Old tool guy
- Joined
- Apr 13, 2023
- Messages
- 3,332
Ok. Then back to the first pic, what is the tool to the tight of the Derlon?
I doubt that would hold up to drilling tap holes for maple sugar trees. I ***** out a lot of hand drills with chucks. Than again that may hold up pretty well. Looks tough.A Simple Tool with No Name.
Do you mean "wore" out?I doubt that would hold up to drilling tap holes for maple sugar trees. I ***** out a lot of hand drills with chucks. Than again that may hold up pretty well. Looks tough.
Yea. Thanks for the correction. Not proof reading. My bad.Do you mean "wore" out?
One picture says it all . . . she's a Winner!Today she sent this picture, with no explanation.
What?
Well I knew what to expect, but something in my mind was hoping it was going to be about a gasoline engine powered cordless drill.
The reason I was hoping to see that is back when I was a kid our neighbor came home with a "cordless" reciprocating saw... it was like a big chainsaw engine with a 20 inch reciprocating blade... almost too heavy to be of any use... I recall everyone laughing about it and then laughing harder when he tried to demonstrate it and it was a real POS functionally![]()
Yes/no. Goodell/Pratt eventually had “Automatic Feed Chain Drive”, is a drill that adjusted tension as you drilled your holeHow does a chain drill work? I know one end chucks in the hand brace, the bit chucks in the other end, and the chain wraps around the item to be drilled. What then? As you turn the crank, does the chain automatically tighten to pull the bit into the wood?
Man,Yup, a cool piece of gizmocity. I think the advance is slow for metal, not fast for wood. @WisJim will know for certain.
Great display, Jim. That looks like a lot of fun. Good mix of things, including books, and vertical and horizontal surfaces. Like a mini museum. Did you screw the pegboard to the back of the table? Edit: What is the button, top right, near your "HAND TOOLS" sign?I took a few items from my drilling tools collection to the "Collectors' Day" that our local museum had this Saturday
Always cool to see corollaries from Europe. Those are cleeeeean!...some Hazet 2135 models as part of tool cabinets from my HAZET collection.
I don’t think mine self-feeds.They are fun to use, just keep drilling, and it keeps feeding.
The pegboard is clamped to the back edge of the table, there's a horizontal 1x2 along the bottom back edge and a vertical 1x2 in the middle of the back of the pegboard. The button is a M-WTCA (Mid-West Tool Collectors Assoc.) pin back tin button.Great display, Jim. That looks like a lot of fun. Good mix of things, including books, and vertical and horizontal surfaces. Like a mini museum. Did you screw the pegboard to the back of the table? Edit: What is the button, top right, near your "HAND TOOLS" sign?
Nice.The button is a M-WTCA (Mid-West Tool Collectors Assoc.) pin back tin button.
Ol Sneelock, what a guy
Here is part 4.
..as we discussing… everyone is right.. I like that.
