Let's see your axes
Mr. Tool
Customizing a small ax.
I decided I wanted to create a special carving ax from one of my ax heads. I’ll point out now that a carving ax is not meant for chopping. The blade is held with one hand while the handle is held usually right next to the blade except for sometimes when you might hold the handle near it’s far end for some leverage and control. I should also mention I spent about 10 or more years building log homes so this experience is where these design ideas come from. I hadn’t planned to document the process so I don’t have any “before” photos but this one is close. I’ve drawn in some black lines along the top where I have started cutting into the head to give an idea of the original shape.
I used a horizontal bandsaw (in the vertical position, think metal bandsaw) and a zip disc on an angle grinder for most of the cutting. The ax head was about 2.5lbs to start with. There were no markings at all on this ax which is another reason I chose it. I didn’t want to cut up a cool old ax. However it’s not to say this ax was low quality, on the contrary I soon discovered it was really nice steel. If you look closely you can see the line that runs along from the bottom where I have cut up to the top. This is the generous amount of tool steel that was forged to the front edge for the cutting surface.
I sketched out a rough design on the ax with a felt pen. This was an evolutionary process that developed as I went about drawing it out. Originally I’d thought along the lines of a Hudson Bay ax for the back end but about here I got the bright idea to make a small adze head along the back side.
There are 2 ways to fit logs on the walls of a log house. One is to chink the spaces between the logs (caused by knots and bumps in their shape) with moss etc. to make them air tight and the other is to scribe the exact shape of the bottom log onto the log above it on both sides and then come along and cut out the “V” of wood between the scribe lines on the bottom of the top log. This way the top log fits exactly airtight atop the lower log. When cutting the “V” a chainsaw is usually the go to tool but you don’t cut to the scribe line. You use a hand ax to shave the last bit of wood out to the line.
The other thing you often do with a hand ax is shave little scallops of wood off a surface of maybe a window sill to create a bit of a slope for rain water to run off. Think of this like machinists used to do on cast surfaces with bearing scrapers (but a lot cruder).
When you are axing in this way and run into a knot it’s hard to get past the knot by shaving with the blade of the ax and this is why I put the tiny adze in the back of the head. You can carefully chip out knots in surfaces you are hand axing. Hand axed surfaces look gorgeous and are pretty much smooth and free of slivers.
I can be a bit of a cheapskate sometimes so when it came time to think about the haft I didn’t want to go buy the ideal piece of hardwood somewhere. I hate leaving the garage to go buy something so I thought about the piece of Gary Oak I’d scrounged from a landscaper. I know it’s not the same caliber of oak you find in the prairie provinces or central USA but worth a try and the price is right.
I needed a special bend so the head would be canted downward to expose the adze more.
After slabbing the log with a chainsaw, bandsawing out the stave and rough fitting the head:
the final smoothing was done with an abrasive disc on and angle grinder, wood rasps and then sand paper.
AWESOME! (y)
2oolhound
BC Canada
Ultra-cool.
That is an interesting project you have going! Post some work pieces when you get to that point!
Don't hold your breath for work pieces. Building my own log house is still on my bucket list but I'm running out of time. We''ll see. In the mean time I'm getting too much enjoyment just tinkering in my garage:). Most of my photos from back in the day are slides and filed away in hard to reach places.
:+1:
And an insightful write-up. Thanks, 2oolhound.
Thanks Lugs, I know I can get pretty windy and create some long posts but I figured I should fill in the blanks to justify the outcome (I've never seen an adze tooth on the back of an ax but it made sense to me), I just hope it's as useful as I imagined.
Thanks everyone for the praise!
Cool stuff. I’ve seen carving axes for small stuff, but none for log house work. I started to put one together from a lath hatchet, some day I may get to use it.
saukit
Amazing work 2oolhound! Write as much as you want, I'll read it all day!
I can't recall seeing an adze/ax - the Pulaski comes close, but it not an adze, but a mattock
Cheney made some carpenters hammers with an adze blade instead of a claw, but its a hammer, not an ax.
Arne73
These are a few of the vintage axes and hatchets I've got.
They are all in rough "as found" condition and currently I don't see any indication of manufacturers.
The axe is a project my dad fiddled with, still needs some help.
The tomahawk has R.C. burned into the handle, likely my great grandfather's.
A small axe and a loose axe head.
Arnie, the hewing hatchet head is my favorite to extend with a 28" haft for a light ax. I have on in each camp trailer. Those typically have invade hardened steel for the blade and the hammer face. Once cleaned you can see the line where it has been forged in.
Love the old tomahawk!
2oolhound
BC Canada
Yeah, the 1st time I saw one of those was one you posted on your hammer thread and I've wanted one ever since. Now those are extra useful hammers!
mdim
Old True Temper Flint Edge I got from my grandfather.
