What do your Storage Cabinets look like?
abstamaria
Manila
Office cabinets in the garage
As with the others who posted here earlier, I used office cabinets in the garage.
I use a compactor system for spare parts; it offers a lot of storage but has a relatively small footprint.
I put not only equipmemt manuals and other files in the filing cabinets, but also technical DVDs, miscellaneous spares, even bongos and ,usical isntruments (every garage must have a garage band).
I posted these some time ago in the gallery section (modern garage ...), so apologize if you've seen them before. I thought it would be good to contribute them to this consolidated thread.
I hope you find the ideas useful.
Andy
alberto
Just plastic door tracks glued to the rack beams then cut the hardboard to size. I still need to cover the sides and drill some finger holes in the doors. The hardest part is finding a glue that will stick to the plastic track and the metal beam.
Here's the website for the track, I had to special order the gray and the longer length. The 8 footers are to short for an 8 foot beam, needs around 8' 6" or so.
http://www.knapeandvogt.com/Plastic_Track_and_Upper_Guides_for_1_~~_4_-_Series_2412_and_2416.html?page=details.432
And the glue you used?
D Force
Tucson, AZ
Re: Office cabinets in the garage
Andy
OMG, did you steal these from a Titan ICBM launch facility, or the National Archives or something?
abstamaria
Manila
That is the good thing about using office equipment. They are inexpensive relative to the tool cabinets we tend to use. They also frequently come up in clearance sales and as used furniture when a business closes.
Not sure about the ICBM launch facility, but the archives would have compactor shelves - they roll on rails and save space by eliminating an aisle or two. But many offices have them, where floor space is at a premium. We have them where I work, but in much larger sizes. I have limited space in the workshop, so the compactor is great for me. They can carry a lot of weight; I have cylinder heads and a gearbox in mine.
Andy
abstamaria
Manila
That wasn't necessary, Dittle FA; I didn't take it as a slight, but thank you. By the way, that's a great site you have for storage cabinets.
Andy
Brettwc1980
130.jpgThese are the cabinets I framed in with 2x4s. The trim all pallet wood and reclaimed roofing tin. The garage door track is built into the top shelf.
icecactus
Agreed, better pic would be nice...they look really cool though. But i would like to see more detail :)
kfvintx
Is that a wine rack over to the left??? I'm all for "beer frig" in the garage but wine? Is the garage temperature controlled?
hobie1dog
Cornelius,NC
I turned some unsused space above the projection screen to house not normally used MX gear.
Got these cabinets out of a Dry Cleaning store on Craigslist.
mgilde13
Crappy pic but you get the gist of it. This is my upper cabinet. It still needs a little touch up, some lettering and a few coats of clear. The lower cabinets have a paint job that is yet to be determined. And yes, there is a wee bit o' Irish in me.
bobbyd
Kansas
All the lockers came from multiple sources including a mental institution in Kansas. Several different sizes and configurations. All painted to match with base/clear automotive paint which cost way more than I actually have in buying the lockers themselves. Several came out of remodels, etc. The base cabinets came out of a grocery store pharmacy remodel and painted to match.
lowbucktruck
Foothills, Northern California
I have a combination of cabinets, some used office cabinets I picked up cheap for garage storage and some auto parts tune-up cabinets for wall storage. The black cabinets store most of my power tools on roll-out drawers for easy access.
Still a work in progress, but getting there.
machine_punk
Napa Valley, California
well done on the painting to match! I've been watching CL for lockers lately. I think they have a lot of potential in a workshop.
D
dittle fart around
Vancouver, Washington, USA
Drop down doesn't work on my machine. The other two beside it does but the first doesn't that was why I askd.
I checked it out and it works for me. If you choose the default listing that says "drawer cases" it takes you back to the same web page you started with. I'll see what I can do to make this work better. Thanks for pointing it out.
Tripp P.
G.R. Michigan
Here's my storage cabinets. All home built with a skill saw and a shopsmith.
