rexpittman
sent email for invoice, glad to see this still coming together!! Thanks for picking up the ball on this!!
GREAT team work guys!!
Look at post #1
Aquamoose lists the machine with no consumables at $192.80 delivered to HIS house.
When you put in your request for machine and consumables, and give him your address, he will figure shipping to your door and add it all up and invoice you. Typically about $35 or so. My total in Detroit with 2 consumables and 1 cups was just under $250, delivered to my door.
Bill
Maybe one of the bronco guys can post a message to others there that they need to move on this
I'll post on the thread over there-
Bump.
If you're going to do this it is time to follow the instructions in post 1 of this thread on Garage Journal. The list of names & status is in post 2.
Going off his status list 139 out of the 297 on the list have requested the invoice as of the last update. Enough to get over the 120 threshold for the thing to work. 76 of those have paid to date. A lot of names left on the list who said they wanted in but haven't responded yet.
If you jumped in but are no longer interested, it would be good if you could post that info in the thread. They are also marking off the names of those who don't want it anymore.
to bad you cant get paypal to send an email that you have an invoice. I would have never known except i saw it mentioned briefly here.
i received nothing to main or my spam.![]()
Anyone on the USA side near Sweetgrass by the Alberta border willing to handle some Canadian orders?
Richard
Richard
I'm in Kalispell, Mt. the Roosville boarder is about 60 miles from me. For some that may be better than Sweetgrass. If that helps let me know.
There are a number of companies in Sweetgrass that you can ship parcels to and they will hold for as long as required. Costs are minimal usually about $4 U.S. per package. I use Montana Shipping Outlet.
http://www.montanashipping.com/
So the 10-2 circuit is sufficient? As long as the receptical is at least 30A?According to other Ebay sellers selling the same thing, this unit draws 25 amps of 240vac at the 50 amp output setting. The 50 amp output setting has a 60% duty cycle rating (40 amp and lower output has 100% duty cycle rating), so a regular 30 amp 240v plug is fine even after factoring in duty cycle and the 80% rule for sizing circuits. What this also means is that if you are planning on making a longer extension cord for this unit, 10 gauge is fine.
I only have a 20 amp 240vac plug in my shop at this time, so I will be setting mine up for that style plug and then only using the unit at a setting of 40 output amps or less for now (so I don't trip the breaker).
http://www.ebay.com/itm/Pilot-Arc-P...216?pt=LH_DefaultDomain_0&hash=item418fcc7818
A 10-2 cord (with a 3rd ground wire) is fine for anything between the wall outlet and the plasma cutter no matter what amperage wall outlet you have.
If you are talking about the wire in the wall of the home between your electrical panel and the wall outlet, you can run 10 gauge there as well as long as your circuit breaker and plasma cutter wall outlet are not larger than 30 amp. Using a 30 amp rated breaker and outlet with 10 gauge is fine.
The most economical combination would be 10 gauge wire for everything from your circuit panel to the plasma cutter, with a 30 amp 240v wall outlet and plug. Electric dryer outlets and plugs should be the most cost effective and easiest to find option for the receptacles.
I sent email too and no response as yet and now I have a friend that wants to add on. No rush, just checking inMake sure your email on PayPal is correct. If it is, send him another email and let him know.
I sent email too and no response as yet and now I have a friend that wants to add on. No rush, just checking in![]()