Mintgrun
Kingston, Wa.
This is a Grey Gorge cedar cruiser that is stamped Hartwell Brothers and Memphis. I think someone may have posted this image earlier in this thread.
Here is a good write up about this axe. https://texashistory.unt.edu/ark:/67531/metapth101117/m1/294/
The link above says the Grey Gorge axes were made by Warren Axe and Tool Company. I like their logo.
A couple more hatchets. EVANSVILLE TOOL WORKS from Evansville, Indiana and a True Temper Kelly Works half hatchet.
I get a kick out of how someone tightened up the handle on this one. Especially the staple/nail from the underside... plus a dozen more nails from the top.
rdenney
Finally getting around to rehafting axes in the new shop.
Here's a Council Tool 4-pound axe in the Jersey pattern from a couple of decades ago. Council Tool is still making quality axes in North Carolina. I used a Beaver Tooth handle for it, but the head is a little too toed in (not bad, just not ideal). When I got it, the handle was cracked and taped up with duct tape, and the owner thought he was taking me to the cleaners when I traded him a freshly rehafted import axe for it. These axes have fat cheeks in the American style, and deliver a lot of punch and eject chips well.
Here's the axe with a new handle I traded for the Council Tool. The handle is a Tractor Supply special. The axe works but I class it as good from afar, but far from good:
Here's one of my favorite axes: A Plumb All-American in the Michigan pattern with a 3.5-pound head. This one dates from about 1970. The handle is that lovely red color and still in perfect condition, mounted using Permabond epoxy.
I have a complete Plumb family. Here's a Dayton-pattern Boy's Axe with a 2-1/4-pound head and a 28" handle, also Permabond, and about the same age as the felling axe above. This one needs a visit to Mr. Sharpen :) Along with it is a Plumb Boy Scout hatchet from a little earlier. This was mine when I was in the Boy Scouts, but I seem to have this memory that my father had bought it earlier and used it a while before trusting me with it. He probably had visions of emergency-room visits and soaking up blood out of the floorboards of his car. He would not have been wrong.
My one expensive axe is a Hults Bruk Kisa, which could also be considered a boy's axe with a 2-pound head and a 26" handle. I'm showing it here with the Plumb Boy's Axe for comparison. The Swedes have done a good job of marketing. These are great axes, but they are not better than the classic American axes of days of yore. They are the best traditional axes currently available, however, and they come sharp out of the box.
I bought a couple of these military surplus, never used, hafted or sharpened Dayton-pattern TrueTemper ax heads about 18 months ago. These were painted OD, and they can be no more recent than Vietnam-era. They could be older. Here's one of them hafted on a Link handle:
This is a Snow and Nealley hatchet that I actually bought new, but have not yet sharpened (and it did not come with even minimal sharpening):
This barn-sale special ($5) turned out to be a Jersey-pattern Collins Homestead—a budget model back when budget models were no real compromise, now on a fresh Link handle:
Finally, this Jersey-pattern Kelly Woodslasher was my wife's father's axe. It was loose on the handle and he had wedged it with a steel wedge that didn't help much. He had also used the poll as a hammer--a no-no with axes--and probably why it got loose in the first place. The wife declared that I must keep the handle, so instead of cutting it off, pounding out the remains, and rehafting it, I trimmed the handle below the head to allow it to seat more deeply. I then drove it about a half inch further down on the handle and installed a new wood wedge. I then soaked then end grain of the handle and wedge in linseed oil for a couple of days to let the wood absorb the oil and expand. Tight as a tick now. I sharpened this one the old-fashioned way with files and stones. It's knife-sharp but that just takes too long! 1x42 belt sander from now on.
Rick "probably done collecting axes for now" Denney
John-O
Near Lake Tahoe in the mountains in California USA
Re: Let's see your axe's
ALL
: my Gramps was a logger in the PNW (Pacific Northwest) for about 65 years (16 to 81 years old) and when he would cut down the big trees up in the woods he would take an axe and chop a few spots to set in his 2 springboards to step up in the tree to use his chainsaw. my Gramps could hit the same spot on a block of wood every time if he didn't cut a piece of firewood on the first swing and he was still pretty accurate even as he lost 95% of his eyesight.
here's some pictures of some of the trees he cut and took on his trucks in the late 50's and since he used to take me to work with him when i was 4 to about 10 i saw a lot of these in person.
cheers and i'll try to find some of my axe heads and his Fro he hand cut cedar shakes with.
Thank you for sharing those photos. I was also raised in a logging family and made a living climbing for about 30 years.
Provincial
Near Salem, OR
I went to an estate sale Friday. One of the items I found was this True Temper Pulaski. For those who don't know, the Pulaski was developed as a multi-purpose tool for fighting forest fires. It doubles as an ax and a hazel hoe, so it can cut up small trees and brush, and also grub out a fire line to bare soil.
