The Original "Cordless" Drills
Beerhippie
Far NE Oregon
Roughly translated:
“hath a Worm at the end of its Bitt. Its Office is to make a round hole in those places of your work where the Stock of the Piercer [i.e. brace or bit-stock] by reason of its own Sholder, or a Sholder, or Butting out upon the work will not turn about….”
Means: ‘Works great in tight spaces.’
Google translate? ;)
Old tool guy
Just picked this up from an old guy in WV. I have not cleaned it yet, I have looked carefully but cannot find any makers marks. At the moment the bit advances automatically when the crank is turned, not sure if it’s supposed to do that. Cannot figure out the purpose of the flywheel on top. There is a set screw that can be tightened to keep it from turning.
WisJim
Menomonie, WI
@Old tool guy, that looks similar to some of the Goodell Pratt bench drills, and you could find a scan of a catalog online. Not quite the same as some that I found right away, though. They often had some type of automatic feeding mechanism and the flywheel helped keep the speed of the bit up while cranking. Millers Falls and other companies made similar drills back then.
GP bench drill
Beerhippie
Far NE Oregon
1762373415539-jpeg.2431422
When I was your age, we had to carve out the arc of shame by hand!
No feed mechanism?
I have it’s baby brother, posted over in the Drill Press thread. Mine is European made, imported by Spiegel Bros, not sure if they were the only importer. Gimme a minute, will add a link.
Arc of Shame pics
Some pics n info, whole thread is useful, I found a catalog listing in the last post.
WisJim
Menomonie, WI
Interestingly, most of the pins of the upper example are blind, while they are mostly through on the lower one.
At first I thought both were Stanley No732 or close relatives, but then spotted the 1911 John S Fray catalog showing model No6. I have not found a mfg stamp (on crank bar or elsewhere) yet.
I’m inclined to think the lower example is a knockoff, but with the improvement of the small roller that bears on a track inside the drive gear, reducing wobble. At the business end, it also has some kind of selector I have not yet explored.
I thought that I had replied to this post of last February, but I'm finally getting around to it. I think that the bottom drill is a Millers Falls No 12 with the 1873 Goodell patent chuck. https://oldtoolheaven.com/millers-falls/breast_drills/GoodellGrip.htm
esben57
Sheffield. England
Found these two in a local junk shop. Left is a Bradson No.1, the other a Union.
Both locked up but a de-louse lubrication and a lick of paint sorted them. I wanted to keep them to use but they were always in the way.
Sold them on but I think they could have been turned into lamp stands.
Secondly, around 1982ish my Father borrowed a cordless battery drill. Rockwell U.S made. Don't know the voltage, it was yellow in colour.
Anyways, not impressed he was. Not sure it was charged or his mate didn't supply the charger.
Anybody know of these Rockwell drills?
Russell Jennings set
This Russell Jennings pouch and bits was a Left-Behind at the flea this morning. The roll up had a very good label, but as you can see, the pouch itself was falling apart and crudely patched with tape at some point in its working life. I was eyeing it, with thoughts of repairing it with heavy needle and thread, but I have one of those triple-decker wooden R J boxes with the 1876 label under the lid filled with spur auger bits, so wasn't overly moved by this set. I have bought the occasional tool before from the seller, a funky woman, always at terrific prices (she is an estate sale maven, with a good eye, but doesn't really know tools) and will very likely see her and it again if you're interested, Jim.
Ayrhead
Ontario
This is my Stanley No. 1220. Made in Canada. It’s my favourite one because the bits are inside the wooden handle.
Ayrhead
Ontario
Here is another Stanley. No. 621 Special 1940. It’s made in the USA. No bit storage in the handle.
Ayrhead
Ontario
My last one. A Yankee No. 1446. Patent # 1.633.400. Thanks to @WisJim as I originally thought the handle didn’t hold bits… well it turns out that it can! I added a photo to show the handle loosened and screwed off where the knurled piece is.
WisJim
Menomonie, WI
I always like those Stanley H1220 drills---I remember using one to drill random holes in scrap wood when I was of preschool age, at the summer camp where my grandfather was the caretaker and my dad taught woodshop for many summers. I had the run of camp in the weeks in late spring before it opened.
Ayrhead
Ontario
I have found several push drills over the past few months. Both of these I found at Saturday’s estate sale had a full complement of bits.
I added that one to the North Bros./Stanley push drill drawer in the basement Kennedy box. IMG_6950.jpeg
Lookin’ Good Don. 👀
WisJim
Menomonie, WI
I just got an attachment or accessory for a bit brace. It's Reinhold's patent 491,189 from Feb 7, 1893. It holds 6 auger and/or screwdriver bits while attached to a brace and allows the bits to be interchanged for use. The only other one that I recall seeing was on Donnely's auction a year ago, and it had some different bits than mine. Mine has 4 augers that look all the same size, and 2 screwdriver bits that are the same. I'll be looking for other bits that fit this device (round shank with a pin on one side).20260223_140034.jpg
@WisJim How long is it, kinda reference less laying there. Are those Doweling bits, regular, bell hangers, etc. inquiring minds and all that?
Eric Brown
The ends of the bits with the pins look like a larger diameter. Maybe 1/2" or so? Were the larger ends separate or part of the bits?
WisJim
Menomonie, WI
I went out and measured it. The bits are a little longer than the doweling bits that I have, about 3 3/4" overall. They are 3/8" bits and the base is about 7/16". The whole thing is about 7 1/2" long. The bits are all one piece except for the pin in the side. Measurements were all with a ruler.
  • Like
Reactions: RTM
Eric Brown
Thanks. Good luck finding bits. You might be able to make some with a bushing and use a long pin to attach. Not sure if that would really add anything to value. Vary rare as it is. Good find.
I cleaned up the Russell Jennings and Irwin bits that came from Saturday’s estate sale. I didn’t really mean to buy them, I thought that they might have fallen out of the Craftsman sets and the room was very dark. IMG_7150.jpegIMG_7151.jpeg
Eric Brown
Here are a couple of unusual braces. They are for twisting wire and were used for making boxes. The wire will twist and then at about 3/4" break it off. There were several patents dealing with the twist and a later one for length. Top one is not marked but the bottom one has Pat May 1, 23, Oct. 2, 23, and 4-One Box Makers, Rockaway N.J. The first patent date actually covers two patents, 1453446 and 1453447 while the second date is for 1469711. Trying it out I used a old coat hanger. Twisted right up nice and tight.
  • US1469711 Wire Twister Oct 2 1923.pdf
Eric Brown
Here is another brace attachment that is for installing hooks. Marked Greenlee. The other markings are very hard to read. There is a Cat No 72Y-4 and Pat No. 2437762 (Mar 16, 1948) by Louis Simonin. Not listed on Datamp.org
I did try twisting some wires and it worked. Unlike the fancy version posted earlier this required manual trimming.
  • US2437762 Greenlee Hook Setter 1948.pdf
Pat No. 3457?62. Probably wrong on the numbers
Running the ? as 0-9 got nothing in US patents. Also tried changing your leading number to a 2, still nothing. Can we get a better pic of the number?