Also built the tool box against the back wall.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
tplaya07
I love the look of these. Nice clean lines, and exactly what I'm going for. Probably a simple question for most of you, but I know nadda about hinge types. What kind of hinges are on these that you're able to have the cabinets mounted so close together without them running into one another when you open them? It looks like it's less than 1/4" gap between the sets of cabinets.
Is it some sort of overlay hinge?
D
dittle fart around
You can get this look with European hinges that look like this
H89Mb5a4y1mmHSS3TX5rB4ukobjj5yn_3wxwsybtWWVJJu4_ZDZ3YLGZ9yQ6XE2BpJoBQRL5p9MKZpIpI-KbH76uVNFjL4oicACqsP4lOptXpOf0FQQu3LxUS6OJv605e3PkxKAggjtwIXEaJ48i
richtersrodz
Waxahachie, TX
I was afraid of using these hinges in the past.. because of how you have to mount them.
But then I went to HD, and found the special drill bit, and template kit. It makes counter
sinking them and mounting a snap!
richtersrodz
Waxahachie, TX
Not really garage storage, but kitchen storage... I built all of my own kitchen cabinets
and counter tops in my old house. I flush mounted everything, and it was very, very
time consuming. I think when I do it again for the garage, I definitely won't go this route.
The doors have to be perfect to fit the holes, and cutting in the hinges was horrible!!
tplaya07
Thanks for the reply Richter. Aren't the ones you have inset overlay? I was planning on using the frameless full overlay ones with the cup (European style?). I'm not sure if they mount the same as your though. I was planning on just using a couple different sized paddle bits to bore out the hole, and then just use some wood filler to patch the hole on the front side (from the tip of the paddle bit). However, I'm definitely open to suggestions if there are other bits to make life easier.
Also, the hinges that I got came with little plastic anchors already installed on the part that attaches to the door. It seems as though you just bore a hole for them to sink into, and then twist the screw to expand the anchor and tighten it. I'm sure this would be fine for kitchen cabinets or light doors, but would this suffice for cabinet doors measuring 75" x 18" and made out of 3/4 ply? Or would I be better off just using some small wood screws?
Thanks.
D
dittle fart around
The cabinets look great. I'm sure after 10 or 15 years of experience it will get easier.
2manytoyz
Central FL
Just sold our present house. It had decent cabinets in the garage, along with a laminated coutertop, down the left side of the garage:
The new house we're buying has a slightly larger garage, with a 5'x5' recessed work area as well. The previous owner had it packed full of stuff...
He's taking his workbenches, and I'm taking out the shelving. Starting with a blank canvas. I'd love to have Stanley Vidmar cabinets, like what I have at work, but well beyond my budget.
I might epoxy coat the floor, and build my own workbenches and cabinets. Getting some good ideas on this forum!
richtersrodz
Waxahachie, TX
Thanks.
True, the European style hinges would not work with how I built my cabinet
doors. I did use some of the European hinges on a hidden wall door that I built
once. It was out of 3/4 tongue and groove 1x4's, with 1/2 plywood on the
back. The door was soo heavy, that I had to use 5 of the European style
hinges on it, to make it hold the weight.
2manytoyz
Central FL
Check out Edsal cheaper than Stanley Vidmar. The shop I worked in at the shipyard had 40 feet Stanley Vidmar cabinets in the tool room.
Had not heard of that brand. Just gave their website a look. Looks very much like the Vidmar equipment! Might be somewhat cheaper, but still more than I can afford (buying a new house, just took a loss on the one I sold).
I build a lot of electronics. Lots of little parts, so small parts drawers are very handy. One such cabinet on the Edsal website, over $2K.
Here's a peek at one of the many I helped install at work:
Wonderful cabinets. We had a 53' trailer, 3 cabinets wide, all delivered to our shop. Over $30K worth. Quality stuff. The tough part is using equipment of this level, then looking to buy something for home.
I'm sure I'll end up building my own wooden cabinets and drawers. Someday when I hit the lottery, I'll have it all. Until then, I'll just get to drool over some of the pics you guys are posting! :thumbup:
