Hey all, I've asked several questions about wrenches, ratchets, and many other tools here but was often lost by responses that used grease-money, mechanic, tool junkie, motor-head, etc… jargon. I'm going to try and make things a bit more understandable and at least explain some things that I only found out through a lot of effort and google searches.
Ratchets:
<a name="teeth"></a>**-teeth: The amount of teeth found on the gear of a ratchet. This is usually found by turning the bit holder(1/4", 3/8" or ½" commonly) one quarter of the way around the ratchet and counting the 'clicks' as you turn. Multiply the number of clicks you counted by 4 and you've got how many teeth your ratchet has.
~Common tooth counts are: 36 (course tooth), 40, 45, 60, 72, 80 (Snap-On Dual 80), and 100. There is no algorithum for tooth count. Not like computers that are base 8 and base 10 or hexideceimal (among other terms) There is no 'quick' calculation for determing standard tooth counts.~puttsy
<a name="pawl"></a>Pawl:This is the second half of the gear that the gear-wheel clicks on. This part often moves/shifts when you reverse the ratcheting direction.
~The Snap-On 'Dual 80 ratchets (FL80 as a reference) have 2 pawls (2 pawls) effecitvely doubling the tooth count and leaving more teeth touching the gear at the same time. This is turn also increases the ratchets strength.~
<a name="detent"></a>Detents:These are dimples, divots, notches, etc…that a ball-bearing (usually anyway) clicks into. These are usually found on flex head ratchets and breaker bars. The bb is held up to fall into the detents by a small spring.
<a name="qr"></a>Quick-Release (QR): This is the mechanism, or way that a socket is placed on, and removed from a ratchet. A metal shaft goes through the center of the primary gear on the ratchet and to the bit holder. A ball bearing is usually fit into the bit holder and, when the QR 'button' is pressed, this bearing falls into a cut-out in the peg allowing a socket to fit onto the holder or fall off of the holder. Nearly every socket has detents in them to allow them to be held onto the bit-holder of a ratchet. This design was pioneered by Craftsman in the 1970's.
<a name="teardrop"></a>Teardrop or Pear-Head: The shape of the head of some ratchets. The shape is, as the name implies, the shape of a teardrop (or pear). Coarse tooth tear-drops are commonly the least expensive ratchets a vendor sells. The Craftsman 44807, 44808, 44809, 44811 ratchets are examples of this shape. However, Tear-drop ratchets are often the most 'premium' style fine-tooth ratchets vendors offer as well. (Snap-On FL80 is an example of a premium fine-tooth, teardrop ratchet)
<a name="round.head"></a>Round-Head (RH): This is another shape of ratchet head. It is, as the name implies, round. Round head ratchets are usually have finer teeth (more teeth overall) making them more versatile for confined spaces. Round head ratchets are often NOT of the quick-release variety. The 'teeth/primary gears' on RH ratchets are on the ratchet head. The pawl(s) are usually inside the teeth. Course-tooth round-heads are usually the cheapest type of ratchets found in cheap-tool bins.
Edits to Teardrop and Round-Head thanks to tyndall. .
<a name="fine.tooth"></a>Fine tooth: There is much debate as to what 'fine-tooth' equates too. A general idea is that there are more teeth per degree of movement of the ratchet than standard ratchets have. (i.e. A standard Craftsman 3/8" ratchet has 36 teeth, a fine tooth has 41 teeth with dual pawls. Making it an effective 82 teeth) Fine-tooth ratchets are often found in a round-head style due to a different mechanism layout than.
<a name="rhft"></a>RHFT:Stands for Round-Head Fine-tooth. This means the head of the ratchet is round and the tooth count (density) is higher than a a normal ratchet. Therefore, there is a smaller 'arc' needed for the ratchet to engage.
**-Round head fine tooth, Can refer to a specfic type of ratchet typically a Craftsman round head with built in spinner/thumb wheel, but can also had as an Allen, KD, Easco, etc branded ratchet.
Ratchets:
