Unusual structure
billconner
Thousand Islands NYS
So buying a 1910 farm house fixed upper for my son. There is a truss like structure though not sure it's really a truss. That doesn't matter - whether the "top chord" is that or if the bottom chord is doing the work. This sits directly on top of a wall dividing two bedrooms on second floor, and a living room that is clear those two rooms. Looking close you should be able to see the tops of two large eye bolts through the "top chord", with 3/8" wire rope down through attic floor.
Next week I'll go back and do a little demo but my guess is this is supporting a beam in second floor/first floor ceiling. Another guess, there was a bearing wall under this on first floor, dividing what is now a long living room.
In my work in entertainment technology I've seen and designed a lot of things hanging on wires rope but don't think I've ever seen a second floor in a dwelling supported like this.
whateg01
doo dah, kansas, usa
Was there one of these hanging below it?
billconner
Yes - that top "rail" is braced to rafters but it has the eyebolts with wire rope. I think they elevated it to make it simpler to rig.
We are wanting to remove it to repurpose attic.
whateg01
More likely done to add strength because the truss has a taller cross section than the ceiling joist that it's attached to
mike93lx
Richmond, VA
That's really interesting. The braces to the rafters feel like an afterthought and may not be necessary. Guessing if you remove them, the truss will have some wobble which a previous owner thought needed to be taken out.
billconner
I agree. The top parts are just double 2x4 toe nailed and a lot of vertical force. I suspect it could be pushed to either side a little at least.
Old Man Roger
Palm Coast Florida
If it was for floor support it doesn’t make much sense to have those 2 boards come down from an angle. They would give way more support if they came straight down, or had 2 more on the other side.
PCustoms
VT
There was lot of framing added after the fact, based on the different color.
@billconner what is below that "beam"?
What are you trying to turn the attic into?
Uncle murph
Harford county
It’s possible it was built for a one time specific purpose.I couldn’t guess what without seeing the rest of the house below.
PCustoms
VT
A lot? All that looks newer to me are the 2x6's tying into the rafters
Ok, some?
Look at the crooked ties up high., and right in the front There's something. There's also a shelf? to the left and something along the table end, a metal turnbuckle or maybe clothes rod, can't tell
firebirdparts
Kingsport, TN
That certainly will hold up the 2nd floor, if that's what it's doing. I'm surprised it's that short. I don't think you really need one that short.
P.S. It does appear not to be a truss. Trusses can only consist of triangles, and it looks like you've got a square in the middle. Still pretty strong.
billconner
There is a wall between two bedrooms on second floor and nothing on first floor. Living room is basically the size of the 2 bedrooms. No sign of any thing in living room ceiling - no crack or dip or any sign it was not always continuous.
billconner
Mid century Vierendeel truss? :)
PCustoms
VT
And what are you trying to repurpose the attic for?
Lassen Forge
Before I drift off into the nether regions... I've seen various wall/floor support systems in older houses - my grandparent's place (built in the 1920's) used truss rods, tensioned cables, and anchoring footings to hold up the floors (and roof) over the basement, as well as load bearing wall framing... . The house was pretty solid and stable, and I attribute it to this construction method... it seems to have been common about a century ago...
Drifting here...
Ya beat me, um, er, to it. (I've had friends into such things....)
Movie production, or, dungeons or, um... never mind....
I've seen a variety of this type of "suspension" in older buildings including threaded rods.
Me too. Older buildings where various "tradespeoples" plied their "trades" with other people....
Mom wants a play room.
Um... never mind. Again. (dammit, where are Pines and TampaGT when you need to 'splain things...)
billconner
What I referred to as the "top chord" is I believe just an elevated rail to make the wire rope termination easier. I believe the triple 2x12 with plywood spacers (why?) is carrying the load. Without the raised rail how could you terminate the wire rope and adjust tension swing the eye bolts? You'd have to tear out some of the second floor wall. I can see feeding wire rope from attic to a beam in first floor ceiling - with temporary supports - and never disturbing 2nd floor bedrooms.
It will be interesting forensic work. I don't know how much I can see with a borescope, but prepared to cut. I'm hoping I can figure out a beam of some sort in living room, though the idea of a truss within the bedroom wall on second floor had some appeal. (I think I'd go to an engineer for that.) Probably will suggest a beam across living room and simply wrap it or otherwise treat it, maybe extend around room coffered ceiling like. Insetting a beam is of course ideal - even if steel. Supporting the second floor temporarily would not be hard but supporting the second floor wall presents a unique challenge. The bearing wall with floor joists probably overlapping on it and another bearing wall sitting on it.
Living room photo. Supposition is the removed wall divided the approximately 24' room.
  • 18.pdf
carlaisle
To confirm I understand correctly: the pictured living room (very nice) is on the first floor, there are two bedrooms directly above with a shared wall that runs roughly across the middle of the living room and the trussish structure is in the attic directly above the wall separating the bedrooms?
What is the span/length of the living room underneath that wall? It is possible that separating wall was built as a truss to support the ceiling of the living room/floor of the bedrooms.
billconner
@carlaisle You have it stacked correctly. the living room is about 24 x 13, so my supposition is it was two rooms each 12 x 13, though no signs. Floor is continuous and ceiling looks flat throughout. But I do know a one story addition with dining room was added at some point.
Someday I'll have to put together the bits and pieces of the previous long term owners renowned in the region for their BBQ chicken, along with the chicken barns in the property. The 4 story chicken barn is kind of amazing.
Leaflessshadetree
Don't ask.
I'd look in the basement/crawlspace. Is there a beam, post or wall beneath it? What about the rest of teh main floor, is there a wall in line with it. What additions have been added to the house? Are there any clues you can use to figure out what the original layout was.
billconner
Plan to be back there this weekend just to survey.
racecougar
Missouri
Four human-size stories or four chicken-size stories?
firebirdparts
Kingsport, TN
Hey, I've got an idea. Strip the 2nd floor wall and build your new support structure inside that wall. Tie your cables to that and then cover it up.
firebirdparts
Kingsport, TN
Honestly, every house is pretty much the same in this way. I can guess without looking what you should find down there.
If there's a problem on the first floor, that's important, but there's no way to physically connect the two problems now. Support for the 2nd floor is the real problem now.
