SilverJimmy
Could you post a couple pictures of your tool holder storage system on the wall behind your Sheldon lathe. Looks pretty simple but effective! Shop is looking great.
Like most things people worry about a whole lot of nothing.I've had people fret about wear- a steel bar on a steel block- but I use these extensively, and have seen virtually no sign of wear. Even my shop-made blocks, which are unhardened mild steel, hardly even show a mark.
Doc.
That is how I kind of pictured it happening too. But I know nothing about the operation and it's not mine.Nice splash guard. I think I would have hinged the whole assembly at the 4-bolt mounting plate.
Endmills have to be center-cutting in order to use them as drills. Alternatively, use a regular drill to clear out the center of the hole where the endmill flutes don't meet, then follow up with the endmill for a (near-) flat bottom hole.Noob question; I noticed that at one point you drilled a hole w/ an endmill.
When would you use a drill vs an endmill to drill a simple hole? Did you just grab what was closest or is there a pro/con to using an endmill?
So if you want a clean flat-bottomed hole, start with a normal drill and then finish with a center-cutting endmill?
And otherwise, you'd never use an endmill to drill a hole?
A braking resistor allows the VFD to dump that extra power into heat when needed, but it will only use it when the VFD knows its braking, ie if you're controlling the speed with the VFD[...]
I suspect the latter as well, I haven't ever used a VFD with a breaking resistor, I only have 2 VFD's in use and only one which I use to vary running speed, on a pillar drill.I have a rotary, good to 7HP, I think? I have that for things like the surface grinder and the big turret. (Which has an odd two-speed "concurrent pole" motor, which would have made running on a VFD virtually impossible.)
It's entirely possible I could bypass the VFD (which, as I said, is a recent addition) and run this thing on the rotary. All I'd need is a suitable disconnect switch.
Kind of funny that, in that case, whenever I would be taking an actual cut, three motors would be running in order to do it.
On the VFD, the question is, if it's set up with a braking resistor, does it shunt any extra energy automatically, at any time, or does it only do it when it's "told" to, such as when it's intentionally bringing the motor to a stop?
I suspect it's the latter- it is, after all, a braking resistor, and you have to program the VFD to use it. Anyone know for sure?
Doc.
