- Joined
- Nov 4, 2017
- Messages
- 10,472
I would say so.
Yes I have been looking for years and they just showed upHeck of a find. Small and often overlooked but those pliers are not easy to get.
I have dad’s, and a second pair of end nippers, with a hole in the same spot from cutting a hot wire.Either that or he tried to cut a live wire lol. I've got a set that look like that for the same reason.![]()
Done it myself once on a hall light - I thought the off switch was up stream; it was down...![]()
It seems like a consensus has been reached.BRZZZZT!
You mean it was common practice for electricians to use their "Oops modified" pliers as a multi tool...it was common practice for electricians to modify their pliers like this. They made their own multi tool.
The BB is rumored to be Millers Falls in other tool genreMy saw has a "BB" stamp (definitely not BE) that I cannot find
Thanks for the reminder, RTM!
I hate to sound dense, but what's your point? I'm not saying the table is wrong, just incompleteRTM covered it well for this particular saw, but Long C also existed well into the late 50s on a variety of items.
In searching I do see the BF on screwdrivers here. (Oops, that's your post) I'm not enough of an expert there to say whose they look like, but it follows the table. I've kept a copy of the Codes, and updated as shown in yellow. Guess I should add Fuller before KTC?
This wrench however, does not seem logical as Atkins. Anyone suggest a maker? And if it is BE, who is that? And even tho BE is suggested, why does it not come up in a search, too common a word?
Just playing catch up.
For $20 that’s a **** worthy haul! Any of those could be sold for $20 each!I had a good day at a local swap meet today. Here are a few Craftsman ratchets I bought. I really only was interested in the 1/4" circle H open frame and the circle U rats. The seller wanted to keep them all together as a lot for $20 so I got the flying V 3/8" too. Haven't cleaned them up yet but they all work, even the detent balls will hold a socket. This is the first circle H open frame ratchet I've found. Ed.
What is the code? I am just trying to catch up. Thanks.
