mark, you have no room to talk.;)
So as some of you may know, we've been doing a transmission transplant in a 61 Caddy. The owner wanted us to put a TH350 in place of the "Jetaway". Mind you this is all at his request. I have a different opinion as to what should have been done.
The first step was to find an adapter plate for the 390 to allow the mate up. With a little help from the guys over on the "Jalopy Journal" here it is installed.
A little more reading and I found out that the starter they were trying to sell me for $179.00 was a started that a 90 Dakota Magnum used and was available and the local parts store for $70.00. ( Yeah I bought the $179.00 one:headscrat:wtf: NOT)
I'm out of time. I'll continue the story later.
oldironfarmer
Terlton, Oklahoma
WOW! Nice update:thumbup:
61 Caddy and you're butchering it:wtf: What kind of shape is it in?
I think the transmission swap is the right move if the car is to be driven much. We're ready for more pictures:rocker: (WOC looks good!)
Bob Heine
Boca Raton, Florida
Dan, I have a soft spot for the Hydramatic/Jetaway transmissions. Right after my accident in 1965 I acquired a small block Chevy engine and a dual-range (4-speed) Hydramatic with a bellhousing for a small block Chevy (I think it came out of a GMC truck). It was my solution for having to drive an automatic because I refused to waste my time on a two-speed Powerglide.
In the early 60s the manual transmission was king and power shifting was the rule at the dragstrip. One exception was the S&K Speed Shop's Anglia with a roller-cammed small block connected to a Hydramatic.
In 1964 S&K Speed Shop did the machine work on my my 235ci Chevy six. The shop was in Farmingdale on Long Island, NY.
https://skspeed.com/history
The straight-six engine produced amazing torque but its restricted RPM made horsepower that was nothing to brag about. With a really low first gear it would outrun some powerful V8s in the 1/10th mile strip marked out on the street next to the railroad tracks (the trestle cut off most of the sounds of our racing).
D
dlcwent
Member Emeritus
coastal maine
Well thank you all for your comments and opinions as to what should have been done. I think Mark is the winner. Keith Black and Lenco.:3gears::lol_hitti:lol_hitti
I've tried a couple of times to add to this but the GJ is not playing nice. Two lengthy posts and a couple of pictures disappearing has kind of taken some of the wind out of my sails. I wanted to get this much out so you guys didn't think I was leaving you all hanging.
Hit "submit reply" and then start another one.:dunno::headscrat
D
dlcwent
Member Emeritus
coastal maine
Well at least that one posted.
So as I said, I picked up the starter at the local parts store.
It's a high torque starter that was used on a Dakota Magnum (1990 circa.) Again, thanks to the guys over on the Jalopy Journal.
A little back peddling: One of my buddies has an older bone yard. A lot of 70's parts. So I went to see him to get the TH350. The one he told me to take was a working transmission when it was parked. I didn't care as I was going to rebuild it anyway. But nice to know the torque converter and pump were working at one point in time. So I brought it back to the shop and threw it on the bench and luckily didn't start tearing it down until the next day. When I got back to it the next morning, I noticed that there was ****** fluid on the casing that at first I thought was dripping from the cut off coolant lines. So I was cleaning it up a bit and realized it was actually not coming from the lines but the case had a crack in it.
[Picture should be here]??????
Sorry to do this but I don't want to lose another post so ....................to be continued.....vvv
walt111
TN
Ah dan. The same problem I had for at least three months. Work on A post and have it disappear into outer space when trying to submit it. What makes it even worst for me is I can not type, I am a pick and peck person. I do not reply to often but I read every one of your post. Keep up the good work.
walt
D
dlcwent
Member Emeritus
coastal maine
So back to my buddies for another TH350......... Off we go for a little walk about his 100+ acre yard. Down in the second field he's got a E150 and it's full of transmissions and various other stuff. Yep he says, that one was working when I pulled it out of a car that one of my old girlfriends totaled. So we load it up and it's back to my shop. Up on the bench and then the teardown started.
Out comes the pump.
The forward clutches look okay but what's all this rust?
Take the valve body off.
And OH NO, water damage and no acid tank to dip it in.
