Maxjax Installs: Post Here
Antbug911
Had a seal blow on an older rod style lock Dannmar MaxJax Hydraulic cylinder. Any idea if the replacements on the MaxJax site are the same as the older style one? Got quoted $240 per cylinder to rebuild.
Also anyone have any interest in creating a MaxJax owners group on FB?
realien
Atlanta
I'd be interested in a FB group. How do you know if a seal has gone, is it pretty obvious and the cylinder no longer rises properly? My Maxjax MX6 is 5 years old but it doesn't see "heavy" use, but I have had issue with one side raising faster than the other and had to add a flow control valve.
Antbug911
I have a waterfall coming from the seal. Lol
Doug
Salisbury, NC
How much is there that needs to be said or asked about these lifts? There's basically only floor mounting, hydraulics, modifications and repair questions to be discussed. These topics are well covered on this forum. That being said, I'd join a FB group anyway.
benzor
I have a saga to share on my MaxJax. I bought a new set of anchor bolts, and am on my third warranty call to them for incomplete package shipped.
First time I only got two anchor bolts, loose (not in the box)
Second time I got ten anchor bolts, but no sacrificial setting bolt.
Third time I got two sacrificial setting bolts (one partially threaded and one fully threaded, which are a different thread pitch than the anchors!
I measured them up, and they're a "special" 5/8-13 TPI for the anchors, meaning I can't go out an buy my own setting bolts / nuts (conventional US sizes are 5/8-11 and 5/8-18)
If anyone else has ordered new anchor bolts, did you get 1 or 2 setting bolts, and were they fully or partially threaded?
MFortie
San Diego County
Anyone have a pic of how the springs are supposed to go on the safety locks?
The way the install manual shows doesn't make sense to me...
EDIT: Found a youtube install video from beardedgarage that discusses the wonky manual directions and he showed how it actually should be installed. Turns out my intuitive orientation was correct, which was different than the manual.
ngng
Moved my lift under the mezzanine, but I'm considering buying another set and keeping both lifts installed.
NoviceWrench
Just found this thread, reposting.
Gents,
1) I'm living the Max Jax installation experience and thought I should give back to the journal if anyone is going through the same challenges.
The slide block positioning matters a lot! My Max Jax arrived with no installation instructions, so I thought I'd get the latest pdf from their website. The instructions were dated Rev B1 - April 2021, so I thought I was good to go....nope. I've attached a key document that's missing for some reason clearly illustrating how the slide blocks should be installed; weird thing is I found it on a Canadian automotive lift supplier's support website. Though produce by MaxJax they were no where to be found on the MaxJax(BendPak?) support page.
2) Would like any opinions concerning the attached picture of my wedge anchors. The anchors have pulled up slightly above the concrete, but torque to 90ft/lbs as specified in the shoddy at best instructions. Is this OK, or do I need to redo with epoxy anchors?
Thanks for any and all responses.
v/r, NoviceWrench
  • MaxJax-M6-Slide-Blocks-Install.pdf
In My Garage
ON
Gents,
v/r, NoviceWrench
Although my Max Jax is installed differently (shown on another Garage Journal thread), just some thoughts or ideas...
Is the garage floor smooth?
Are the holes in the base plate large enough for the OD of the anchors to pass through? If so, maybe a large heavy duty fender washer atop the anchor might help.
Is your concrete floor thick enough? Max Jax instructions state one thing and the anchor manufacturer state another thing.
Did you vacuum out the ALL the dust after drilling out of the anchor holes. Flush them out with water and let them dry throughly.
gpeterson
The MaxJax M7K installation manual has a spec for concrete re-work if the slab is too thin. It is nice to see something definitive from the manufacturer:
I bought a M6K which seems to be identical to the M7K other than the lower weight capacity, so I followed the spec:
I paid someone to do the pour & finishing while he was doing a large driveway pour next door. Now is the 28 day curing wait before I drill and epoxy in anchors.
gpeterson
I waited 26 days for the concrete to cure before drilling. I used a new a Bosch 7/8" bit and it felt pretty worn out by the time i got to the 10th hole @ 6.5" deep. I went with the max spacing, 135" measured from outer edge of base plates.
Each hole went through ~10x cycles of brushing and blowing with clean compressed air from the bottom until no dust was expelled followed by a gentle brushing with an acetone soaked towel and more air to fully evaporate the acetone.