This one is marked "TRUE TEMPER" "FLINT EDGE" and "KELLEY WORKS". It is in very good condition, with the handle a little loose from shrinkage, but the original wooden wedge has not been driven in below the end of the handle. The handle has some traces of red paint (many forestry fire tools are painted red), and is smooth from being used. I call it "honest wear", that is really a polished surface.
I'll bet that if this tool could talk, it could tell some tales!
Provincial
Near Salem, OR
I have several pulaskis that I bought new to put in forestry fire fighting kits that are required during fire season. There was a head for another True Temper pulaski at that sale for $4.00, but it didn't say "FLINT EDGE", just TT and Kelley Works. I left it behind for collectors.
Mr. Wonderful
I picked up a "Vulcan Hand Made" True Temper Kelly works double bit axe head this weekend. It's got a stamping of a blacksmith hammering an anvil on one side and the True Temper logo on the other. I haven't been able to find anything on the model with the blacksmith on the side. If anyone has any info on this model it would be appreciated. I'll post some better pictures later.vulcan.jpg
Jazz1
Thunder Bay On.
Picked up this $2 swap meet pickaroon head that I believe was cut from axe head
The stamp is WELLAND VA,,as in WELLAND VALE. Axe head cut down to repurpose
I made the handle
BMW Rider
Calgary, Alberta, Canada
A couple axes I've been cleaning up this week to keep myself amused. The first is a double bit axe that was my grandfather's apparently. I've had it for many years, it's always been rusty and though I had replaced the handle years ago, much abuse left it broken again. The head has been lying neglected in my garden shed for years. After cleaning off the rust, I was able to make out some light incomplete markings on it and so far as I can determine it appears to be a Sager Chemical Process axe. No idea of the age though. When I cleaned the rust off it was clear to see the hardened steel of the edges versus the softer steel of the eye. The edges are very hard and a file won't touch them, but some work with a diamond hone has them razor sharp. I decided to just blue the metal and gave it a coat of protective oil afterwards. It looks quite nice now. I'd like to find a new handle for it or if I can't find one, I may choose to make one myself sometime.
The second axe is one of unknown origins and is probably nothing special. The only markings on the head are 3 1/2 Made in Sweden, no brand. It too needed a new handle as a big chunk was split out of it by the head. I cleaned it up and gave it a shot of paint, then found a new handle and go it back to useful condition. It'll keep it working as a general purpose yard axe.
2oolhound
BC Canada
This is such a great thread, I'm amazed at all of the variety and uniqueness of the axes you all are posting. Keep em coming guys!
I finally got around to making a Big Brudda for my carving ax in post 679. I picked this no name ax up at a swap meet for $6 with a short handle on it. Here it is with marking where I'll cut it.
As I mentioned in the last post I'm a bit of a cheap skate when it comes to spending $ so I decided to reuse the haft even though it has a nasty crack. I spread the crack and squirted in some white glue thinking the head would help prevent any future splitting.
I used a cheap 30 year old HF style band saw with a horizontal plate attached to do the rough cutting.
Here it is with the cutting done and the haft re-fitted.
After getting the wedges in I trimmed the top of the haft to the contours of the head, I also put a wire whipping on the handle to aid in preventing the old crack from starting up again from where the glue didn't penetrate to.
Also note how much tool steel is on this head. Wow, that's a lot of tool steel the maker forged onto this head! You could grind this edge for 100 years before running out of tool steel! I used an angle grinder with a flex pad to grind out all the nicks you can see in the 1st photo but stopped short of doing a mirror polish.
And here it is united with it's little brudda!
A carving ax doesn't have to have all of the dramatic euro style cut outs like you see here but I've always liked the look of them and do believe the low hanging beard does prevent the haft from striking the wood when chopping moreso than just being careful with a conventional ax.
bdbecker
Iowa
Here's my latest haul...
full
I can make out logos for Winchester, Warren, and Plumb on a few of them, we'll just have to see what I find after I run the rest through the e-tank. For what I paid for the lot, I'll still be happy with the deal even if the rest end up being unbranded generic axe heads.
catongw
I have a few. Since I retired I've taken up giving old rusty tools a second/third chance at life . Mostly axes/hatchets/knives and other sharp things . Have several not on the wall. Need to do another section of wall .
No names I customize. If I find a makers mark I usually just clean them up and if need rehang them.
Mike'smeatshop
I found a few up in the loft. A Simmons, Collins Broad Axe and one just marked B35. Would anyone have any idea what would the model would be? Thanks.
bdbecker
Iowa
My guess is that B35 axe is a True Temper. A quick search didn't bring up a lot of info, so you may have to do some digging to get a production time frame on it.
