The Original "Cordless" Drills
Eric Brown
Pat No. 3457?62. Probably wrong on the numbers
Running the ? as 0-9 got nothing in US patents. Also tried changing your leading number to a 2, still nothing. Can we get a better pic of the number?
Added new picture to the original post.
Eric Brown
Found it and I was wrong, it's a hook setter. Edited the above post to correct and add pictures.
  • Like
Reactions: RTM
Old tool guy
I thought I had posted this earlier but i can’t find it. Any ideas what this is? No markings. It’s obviously some type of corner drill, there is a flat on one side of the head and the short stub shaft at the square corner does turn the chuck.
Old tool guy
Thanks, i will go through those references. The initial link you provided goes to “geared” braces, which are different from mine, mine does not have the driven gear.
Eric Brown
Look again at the first two pictures. I think they are a match.
Old tool guy
I am seeing the top part of the frame as a twisted spiral. Maybe it’s just the pixeling of the photo.
WisJim
Menomonie, WI
Here are my Bennet-Bloedel drill braces. The one with the tag has the knob or pad replaced with a common round one, and I made the crank arm for it many years ago, based on dimensions given me by someone on the Old Tools list.
Old tool guy
Just got this tenoning attachment, trying to figure out the manufacturer. Overall it’s in great condition, most of the japanning is still on it. I have not cleaned it yet, but so far the only mark is a patrnt date on the blade holder: Mar 5 78.
Eric Brown
This would be a Stearns. Patent attached.
  • US201064 Stearns 1878.pdf
Old tool guy
Started in on cleaning up the Stearns tenon device, itks in great condition, except there is a little more pitting on the blade than i had expected. And i was surprised to see that the blade is double beveled.
That can be a blessing and a curse. The back bevel can make pitting less of a concern. But if the tool is not set up for a double bevel, sharpening it away is a PITA. The patent may tell you more
Old tool guy
Was able to copy off the patent description.
This cutter is beveled on both sides, so that it can be reversed, and wear either side up alternately, to equalize it.
  • Like
Reactions: RTM
Old tool guy
In post #295 i showed a tenon auger, cleaned it up, re-japanned, sharpened the blade. Didn’t work well. I think part of the problem was getting it started on the square stock. So i bought a spoke pointer.
E C Stearns model 0, picture is from the 1924 catalog. $1 each. It is in very good condition, mostly just dirt and grime, except that some previous owner applied a thick paint to the blade, screw and washer. Got that off. Now i need to finish sharpening the blade and try it out. The blade is very thin, only about 0.050” or just over 1 mm.
Definitely a problem with tenon cutters. Next you will need a smaller one for tiny tenons
I thought cutting the square down to an octagon would help, but way too slow for a few $ invested in a pointer
Yesterday was expansive bit day. I finally found a replacement for my early broken Convalco bit that Ives in my NAF toolbox. It came from an eBay seller. The large cutter was missing
I cleaned up this rusty bit found at a recent estate sale.
it turned out to be a Greenlee wheel adjusting bit in quite good condition. IMG_8422.jpegIMG_8421.jpegIMG_8422.jpegIMG_8423.jpegIMG_8424.jpeg
Eric Brown
Take the broken one, cut the end off and then grind a screwdriver tip on it. Or is you can weld, put a 3/8" square drive end on it. It can still be usefull.
Old tool guy
Need a little help cleaning this up: the crank handle and gear.
The handle was japanned and the gear was painted red all over, except the teeth. The also look like different kinds of metal, and in fact they are 2 parts pressed together and pinned to prevent slippage. I don’t plan to disassemble them, but i do plan to re-japan everything that was, and paint everything red that was.
So the question is … how do i mask off the teeth when i spray paint the red.
Eric Brown
Two ways come to mind. Put some blue tape on a sheet of plastic and then use a knife or gasket cutter to cut out a ring. There would still be a little overspray on the ends of the teeth that could be cleaned with a wire brush,
One tool I use for some nickel plating is a masking lacquer. You would paint it on as a thick coating over the teeth. Do your other work and then the mask just peels off
One source: https://caswellplating.com/mask-it-masking-lacquer-8-oz.html
Eric Brown
Was plating today and used the masking lacquer. Took picture so you can see how it removes. In the picture are two sections out of similar push drills. I didn't want to plate the spirals because the plating may make the tolerance too tight. The blue peels right off.
Gmonkee
These were my attempt to become a bit more efficient on an extreme budget years ago. I made artisanal furniture for fun. The one is new, the others broken junk from street markets. I patched them up to useful from spare bits I had . Ball bearing replacement handles are nice.
These are working tools before we had too many battery drills here. Not pretty, not perfect specimens of the tool.
One is hex bits, another a regular drill chuck and the last for the proper bits for them.
You can still buy the yellow and black Pretul from the current Truper catalog. It's ok but cheap plastic.IMG_20260529_104350.jpg
59Sled
Santa Clarita, California
I enjoyed restoring a my first eggbeater drill (see post above) that I went back to the same antique store and bought 2 more.
Couldn't pass up his prices on them.
First is a crusty Dunlap. Not sure what model it is. Also not sure if there is even various models of a Dunlap.
Second one has no markings on it other than it being stamped in 2 places with "BW"
With the hexagon main chassis, it looks like a Defiance by Stanley to me. But every Defiance I look up is slightly different.
Either the big gear is different looking, or it has markings on the ferrule, or they don't have a third knob.
Any ideas on a maker or is it a Defiance?
Old tool guy
Need a little help please. I’m in the reassembly phase of my drill press and i need confirmation of a detail. Can somebody please remove this screw and tell me what's behind it. The screw is not long enough to go all the way through the threaded boss, pretty sure there is a spring and ball bearing hidden in there. I think it's part of the auto-feed mechanism. I have the screw and spring, but indon’t have whatever the spring pushes forward.
Just to the left of that knob you can see an exposed part of the shaft, and you can see the edge of a groove into which a key slides, that key connect the small shaft mounted gear to the shaft so it can be driven by the crank handle. Because the keyway runs almost the full length of the shaft, i assume it keeps the small gear engaged to the shaft as the shaft goes up & down.
Old tool guy
A couple more details. The chuck threads on to the fine threads on one end, the flywheel threads on to the coarse threads on the top end of the shaft. The pin connects the bevel gear to the shaft, the lengthwise groove allows the gear to move up & down the shaft while still connecting them. Instill don’t understand how the self feed works, maybe it will become evident when it’s all assembled and moving easily.
