Unusual structure
billconner
Thousand Islands NYS
So buying a 1910 farm house fixed upper for my son. There is a truss like structure though not sure it's really a truss. That doesn't matter - whether the "top chord" is that or if the bottom chord is doing the work. This sits directly on top of a wall dividing two bedrooms on second floor, and a living room that is clear those two rooms. Looking close you should be able to see the tops of two large eye bolts through the "top chord", with 3/8" wire rope down through attic floor.
Next week I'll go back and do a little demo but my guess is this is supporting a beam in second floor/first floor ceiling. Another guess, there was a bearing wall under this on first floor, dividing what is now a long living room.
In my work in entertainment technology I've seen and designed a lot of things hanging on wires rope but don't think I've ever seen a second floor in a dwelling supported like this.
whateg01
doo dah, kansas, usa
Was there one of these hanging below it?
whateg01
Yes - that top "rail" is braced to rafters but it has the eyebolts with wire rope. I think they elevated it to make it simpler to rig.
We are wanting to remove it to repurpose attic.
More likely done to add strength because the truss has a taller cross section than the ceiling joist that it's attached to
jack stand
Lakes Region Maine
I've seen a variety of this type of "suspension" in older buildings including threaded rods.
I definitely would not remove it unless you like very springy floors.
There was no engineered lumber back then a the size of timbers & joists were limited to local resources and budgets.
mike93lx
Richmond, VA
That's really interesting. The braces to the rafters feel like an afterthought and may not be necessary. Guessing if you remove them, the truss will have some wobble which a previous owner thought needed to be taken out.
billconner
I agree. The top parts are just double 2x4 toe nailed and a lot of vertical force. I suspect it could be pushed to either side a little at least.
Old Man Roger
Palm Coast Florida
If it was for floor support it doesn’t make much sense to have those 2 boards come down from an angle. They would give way more support if they came straight down, or had 2 more on the other side.
PCustoms
VT
There was lot of framing added after the fact, based on the different color.
@billconner what is below that "beam"?
What are you trying to turn the attic into?
Uncle murph
Harford county
It’s possible it was built for a one time specific purpose.I couldn’t guess what without seeing the rest of the house below.
PCustoms
VT
A lot? All that looks newer to me are the 2x6's tying into the rafters
Ok, some?
Look at the crooked ties up high., and right in the front There's something. There's also a shelf? to the left and something along the table end, a metal turnbuckle or maybe clothes rod, can't tell
firebirdparts
Kingsport, TN
That certainly will hold up the 2nd floor, if that's what it's doing. I'm surprised it's that short. I don't think you really need one that short.
P.S. It does appear not to be a truss. Trusses can only consist of triangles, and it looks like you've got a square in the middle. Still pretty strong.
billconner
There is a wall between two bedrooms on second floor and nothing on first floor. Living room is basically the size of the 2 bedrooms. No sign of any thing in living room ceiling - no crack or dip or any sign it was not always continuous.
billconner
Mid century Vierendeel truss? :)
PCustoms
VT
And what are you trying to repurpose the attic for?
