Joe Cool
So if my garage is almost double the length of DSPark13's (36'x50'x12' 3 bay tandem) am I correct in assuming that should be doubling the fixture and light quantities? That sure seems like a lot of lights.
Platonic, thanks for posting the software! After a pretty steep learning curve, I am working on my layout. Any pointers welcome
Joe Cool - fdkss03 30x40x12 layout is similar, but your space is still larger.
Qty. 20 of 8ft 4-Lamp F32T8 like this Howard Lighting FSB80432ASEMV for $41.80 will yield 90fc @ 30" workplane in an empty room. How you use the space should determine proper location and you may find you need a couple extra to balance things after mapping the layout.
Hello, I could use some help with lighting. House is new construction. The garage will be 2 car garage with a 15'10" bump out as below. Ceilings are flat and about 10' high.
Garage will mainly be used for some weekend detailing and auto repair, mostly the former. I'd like to use T8s, as I don't have the cash to sink into LEDs at this time.
TIA.
A rendering.
Not recommended as this creates the dark ceiling cave effect.I'd use qty8 4' 2 bulb T8's lights (16 bulbs) with their reflectors and probably hung on chains to 8.5 feet.
All ballasts in new fixtures these days are electronic.Buy ones with the electronic ballasts. They start in all temps, don't flicker and are quiet. Spaced right they will provide ample lighting.
Fixture layout is use dependent. If you plan on using your garage for cars, follow perimeter of vehicles or you'll have shadows.Spaced right you won't have any hotspots. In my first pic check out the zigzag pattern of my lights. The ones running the length of the bay are about centerline of the car and the perpendicular ones spaced evenly between the first light and the wall. Pic 2 shows my garage door is pretty evenly lit; consider that 1/2 is basically lit by the end of a tube 5' away and the other 1/2 buy those parallel bulbs 9' away.
Do not put fixtures on centerline of cars, put fixtures between cars and cars and walls.
swanicyouth's 10ft ceiling height is perfect for surface mounted F32T8 strip lights without reflectors. The suggested 8.5ft hanging reflector fixtures is a poor recommendation since lower mounting heights require more carefully placed fixtures to attain even shadow free distribution. Better to offer no advice than wrong advice.Eh, more than one way to skin a cat and more than one way to arrange lights. Mine clearly works well for me. Like I said, YMMV.
DonPowers - You can't go wrong with LED in the cold. Recessed cans are a bigger challenge when used for general lighting since you need so many of them to equal the output of typical strip lights. If you want layout assistance, I'll need IES files for your fixtures and a garage drawing with ceiling height.
Give me a little time to model your garage and I'll get back to you.Platonic,
Any thoughts on lights around stairs?
Than
