The Original "Cordless" Drills
Old tool guy
LH thread? Great. Here are a couple more pics, I might take you up on that offer. The shank is about 3/8” dia x 7/8” long.
Eric Brown
Thanks for the pictures. Another option for you is to cut the broken part off just above the shoulder. Then put a tight-fitting washer on it and peen the end over. If you had access to a welder you could also weld the washer on. Of course these options are basically permanent where a nut or screw would allow future removal.
Mike'smeatshop
It is a design to only take off once. I would take mig welder with some heat first, and build it upDSCF8148.JPGDSCF8149.JPGDSCF8150.JPGDSCF8151.JPG 1/2 inch, grind it down to original and then take a hack saw and cut a cross to mushroom out with your main screw.
Mike'smeatshop
I know folks here are reluctant to give advice, like “what I would do is …” but I’m going to ask anyway. I have this H. O. White No 2 brace (probably 1830-1850) that has a top cap problem. Here is a picture from the Sydnas Sloot site that suggests what the cap may have looked like.
I’m guessing the large screw was lost and a previous owner split the top if the shaft and mashed it over like a cotter pin, spreading the tails. When i bent the tails back together, they broke off. So what I’m thinking is to cut off the broken part of the small dia shaft, drill and tap it, and use some kind of screw to hold the cap in place. I don’t have a lathe so i will have to do with whatever the hardware store has. Not trying to get it back to factory condition, but i do need to secure the cap in place.
Is it the design that says. H.O. White No 2 Brace? Or is there some indication of marks that says H.O. White? Tell me more.
Old tool guy
It has this washer … that might be slightly too thick. Although if i start peening it might push it down and be just right.
Old tool guy
Mike ... tell me more. Is the inside of the cap threaded for that plug? Mine is not. And i’m not understanding how you made the plug.
Eric Brown
Try sanding the washer down until it's flat on both sides. Then countersink on side and position it at the top. Then when you peen the material has a place to go and is more likely to secure the washer. That should work for you.
Mike'smeatshop
Where did you find the information on H.O. White?
Eric Brown
Here. http://www.sydnassloot.com/brace.htm
Click the “braces collection” and start reading. H O White is part of “Taylor Patent”.
Sandy Moss has excellent information. Not sure what will happen to it as he died September 2024. Not sure about the tools he had for sale either. Probably will be sold on consignment by one of the larger dealers. He will be missed. R.I.P.
Old tool guy
This is what you said in #164 … doesn’t make sense.
Eric Brown
I believe he was saying to use a welder to rebuild the shaft to something larger in diameter and then grinding it down and making the shaft longer. After grinding it down, put the washer on and cut the shaft so it is longer. Then cut a cross into the top of the shaft to make peening easier. This of course assumes you have a welder, or access to one.
Mike'smeatshop
Take a welder and build up the bad end with weld to about the original size of the length. And then grind it down to the right diameter and length. And then take a hack saw and cut a cross like mine. And after you slip the knob on, take a punch and mushroom the end like mine.
Old tool guy
Ok, i thought you were explaining how to make the large slotted cap.
If i flatten and/or slightly thin the washer, i think the current length is enough.
Old tool guy
Mike ... what thread is the plug in the end of the cap? I cleaned mine out better and discovered that it is threaded. Best i can tell, it’s something like 5/8-18 but that’s some guessing. I don't have a tap bigger than 1/2” and it’s real hard to read how the teeth in my thread gauge fit. I think i will take it to the local Ace hardware and try some bolts.
Mike'smeatshop
Yea. My thread gauge says 18 x 5/8. Now my brace is a model 1 1/2 if that makes a difference.
Eric Brown
Working on the auger list and have a few I have not been able to identify, yet. Anybody know?
First is a counter bore, no markings. Makes a flat bottomed hole. Adjustable from 1 1/2" to 2 1/8", 1/4" pilot. The bolt holding it all together is a 5/16-16. (No not a typo, 16 threads per inch). Everything about it tells me it's old and was manufactured.
TheRealZeus
CONTINENTAL USA
📚 In order to aid in your quest, here are the some of the starter patents for expansive bits. It provides no definitive resolution, but whoever patent your’s there, would have likely sited one of them. 👌 cool piece!
Sourced from reference; lostartpress
Eric Brown
I had these prints done by Briony Morrow-Cribbs. Limited edition. She still has some for sale if interested.
One of the best auger references is the one done by James E. Price called "A sourcebook of United States patents for bitstock tools and the machines that made them".
His reference focused on patented bitstock tools. My reference deals with what was made.
TheRealZeus
CONTINENTAL USA
Very kind! Thanks for the offer. I live virtually inside the internet, and would not have a wall available to display the piece. These are my walls! 🤔 Well,..We all share them, I reckon. Appreciate the reference! I’ll check that out!
Squirrel!
Rhode Island
I spent many hours with my Dad in his workshop as he was always working on something. As a woman in my mid 50’s, I’m grateful he included me in his projects.
Unfortunately, he passed away in May at 87. I am trying to organize and restore the tools as I find them. Because of this forum, I am learning so much. I’ve totally fell into the rabbit hole.
Today, I restored the Lakeside brace I learned to use as a kid.
Eric Brown
Good job. Be sure to oil it to keep it from rusting. (I use Metal Elixer from Union Manufacturing Co. for surface metals).
Squirrel!
Rhode Island
Thank you. I used some 3n1 oil on this tool.
TheRealZeus
CONTINENTAL USA
Great job! 👏 💯 she is read to stand the test of time! Positive ya Father is up there smiling! 😊
Eric Brown
Began fixing a C.E. Jennings auger box with double spur bit that were rusty. Cleaned and polished the bits. They are all good. The box though, need a bunch of work. It was made out of a cheaper wood, maybe poplar. The top and bottom had shrunk about 1/8" in width and one end had come loose. The clips that are used to hold the bits were either broken or bent. They have lost all grip. Probably made of brass. The box was taken apart and reglued the end. The top and bottom were reattached using small brad nails to allow wood movement. The blocks for the clips were replaced with hickory and new clips from McMaster were installed. The insides of the box was painted red and the outside will be painted black. This wasn't a set that a collector would want so I did what was needed to make it strong for a user. In the picture below the hinges have not been installed yet. The clips hold really well. Had to squeeze the clips for the smaller sizes.
Old tool guy
The flutes on the #14 aren’t polished as well as the others.
Just kidding … awesome job. Did you have all the bits, or did you have to find replacements?
Eric Brown
Thanks. You are right, the #14 does need a little bit more polishing. The #10 is a replacement but is from the same maker and same cutters.
Eric Brown
New update to the auger list has been done. Up to 285 pages with a few more to go. Won't have another update until next year.
Latest update includes a bunch of depth stops. Even bought some more to add but don't have them yet.
See the list here (click on Eric Brown Auger List to see): https://oldtoolheaven.com/auger-bits/openerimg/AugerMakerReference.pdf
Enjoy and have a good holiday.
