I made some progress on the Craftsman 100 DP restoration, the paint turned out really great.
I misplaced the spacer with the nut cut out that is used to hold the head frame on the column (Headstock lock - part #18119). Really hoping I find it! For now I'm going to use the part from the 150 which doesn't have the nut cut out but has a thread instead (Headstock and Table Lock - part #18121), which will work just fine. If anyone has an extra or would be willing to help me reproduce one (I don't have the machinery), I'd be grateful.
That is looking very good!
Did you find the lock cylinder?
honza.vosalik said:I'm looking online at these bearings. Do you think the covered bearings would work on the DP?
https://recstuff.com/towing-trailer...x_D9dL4GXpkoWS0JQTO2Aaupj4q1MyhxoCQKEQAvD_BwE
Check the origin of those bearings in that link.
Check the "Bearing" links in my first post.
I use shielded bearings in the pulley and sealed bearings in the quill. Be aware that the bore in the quill bearings should be a 5/8" special bore, not 15mm.
Next time I order pulley bearings, I think I'm going to try those bearing inserts that Cjmac posted.
I will often attempt to clean bearings before I order new ones. Most times they work great after cleaning and lubing.
If so, $150 isn't a bad deal...
