About time for another update! I had my final inspeection on Thursday and sailed right on with a "good to go". So that's it for official signoffs. On with the work. I'm pushing to get the work room set up as working space and get all the stuff out of the house garage. Slow progress. Spent Sunday working on the corner bench. Bought 22 2x4s, a sheet of 23/32 plywood sanded one side and some 1x2 trim. I also used some of the stored 2x6 lumber, saved from the next door house foundation pour. Then I cut it all up into little pieces
Built some overhead 16" deep storage. That also mounts the bench overhead light. I tested it by swinging my 213.5 lbs from the shelf. No problem there.
Built the easy frame first - this section is 8' x 29 1/2" deep. I'm using a 2x6 on the back side so I can just rip the plywood, OSB, etc right in half and use both pieces. I was going to shave 7/32 off the 2x6 to make it level with the top, but thought that might be a bit much of "make work" on the 10" table saw. So I just left it alone. I can always pull it and shave it down later if I feel the need. But a planer would be a safer way to do it for sure.
The next section is 119" x 24" deep. I made it a bit narrower so I could easily reach the windows. The top frames are lagged to the walls studs with 1/4 x 3" lag bolts. The top doesn't move or even wiggle.
Mounted up the 5 drawer cabinet we found on sale at Sears late last year. It was about $120.
On the far left and far right, there will actually be two shelves with abotu 12" of space. The middle will have just the one for leg room and tall stuff, like air nailers or some such. The left side is 20' deep and the right side shelves are 16" deep.
The top is 7/16" OSB, 23/32 ply and 1/8 hardboard. The overhang will end up around 2 1/4" of so with the trim. There will be a 1x2 trim around the front and side edges to hold the hardboard in place. Vice will sit on the far left corner. Still needs a little trimming up, but this is as far as I got before calling it a day. It sits comfortably, so I think I got it like I wanted it. Floor slopes a little to the windows, but the mean height to the bench top is 38". Feels good standing and it clears my legs when sitting.
The left side wall will get three Seville wall cabinets. I have one - that was all that Sams had in stock this week. I'll use 23" linkable undercabinet lights. When my wifes sees that, I'll be putting some in the kitchen. Plugs will run along the back wall, spaced out however. Those will be surface mount metal boxes strung with MC cable.