Strike two. Guess I'm heading back one more time.:wtf:
walrus
Maine
I used to love walking around in the junk yard but after 2 or 3 tries it gets old
oldironfarmer
Terlton, Oklahoma
Yeah, don't you dare leave us hanging. Two days without a post and you know we're all out of here.
Just wondering, could you swap valve body between the cracked case and the trusty rusty? I'm just curious. And I'm not a cat.
bolensboneyard
South East
Out comes the pump.
Dan hope your keeping all those bad transmissions for parts. You should be able to build a good one by the time you are thru. :lol_hitti
D
dlcwent
Member Emeritus
coastal maine
Thanks guys. Walrus, damn few yards you are allowed to walk around anymore. It used to be that they'd let you go and get what you wanted for parts, now in this sue happy world, you can't do that.
Andy, good valve body in the cracked case but why too much rust in the "good" casing. If I had a dip tank (or if I were you, I'd probably make one) I would have cleaned it up and proceeded. Anyway, I'm about to go get another one from this guy.
Bobby, I know right. I need a bus or trailer to store all this great stuff in. I'm running out of room in my 35'x75' garage.
I won't leave you guys hanging.............:rolleyes:
D
dlcwent
Member Emeritus
coastal maine
So "third times a charm" they say. Back own into the second field but off to an old box truck this time. Pry open the door and WOAH, she full of you name it. Pick through some of the pile and pull out another TH350. I feel good about his one.
Back at my shop I start the teardown.
Pump out
Valve body off
I'm liking the looks of this little puppy.
Sorry guys, but out of time for now. The saga will continue.
D
dlcwent
Member Emeritus
coastal maine
So on with the story.
I could show you a bunch of pictures of the rebuild but am only going to show a couple. Mainly because I want to show JB some of my "special" transmission tools. This is what I use to compress the pistons in the clutch pack JB.
Yep, that's right, it's a 3" saddle from an exhaust clamp. Pretty high tech eh?
And after putting on the new lips seals, I use my trusty feeler gauge to make sure they don't roll when the piston is put back in place.
Pretty special tools don't you think?
Again, sorry to break this up but I've lost too many posts and uploaded pictures in the past. So....................vv
D
dlcwent
Member Emeritus
coastal maine
So next hurdle was to re do the transmission mount. It really wasn't much of a hurdle. A little cutting and welding ( and a trip to the parts store for the proper mount) Which by the way if I remember, is the mount used in a 80 something S-10 2WD. I'll get back to the exact year if anyone really needs to know.
The next problem was the drive shaft. And that one took a little longer to resolve. By taking the front piece (two piece shaft originally) and changing the yolk and u-joint, we were able to use the splined end (with another u-joint) and keep the center bearing (did have to be re-drilled for it's new location) and then found a two piece shaft out of a 70's chevy something that we used the back shaft to actually give us the right length to make it all work. Got a picture but it's not that impressive.
I told you it wasn't that impressive.:wtf:
Sorry but out of time.....................
D
dlcwent
Member Emeritus
coastal maine
Now we can start butchering the car. He picked out this shifter.
It's the Star shifter. My suggestion to him because it has a reverse lock out.
I'll finish this up in the next couple of days with a couple of "DONE" pictures. It's been a lot of fun ruining this Caddy. How often does one get a chance to do that to a 61 Caddy? I doubt I'll ever have another one that someone wants that done to. Thanks for your interest and comments guys.
BBChevro
Brisbane, Qld., Australia
I would never have expected to see a B&M shifter in a Caddy.
The TH350 is probably not the worst choice though, that low first gear will help get it moving (although I don't know what the ratios of the original box were).
tymbo
West Chicago
I have a funny story about the star shifter I installed in my first car a LONG time ago. In my youthful exuberance, I did not reconnect the neutral safety switch. This allowed the car to be started while in drive! I ended up almost crashing through the garage wall.:lol_hitti Other than that, it was an awesome shifter.
jbmatth
Northern Ok.
I love all of the special high tech tools you use, I think I might even have some of those somewhere. I just don't have a trans that needs rebuilt now, Andy does though. :)
JB
xtremek
St. Johns, Mi
Lyndon, Dan has been away taking care of his Mother. He should be back soon. Last I heard his Mother was on the mend.
Hey 53, thanks for the update. I'm sure I can speak for everyone on this in that we hope that your mom is doing well and hope it wasn't too serious.
