Moved my lift into the new shop. Had a couple of things I had to figure out
1) I needed to run the hydraulic house above the lift, but in the new shop, I have a large ceiling fan, so can't hang it from the ceiling
2) I wanted to mount the pump on one of the posts (it was on the wall in the old shop), but I don't want to drill new holes in the post.
so I designed a mount in Fusion 360 that uses the existing holes in the posts (the handle and the bar that sits at the top to keep hands away from the jacks/pistons (or whatever you call the cylinders
Solution :
3) On one side, made mounts for uni strut so I can run about 10' high and across for the hose and I'll mount LED's on it too for additional lighting
4) on the other side, I created a cleat so I can drop the pump on
5) It's all supported by class 8 stainless hardware for extra strength
20 prototypes in PLA and final print in PETG with 4x 1 mm walls x 20% 1m infill and best of all no new holes in the lift, and 100% reversible..
I hung of the cleat and I'm 180 lbs so I figure it can handle the pump
I'm going to and a stubby c-clamp to the front of the pump side for "insurance" that will hold the cleat in place if the plastic fails.. but it looks great so far.
I'm working on some accessory parts now to hold the pad risers via a dovetail attachment.
