BEFORE & AFTER....A Tool Polisher's Haven
J
JMLangford
Upstate SC
Is it just me or do you all wish we had more pics being uploaded!!! I love this thread. I don’t actually do any tool polishing but this is one of my favorite threads on GJ....
O.K. guys.....I know I've been slackin' off here lately....here's a couple more Before & Afters....
BEFORE:
Found this little J.H. Williams B50 double headed ratchet from the '30's....
I was extremely lucky to have found the 3/8" drive insert....I understand they are usually missing when you find the ratchet....
I cleaned the outside , then took it apart to clean and lube the innards....
J
JMLangford
Upstate SC
Cleaned up the drive cog (I used one of my bronze bore brushes to clean the inside drive area... :thumbup:)
Next, the pin, spring, and screw....
Then, shined up the inside of the head...
AFTER:
All lubed and back together....
J
JMLangford
Upstate SC
One more quickie....
BEFORE:
Picked-up these two pipe wrenches last year....one is a 10" no-name Made In U.S.A. and the other is a 10" Hercules...
AFTER:
Now, this is one of those "remove the rust...keep the patina" cleanings where I shined up the exposed metal but didn't repaint the red area.....THAT may change this summer :beer:...
PENDING:
Now, the Hercules is patiently waiting his turn this summer....
(I think I'm starting to break out in hives....:lol_hitti)
don long
southern california
Here is a little project I did last week.
It is a blow torch oven tool. I have no idea how it was used but it is made with very good quality brass so I had to clean it up
38872551745_9be3d88492_b.jpg2018-01-15 16.07.43 by don long, on Flickr
38872527685_eac30f8dc8_k.jpg2018-01-15 16.08.23 by don long, on Flickr
38872579635_70fd611bc6_b.jpgIMG_2466 by don long, on Flickr
38872574015_17da73a056_b.jpgIMG_2465 by don long, on Flickr
So here was the process
!. glass bead blasted to clean the pocket
2. grind down the casting marks using a 2" grinding pad on my die grinder
3. start the long tedious sanding process with a 3" velcro pad on my pistol grip polisher 80* , 120* , 180* , 220* , 320* ,400* , 600* , 800* and finally 1200*
By the time the 1200* sanding was complete the piece had a dull mirror finish
Next was the buffer using the green bar first on a hard wheel then the red bar on a soft wheel.
Now it shines with a deep reflection.
Last: to save the shine I sprayed the piece with a brass saving liquid called brass saver.
Now it's ready to put on display in the party garage
trijeff
Northern Cali
Looks great Don! Green/stitched and then red/loose for brass ... definitely noting this because that finish is outta site
Swingpress
Oh! Come on Don! We all know you buy that stuff brand new! You ain't fooling me!
Lol in all seriousness, killer work brother! That is on a whole new level.
Facebook Group: TheCatalog Live Auctions
cweidert03
New Castle, IN
BEFORE:
AFTER:
PENDING:
That red handle would look nice in my box!!
FMC1959
Montreal, Canada / Upstate NY
Some beautiful stuff on this thread. Don or anyone else who knows, I have seen many different colors for the buffing compounds, like white, green, grey, black and red. I have a green bar and IIRC it is fine. From Don's process, it would seem like red is an extra fine.
Is this usually the case, red will be more fine than green and some of the other colors might be coarser or even more fine than red?
Or depending on the brand or MFR, color has no bearing on the coarseness of the compound?
1953mercury
Steamboat Springs CO
Reworking the The X,Y, and knee feed nuts and bearings on my Bridgeport, and decided as long as it was apart I would do a little polishing on the handles and related parts. Didn't get to carried away like I would on engine cases and such, but they didn't come out to bad for an abbreviated job. Mike
littleponderosa
MONTANA
Ok. If I'm gonna get started down this road I need an equipment list.
Please chime in with suggestions - I'm outta the $700 baldors league till I can justify it - and a priority list.
I'll have time over money on this project.
Bill
eric.holmslice
Proud of my old school Atlas restoration. Nearly complete. All bare metal has been polished or being polished. I need to get some better compound for the stainless parts. I even polished bolt heads. I’m learning a lot from this forum. What is a good compound and buff for stainless steel? I’ve sanded all parts, but my wheel polish just isn’t cutting it on the stainless.
First thing I did was polished all three pulleys prior to the tear down. Basically pretended they were spinning on a lathe.
trijeff
Northern Cali
Bill
Look for a Craftsman block grinder 1/2hp or above, it'll take care of wire wheeling and buffing. You can go cheapo on wheels and buffers at Harbor Freight but I would recommend spending just a few more bucks on made in USA goodness, you won't be disappointed. In between rhe wire wheeling and buffing you'll need to do some filing and/or sanding in increasingly finer grits ... see Don's post on that a few back. And you have the number one thing this takes already ... time ;)
trijeff
Northern Cali
Re: BEFORE & AFTER....A Tool Polisher's Haven
Now THAT is absolutely amazing work right there, holy camole!!
chrisnazzy
Arizona
I have recently acquired both of these and the plan is to make the Baldor my buffer. I've polished alot of aluminum stuff over the years but my venture into vises over the last year leaves me wanting to up my polishing game.