I didn't take pictures when installing the anchors due to epoxy working time. It was abut 85 degrees and low-ish humidity when I set them, but working time seemed fine. Bolts were wrapped with 3/4 masking tape at the top of the threads and screwed into the anchors until the tape began to thread in. I used a a high-leverage caulking gun (https://www.amazon.com/gp/product/B008DYN9JO/?tag=atomicindus08-20) and went through the entire tube of supplied epoxy for 6 of the 10 of them. Mine shipped with PC Concrete (https://www.pcepoxy.com/products/concrete-repair/pc-concrete/) which isn't pictured in any of the literature from MaxJax. I bought a 2nd tube of the same epoxy from my local Ace hardware for the remaining 4 anchors. After a few holes I settled on nine full squeezes of the trigger with the nozzle at the bottom of the hole. Epoxy was injected one at at time and the anchor inserted with a clockwise twisting motion until they could not be pushed down further by hand. It took a surprising amount of force to push them flush and see excess epoxy expelled. I started with a decent size ball peen hammer then switched to a 10lb sledge.
I wall mounted the pump and extended one of the hoses with a union and https://www.amazon.com/gp/product/B000LNXRAG/?tag=atomicindus08-20. I also installed high-pressure 2.5" ******* at the cylinders & 90 degree fittings instead of the supplied 45 degree fittings since I ran hoses overhead. The supplied liquid sealant was used on the NPT fittings (not the JIC from pump to flow divider) and all are leak free so far.
MaxJax says "maximum tightening torque of Anchors is not to exceed 60 ft. lbf" so after 48hrs of epoxy curing time I installed at 55 ft/lbs and bled the system. AW 32 hydraulic oil was used as it smells far less that ATF. I zip-tied some shop towels to the top of each cylinder to act as a dam during bleeding. I also learned that covering the top of each cylinder during bleeding prevented oil from spraying all over the garage. It took about 2.5gal, probably more than a standard install due to the extended hose on one side. After bleeding twice and a few cycles up & down it lifted evenly with no load.
I put my smallest/lightest/cheapest car on first, lifted past the first stop, then back down on the safety stops with hydraulic pressure relieved for for few minutes. Back down after that and re-torque the fasteners. A full height lift after that was no problem and torque check back on the ground was good.
I was able to get it to full height in my residential garage (using jackshaft opener) with this car and should be able to with the M5 as well. I'll be limited with overhead clearance on the SUVs but think I may still have enough height to drop an engine/subframe if need be.
I ordered an extra set of anchors to optionally bolt the posts closer and will likely return them. The arms are minimally extended lifting the midsize E90 and my other cars are E60, E70, and E83. Once I decide on extra anchors or not I'll use more epoxy floor paint on the new concrete pads.
rbrtmchl
Looks like a great installation.
Your most recent post says: "MaxJax says "maximum tightening torque of Anchors is not to exceed 60 ft. lbf" so after 48hrs of epoxy curing time I installed at 55 ft/lbs and bled the system."
I thought the recommendation was torque to 90 ft. lbs. Can you tell me where you found the above quote?
Slick111
Everett Wa
My second Max Jax install took a suggestion from a concrete guy dill your holes after 24 to 30 hour pour time frame much less effort to drill I used some steel rod in each hole to keep the mounting base lined up not moving. DO NOT install anchors for 25 to 30 days
Colin Len
Long Beach CA
Looks great! How wide is your garage? Fitment looks great but I worry these pics are deceiving and likely my garage is just too small for this setup :(
gpeterson
Thanks! Garage is 18ft wide but has a lot of stuff (cabinets, tools, machinery) on each side.
Colin Len
Long Beach CA
Wow, thats narrower than I'd expected. Mine is 17' so maybe there is some hope. Unfortunately, mine is also only 19' deep so like you I've got a ton of stuff on the sides since there's no room front to back for that stuff.
Do you plan to leave it setup most of the time or will you move the posts out of the way and only reinstall when being used? Seems like a hassle to uninstall/install all the time but maybe it's easier than I'm imagining? If I were to get one I think I could keep one post installed all the time but feel like the other one would be too much in the way.
gpeterson
I'm not sure yet but hoping that one post in place all the time doesn't get in the way too much.
gpeterson
Anyone want to buy my MaxJax standard anchor kit?
Rusty67
LA, CA
So much great info here, I'm subscribing to this thread. Wish I'd known about it when I did my install a while back. After dealing with Bendpak supports REALLY poor knowledge of the product. I've decided to use epoxy anchors instead of the regular ones. My version of the directions didn't have any info about the torque specs after the anchors were set. They emphatically told me I was supposed to set the anchors with 90 foot pounds AND torque the columns into the anchors at 90 foot pounds. They also were unable to tell me the total hydraulic fluid capacity of the system, they kept telling me that the reservoir size was the total capacity of the system (which it obviously isn't). I hope their support has gotten better since then.
gpeterson
Turns out the 1K HF hydraulic lift table is a great transmission jack for the MaxJax. I modified it to make the handle fold backwards. Would be nice if it went a bit higher, but I lowered the lift to drop a very heavy exhaust then transmission. Next time I pull an engine/trans I'll unbolt subframe and lift car above it.
jonesg
northern Maine/
that adj table would be a good addition for that lift, could also double as an adjustable work table.
