Vintage Veloce
Ah, and here is an old video of it in operation:
(Not scary at all! Look at that spring...)
I purchased a 24"x50' roll of this stuff to put over the 4x6s, which is roughly just the lower 12" around the perimeter. Hopefully cutting this stuff in half lengthwise won't **** too bad. (I will still have siding to fill in above the fiberglass to cover the ~1ft plywood strip.) The instructions say:Pvc expands and contracts way too much if you have any real lengths of the stuff fastened at both ends. My recommendation would be treated 1x or plywood and cover with something called ground breaker. It's a textured fiberglass sheet that comes in 1ft and 2ft high 50 or 100ft long. I used it on my last house to protect the pink board I put against my house foundation. Held up great to 10+ years of string trimming. Fades a little but other than that no complaints. That's what I'd use. They have a good selection of accessories for it at menards but you said those aren't near you. Maybe home depot?
http://www.homedepot.com/p/12-in-x-...ic-Foundation-Protection-Kit-GB-1-K/205735697
I used 20A GCFIs to feed 15A receptacles, as 15 are way cheaper, but still can plug in a NEMA 5-20 into GCFI.
DAMN ! That looks fantastic !
...... Turns out a sectional won't fit without losing valuable head room, so the existing door stays. It's actually functioning pretty good at the moment.
Im late to the pary as usual,
Regrettably this is a storage shed inconveniently located on a rental property 20 minutes from my house, so I won't be getting carried away with lighting. I picked up a few of these the other day that should fit the bill -So now the question is: what kind of lighting will our resident expert on the topic be installing?![]()
I hope someday someone will turn it into a proper workshop.For people in CT, Ocean State Job Lot is selling Maxlite shop lights for $15 - max 6 per visit.
Looks nice. I see you used groundbreaker too. Good stuff just dont hit it too much with weed eater or it eventually chips.Almost forgot - I finished the threshold. Used cedar shingles under a 2x6 and 4/5 x 6 to give a slight drainage slope. End result (pictured in prior post) leaves a 3/8" gap between door and threshold. Slope is only 2°, so not noticeable at all.
I'd never have known about groundbreaker it if it wasn't for you. Thank you very muchLooks nice. I see you used groundbreaker too. Good stuff just dont hit it too much with weed eater or it eventually chips.
.That's odd - I host my own pics so I don't think it's on my end.I can't see your pics. There a couple of other threads I can't see the pics on as well.
