Some compressors can be rewired for 220v. I don't know if that one can. That's a pretty big head and motor.Any info would be appreciated... on the swap for $300 obo, only info listed is that it’s 3 phase and he can’t hook it up at his house.
I asked for more pictures when I messaged him, I’ll update when I learn more
You need to study up on electricity. Three phase motors can be converted to run on 220v using a VFD. I haven't done it. I have replaced 3 phase motors with 220v motors and added a lot of capacitors to help get the motor running without tripping a breaker.Many motors can be wired for different voltages, but 3-Phase is 3-phase.
https://www.precision-elec.com/how-to-run-a-3-phase-motor-on-single-phase-power/
Directly from the website.Yes you can use a VFD, an idling 3-phase motor, or other external device to create 3 phase power for the motor. (The motor still requires 3-phase power)
Yes, you can build a motor-starter to use the extra phase windings as starter windings, and get the motor to run.
It will produce between 1/3 and 1/2 rated HP, and when loaded with want to run a bit hot.
It will also have relatively low starting torque and these two factors together make it unsuitable for compressor duty.
How To Run A 3 Phase Motor On Single Phase Power
Actually, 3 phase motors can be run with a 1ph input - 3ph output Inverter.
No 'converting' to it or needed. I know who needs to study up.
Hello, new friends. I finally found a compressor that will outlive me... BUT...It took so long to find one (I could afford) so it won't be much of a chore to outlive this old man
I'm done buying a new one every 2 years. Damn high-speed loud annoying timebombs...
But now that I have what I want I'm also gifted with a bunch of new hurdles to jump. Living on the belief
"THE MORE YOU PUT INTO IT THE MORE YOU GET IN RETURN" Well, this worked with my Dog and my wife...
1st was unloading it off the trailer as we had a tractor at the pickup site. I drove to Marietta Oklahoma from Houston Tx to get her. She is heavy and was that ugly old light blue the Houston Oilers seemed to like in the '70s
So I had to sand and paint ASAP to make her look as good as she "WILL WORK" he said knowingly. I also replaced the gauge with a nice oil filled one and bought a few new connectors and ball valves to install.
The motor and THE POWER it consumes:I was told that the motor would run on 110 or 220. Simple enuff... or so I thought. I was able to find the wiring info on the info plate. as you can see below. in pic 2 I think. SO ya know... I'm well into my 50's jack of all as they say mostly 99 percent self-taught which means "I don't know %$@#" but I get by... much better now that I can hide in closet and look up a 9 yr old kid on youtube that can teach me anything how to fix computers to How to pass level 108 of ZELDA Conquers SLIMVILLIA ( these kids are so smart nowadays I just don't understand why they're so damn ignorant)
I had always thought you had to have a + and - for Anything to work but as I learned with this 4 wire motor just a 120 leg off each phase and it works... I'm still gonna study this theory until it sinks in... e motor is PRE 52Im told it was or is called "the Original frame" Rerated "U" frame in 52 then again in 64 to a "T" frame My Motor guy said they Use "T" frames currently WHATEVERALL THAT MEANS>>>>lol
I think he said it was a 224 frame and one of the rarest due to age... yaba daba doo...
We do know its a WAGNER and we do Know it's very HEAVY. Since it was cut loose on pickup and I was told it was on 110 I plugged it in and she ran fine but weakened around 50 PSI so I unplugged her and started reading...
THE TANK1984 Manchester 200 PSI
HOLDS air and NO RUST
NEXT... Unless I need to be told there is more to it
The V-TWIN Compressor
Boy, I hope this is a good one. So far she pumps air and it holds but I know less about it than I do the old motor ( NOTMUCH)
It has a D inside a circle. I ed up all the companies that start D that I can find that builds compressors to no avail but I want to say... Ingersoll Rand for some reason...
If you of this compressor or have any general knowledge that will help me from BLOWING IT OR MYSELF UP please chime in I can use the help. I have found ZERO 9yrs old kids on youtube with that knows anything about this old beauty. Once I have her all shed and ready I plan to build a newly insulated home a nice positive airflow and start running pipe to every room on the property. My wife overheard this statement and ask EVERY ROOM? She's blonde and I love her...So I replied... Well, ya never know when ya might need 200 PSI in the bathroom. She said.... WELL? O.K. with a confused expression and said " please use a nice faceplate"
Here is a neat little DeVilbiss compressor my SIL found in the attic of his camera shop and brought by the other day.
That little Champion sure looks nice Doug. Better than new. More than adequate for blowing saw dust I'd think
Got some more info on this compressor, yes it is a Curtis, 15hp 3phase 200 gallon. Don’t think I have 3 phase power in my area, still kinda want to buy it
If it builds to 90 psi and keeps running then there is something wrong with the compressor head. If it builds to 90 psi and shuts off it may have a low set limit switch. That comp is two-stage and should be good for 150 to 175 psi. I would not take it up there without having the tank tested. If the comp has been limited to 90 psi, there's probably a reason. I would try to find out what that is. May be that the tank's integrity was brought into question. May be the job it was doing only required 90 psi.
It is hard to say, but it sounds like a frankencompressor, so who knows what kind of control it has on it - as I'm sure you know, the IC engine-powered units typically use an unloader or in some cases an engine throttle control when the pressure reaches the setpoint.
New member here. Any one ever hear of a C.A.S.E brand compressor? Made in Grand Rapids Michigan. Any idea if these are good compressors and how old they are?
New member here. Anyways I picked up this compressor pump last night but I'm not having much luck finding any information on it. I want to put it back in service. I'm hoping somone on here can help me out.
It's actually bigger than the pictures make it look. The dang thing weights over 100 pounds. Turning it by hand it seems to move a lot of air.I have never heard of that brand, but just judging from the size of the pistons, it probably only flows 3-4 SCFM. It is a two-stage pump however so it should get up to 150-175psi.
I doubt that you can still get any parts at all for it, so if it still rotates and seems to pump, I'd put some fresh compressor oil into it and see what happens when you run it. If you just need something to pump up tires and use for short periods of time it will be fine - it will not handle any continuous-use air tool such as a sander or die grinder, other than for very short periods (dependent upon how big of a tank you use with it).
Thanks for the information. Any clue how many rpms I should be shooting for?