Rusty67
LA, CA
The front flip handle mod is a must, I haven't don't it to mine yet.
As for using it as an adjustable work table, I serviced my lawn mower on it for exactly that reason. I was able to get it to the perfect height to work on, it was great.
Jason280
That's really pretty cheap for the hydraulic cylinders, but shipping would be a factor. I've had to have both of my cylinders rebuilt, but each of mine were under $100.
jiw42069
soooo close to having this install done. Waiting another week or two for the concrete and waiting for new hydraulic lines to come in the mail. Give me a break on the concrete finish, it’s my first time 🤣 the spackle knife was for scraping the floors, I bought a brand new finishing trowel, who woulda thought that it would take practice to master concrete finishing🤣🤣🤣 but I’ll tell ya what, the mud mixer was sweet.
jiw42069
Looks badass man, which anchors are you going to use?
I ordered 8” red heads, but I’m debating on going with the supplied wedge anchors. I’m already herniated, I don’t feel like dealing with picking them up and over the red heads if I need to move it for some reason lol.
My other thought was to just drill through my footing so I could always push the redheads down into the dirt if needed.
I was just going to shim it so it is plumb, then tack weld the shims to the base plate.
Rusty67
LA, CA
What about using an epoxy anchor that you can screw the bolt into rather than have a stud sticking up?
jiw42069
I’m not exactly opposed to epoxy but it’s not solving any existing problems honestly, that’s essentially what the supplied anchors are but mechanical.
Rusty67
LA, CA
Sorry, I think I missed what the problem is. What is the problem you are trying to solve? Some quick comments though.
If you weld the shims to the bottom of the base plate and you ever want to move the posts narrower or wider, you will probably have to grind the shims off because a different shim stackup will probably be needed in a different position.
If you don't want to worry about lifting the column over studs sticking up from the ground, bolting down seems the obvious solution to that problem.
I wouldn't use the metal shims that came with the kit. I couldn't get mine leveled properly with that kit. Instead I got a kit with very dense polyurethane shims that came in various thicknesses. This let me fine tune the shimming under the columns without having to stack multiple shims in one spot. My floor was strangely uneven and using only the metal shims I felt really unsafe by the time I got the columns level.
I also didn't use the bolts that came with the kit except to set the mechanical anchors. They weren't long enough and didn't get enough thread engagement to where I felt comfortable trusting my life to the lift. I ended up getting the next longer size bolt that gave me the proper amount of thread count to make me feel like I wasn't going to die randomly at some point while under the car.
If you drill all the way through to the dirt and push the stud anchors into the dirt after setting them, I don't think you will have enough structure left in the concrete to use them safely again. I'm not a mason or anything but the anchors expand and hammering them out probably means you will be taking the seating surface along with the anchor when they drop down. Even if you pulled them back up and in place, I'd be worried about the cement cracking and failing over time. Though I suppose if you torque the nut to spec, it should hold? I don't know enough about concrete but that would leave me worried about it at night.
I personally did not like the mechanical anchors I got with the kit and decided when I do this again, I would use the epoxy anchors. I'll be setting my maxjax up again in my new house, hopefully in the next few months.
Hope that is helpful.
Homewrecker
Toronto, Ontario, Canada
The installers used HDPE shims instead of metal ones on mine (full size 2 post) and one of the posts is actually sitting on a 3/8" x 19" x 18" HDPE 'plate' since the floor was lower on one side compared to the other. I was somewhat skeptical at at first but this material doesn't compress at all and works well. They told me they use this stuff under truck & bus lifts they install all the time.
jiw42069
I’m not really in any type of bind, just waiting for the Crete to cure. You asked what anchors I was gonna use, I had considered 8” long 7/8 red heads (because I my self and partially skeptical of the supplied anchors and short bolts.) the problem with red heads is that I would have the pick the lift up and over the anchor bolts which doesn’t seem worth it to me. My thought what that I could use the red heads and if the studs ever get in the way I can just push the red head down through the footing and use a different type of anchor in its place.
The welded (tacked) shims aren’t an issue, I only have one set of holes in my floor so it won’t be moved any where else, plus I have a few dozen grinders floating around 🤣.
Homewrecker
Didn't the Maxjax come with Wej-It PD58 Drop in anchors at some point? Did they switch to no-name chinese anchors now? Why not get a box of the actual Wej-it anchors and see how that goes.
If you want to go with threaded stud anchors take a look at the Wej-it ANKR-Tite or the Hilti Kwik-bolt TZ2 series. Both are mechanical and not chemical.
jiw42069
Hilti is my typical go to. The female type anchored is definitely preferred, I was just on the fence with what to use at the time.