Seems like an appropriate place to ask if one of you can recommend what buffing wheels I should get if results and quality were more important than price. Should I get 6" or 8"? Also could use a rec for good compound. I'm already exploring some sanding solutions down to very fine grit.3a7c53981443dc9c1e920c1bcbb48c10.jpgda94abb16e80af20332695a772cad2aa.jpg
bonneyman
Desert SW
AFTER:
Nice "water wheel drive" ratchet! :thumbup:
cweidert03
New Castle, IN
That is very nice work! I’d imagine looks much better than when it left the factory
Bears Fan
Indiana
This is quickly becoming a thread favorite!!! Awesome work guys :beer:
J
JMLangford
Upstate SC
Sometimes you just have to clean off the nastiness and leaves the scars.....
BEFORE:
eric.holmslice
Man I want a Wilton bullet vise so bad. They are so dang expensive.
Out of curiosity, how is everyone protecting polished cast metal or polished steel?
Clear coat? Wax? Oil?
Swingpress
I normally use gun oil for blades, but if you look earlier in this thread, someone pointed out a method that show real promise.
don long
southern california
When I have a few spare minutes I work on cleaning up a few old tools for a vintage tool display that I want to hang in the party garage.
Here is a shot of some of those tools that I'm working on.
It's just a start
IMG_2501 by don long, on Flickr
csp
Franktown, CO
Before and after of a Beverly Shear I picked up for $35 at an auction years ago.
Catfishdan
Central coast, California
Not a huge project, but I polished and re handled this old hammer I got at a garage sale today. I think it's an old Hart or a Deluge.
Jayman17
Seattle, Wa
:drool:
That is a beauty!
-Jay
FJ 432
Littleton Colorado
I hope this isn't out of place for this thread, but perhaps I can ask for assistance/tips on how to clean up an old vice. So far I've hit it with the power washer and a wire cup wheel. Doesn't seem to make a real difference. It's my grandfathers old vice and as such has sat in piles of mouse droppings and spider webs for fifty years. In an ideal world, I'd like to get it clean enough to paint. Couple pics of where it sits today, thanks in advance.
Start with this thread. It will help you big time:
https://www.garagejournal.com/forum/showthread.php?t=252830
ilovevocs
Toledo, Ohio
What kind of buffer are you using? Stainless takes either 1. allot more prep prior to polishing, or 2. A powerful buffer, aggressive wheels, and starting with an aggressive compound. Its difficult to get sufficient heat buildup in a stainless part for proper polishing with a an average bench grinder. I also use a higher RPM buffer ( 3600 vs 1800 rpm.)
Have had some parts that i use my curing lamps for auto paint to preheat the part if the size is two great. if the part is cold all of your compound will stay on the part and not in your wheel.
My supplier offered burlap sisal wheels that i used with their black emery that i would start with. I polished allot of stainless hydraulic hard-line for low riders in the late 90's. The fittings and the line were in good enough shape to just compound and buff without sanding or the use of setup wheels.
My supplier went out of business when Detroit stopped putting chrome steel bumpers on almost everything and stopped polishing as a side line. I will still polish my own things, and have been working off a huge supply of old inventory for supplies.
My plater was the plant manager for a small company that chromed all the bumpers for the ford superduty. His boss would allow him to chrome custom parts on the side for cash. Those were the days.
After i did the polishing and he plated an entire banshee frame for me for $80.00. Best part was he would run parts the day i dropped them off and have them back to me the next day.
In the late 90's when the custom auto world was booming and chrome was cool most shops here were three to four months for plating. I could turn parts around in a a few days.
drivesitfar
BEARSFAN: it was easier quoting your post of a lot of the cool stuff that's been posted and also giving all those members and everybody else a HUGE THUMBS UP.
ALL: GREAT JOB EVERBODY and thanks for posting all the cool stuff and especially letting us know what tools and methods you used to do all this spiffing up.
J
JMLangford
Upstate SC
TOOL POLISHER"S TIP #317.....
Whenever you're cleaning the rust from small letters or logos....
Take a #2 lead pencil and rub it all over the letters/logos....
Work it in all the nooks and crannies....rub it til it runs into wood...re-sharpen and keep going....
Take and brush the lead (graphite) off with a wire brush or wheel.....then you're ready to clean the rest of the tool.....
Lookin' Good.....:thumbup:
BONUS TIP: If you still have signs of dirt or rust (like inside letters "R" "O" "A" etc...) take a straight pick or dental pick and scratch it around on the stubborn letters , then repeat the pencil trick.....
Happy Polishing.....:beer:
